Addition of New Turbulence Models giviing errors
Like Tree6Likes
  • 2 Post By floquation
  • 1 Post By sabyju88
  • 3 Post By floquation
Old   December 15, 2016, 22:48
Unhappy Addition of New Turbulence Models giviing errors
SD
sabyju88 is on a distinguished road
I wanted to add a new turbulence model so I followed the instructions in http://www.tfd.chalmers.se/~hani/kur...lenceModel.pdf
I created the Make/files and Make/options and then I ran wmake libso. The library ("libmyIncompressibleRASModels.so") was created at the right spot without any error which I can see. I also changed the controlDict to add
libs ("libmyIncompressibleRASModels.so");
But when I try to run my new model "mykOmega" I get the error
Selecting RAS turbulence model mykOmega
--> FOAM FATAL ERROR:
Unknown RASModel type mykOmega
So I checked if my library path is included or not using
echo $LD_LIBRARY_PATH | tr ':' '\n'
which showed me
/home/sabyju88/OpenFOAM/sabyju88-4.1/platforms/linux64GccDPInt32Opt/lib
i.e., the required library which has the libmyIncompressibleRASModels.so is included indeed.
I do not understand what is creating this error.
Any help will be really appreciated.
Thanks in advance.
sabyju88 is offline   Reply With Quote
Old   December 16, 2016, 03:52
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Silly suggestions:
  1. Typo in the library name?
  2. Does the variable FOAM_USER_LIBBIN point to the location your .so-file is in?
  3. Are there more "libs" in controlDict? Then I reckon they should be inside the same "libs" data block.
More complicated suggestions:
virmodoetiae and lpz456 like this.
floquation is offline   Reply With Quote
Old   December 16, 2016, 13:19
SD
Thank you for your suggestions which I followed to notice the following
1. I checked for any typo in the library name. There isn't any.
2. FOAM_USER_LIBBIN points to the location of my libmyIncompressibleRASModels.so file indeed.
3. I have used only this library inside libs.
Using "banana trick" I get
Valid RASModel types:
17
LRR
LamBremhorstKE
LaunderSharmaKE
LienCubicKE
LienLeschziner
RNGkEpsilon
SSG
ShihQuadraticKE
SpalartAllmaras
kEpsilon
kOmega
kOmegaSST
kOmegaSSTSAS
kkLOmega
qZeta
realizableKE
v2f
So, my RAS model is not inside.
However, I did not implement the runtime selection mechanism which I am gonna do it now and post my result.
Regards,
SD
Old   December 17, 2016, 17:23
SD
I implemented the runtime selection mechanism following http://hassankassem.me/posts/newturb...l/#new-version.
After compiling when I try to run I get the following error:
simpleFoam: symbol lookup error: /home/sabyju88/OpenFOAM/sabyju88-4.1/platforms/linux64GccDPInt32Opt/lib/libmyIncompressibleRASModels.so: undefined symbol: _ZN4Foam9RASModels8mykOmegaINS_29IncompressibleTur bulenceModelINS_14transportModelEEEEC1ERKNS_17geom etricOneFieldES8_RKNS_14GeometricFieldINS_6VectorI dEENS_12fvPatchFieldENS_7volMeshEEERKNS9_IdNS_13fv sPatchFieldENS_11surfaceMeshEEESL_RKS3_RKNS_4wordE SQ_
I then copied the simpleFoam solver and changed it to mysimpleFoam with the addition of
#include "/home/sabyju88/OpenFOAM/sabyju88-4.1/src/TurbulenceModels/turbulenceModels/RAS/mykOmega/mykOmega.H"
But I am still getting the same error:
mysimpleFoam: symbol lookup error: /home/sabyju88/OpenFOAM/sabyju88-4.1/platforms/linux64GccDPInt32Opt/lib/libmyIncompressibleRASModels.so: undefined symbol: _ZN4Foam9RASModels8mykOmegaINS_29IncompressibleTur bulenceModelINS_14transportModelEEEEC1ERKNS_17geom etricOneFieldES8_RKNS_14GeometricFieldINS_6VectorI dEENS_12fvPatchFieldENS_7volMeshEEERKNS9_IdNS_13fv sPatchFieldENS_11surfaceMeshEEESL_RKS3_RKNS_4wordE SQ_
Any help will be appreciated.
Thank you,
Regards,
SD
Old   December 19, 2016, 07:29
Agustín Villa
agustinvo is on a distinguished road
Originally Posted by sabyju88 View Post
Thank you,
Regards,
SD
In the solver you should not add it directly. I was facing with something similar a month ago. The tutorial you mention it's a bit old, but the core of the code should be similar. Did you follow the tree directory of OF4.1? Try to start your implementation from the kOmega code and modify it as you need. Remember that in OF4.1, you have two libraries, the turbulenceModels, and the incompressibleTurbulenceModels.
agustinvo is offline   Reply With Quote
Old   December 19, 2016, 23:05
SD
Originally Posted by agustinvo View Post
Hi Agustin,
Thank you for your suggestions.
I started with the kOmega code and haven't changed anything in it yet and my Make/options look like this:
EXE_INC = \
-I$(FOAM_SOLVERS)/incompressible/simpleFoam/lnInclude \
-I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude \
-I$(LIB_SRC)/turbulenceModels/incompressible/RAS/lnInclude \
-I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \
-I$(LIB_SRC)/TurbulenceModels/turbulenceModels/RAS/lnInclude \
-I$(LIB_SRC)/transportModels \
-I$(LIB_SRC)/meshTools/lnInclude \
-I$(LIB_SRC)/sampling/lnInclude \
-I$(LIB_SRC)/incompressibleTransportModels/Newtonian/lnInclude \
-I$(WM_PROJECT_DIR)/src/TurbulenceModels/turbulenceModels/RAS/mykOmega/lnInclude \
-I$(LIB_SRC)/fvOptions/lnInclude
LIB_LIBS = \
-lturbulenceModels \
-lincompressibleTurbulenceModels \
-lincompressibleTransportModels \
-lmeshTools \
-lfvOptions \
-lsampling \
-L$(FOAM_USER_LIBBIN)/libmyIncompressibleRASModels.so
I guess I have included more than I need but
  • am I missing any libraries or my directory path is incorrect resulting in the symbol lookup error?
  • do I need to change anything in the simpleFoam solver for this new turbulence model 'mykOmega' to work?
Again, thank you in advance for any suggestions.
Regards,
SD
lpz456 likes this.
Old   January 31, 2017, 10:33
Tobias
tosc is on a distinguished road
Hello SD,
did you already fix your problem?
Today I did encounter the same one, however, after changing the file /Make/options it did work.
Here is my options-file:
EXE_INC = \
-I$(LIB_SRC)/transportModels/incompressible/lnInclude \
-I$(LIB_SRC)/finiteVolume/lnInclude \
LIB_LIBS = \
-lfiniteVolume \
-lmeshTools
"files" looks like the following:
makeTurModel.C
LIB = $(FOAM_USER_LIBBIN)/v2f_Fluent
I did inlcude it via, system/controlDict:
libs ("v2f_Fluent.so")
control/turbulenceProperties:
simulationType RAS;
RAS
RASModel v2f_Fluent;
turbulence on;
printCoeffs on;
I hope it did help.
Cheers,
Tobias
tosc is offline   Reply With Quote
Old   February 1, 2017, 22:21
khedar
khedar is on a distinguished road
Thers is a big difference between Turbulence model compilation before 2.3 and after it. Since you are using OF 4.1 use this tutorial,
https://pingpong.chalmers.se/public/...o?item=3256524
khedar is offline   Reply With Quote
Old   February 2, 2017, 11:06
Thumbs up
Tobias
Thank you! Thats really perfect! No more nasty errors when starting a simulation of using the sample function.
Old   August 10, 2017, 11:20
Default Lookup error
Vedamt Chittlangia
vcvedant is an unknown quantity at this point
I tried making a new model or new solver yesterday and messed up to get this error.
simpleFoam: symbol lookup error: /storage/home/vjc5126/OpenFOAM/vjc5126-2.3.x/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so: undefined symbol: _ZTIN4Foam14incompressible8RASModelE
Make/files
myLaunderSharmaKE.C
LIB = $(FOAM_USER_LIBBIN)/myLaunderSharma
Make/options
EXE_INC = \
    -I$(LIB_SRC)/turbulenceModels/ \
    -I$(LIB_SRC)/turbulenceModels/incompressible/lnInclude \
    -I$(LIB_SRC)/tranportModels/incompressible/lnInclude \
LIB_LIBS = \
    -lturbulenceModels\
    -lincompressibleTurbulenceModel \
    -lincompressibleRASModels \
    -lfiniteVolume \
    -lmeshTools
Can someone please help me resolve a similar problem. icoFoam works fine but I have problem running simpleFoam. I even tried remaking simpleFoam in the /applications/solvers/incompressible but still receive the same error.
vcvedant is offline   Reply With Quote
Old   August 11, 2017, 04:42
floquation's Avatar
Kevin van As
I assume this is a new turbulence model that you include in a case using a "libs" subdictionary in your controlDict?
In that case, the library is dynamically loaded at run-time. That is, you don't have to recompile your solver, as your new library is not even used at compile-time.
Symbol lookup errors are nasty... I've encountered quite a few myself, and I have resolved all of them... But I do not yet have a good tactic to figure out where they come from.
One time, my problem arose because I did not explicitly define a (virtual) destructor in my derived class. The other time I had simply forgotten one line of the RTS.
That is, they are problems in which there is "nothing" wrong with your library, and therefore it compiles. But when you actually try and use the library, errors pop up, because the library is incomplete in some manner.
Since you are trying to compile a new turbulence model:
  • How did you write the turbulence model? More specifically:
  • Did you take an existing turbulence model, and then simply adapt it to your purposes... or
  • did you write it from scratch?
Either way, it is always a good idea to copy an existing turbulence model, as you can be sure that everything is already in there.
Either way, without your code, there is no way to diagnose the problem. But first, compare your code with an existing turbulence model to see whether you forgot something.
vcvedant, purnp2 and lpz456 like this.
Old   March 27, 2018, 06:44
Luis F is on a distinguished road
Dear Kevin,
I have the same problem:
yPlusRAS: symbol lookup error: /home/flowuser/OpenFOAM/flowuser-2.3.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so: undefined symbol: _ZTIN4Foam14incompressible8RASModelE
I tried to create my own turbulent solver using:
I am using OF 2.3. Somehow I get that error everytime I use simpleFoam now.
Luis F is offline   Reply With Quote
Old   October 30, 2018, 03:07
Karl Yang
HoneyBadger is on a distinguished road
I ran into the same problems as well. I successfully compiled a new turbulence model. However, I realized new things to be implemented, the second time I use the same method to compile, I encountered the same symbol look up error and never found a solution to debug it.
HoneyBadger is offline   Reply With Quote
new ras turbulence model, wmake libso
Multiphase Turbulence Models im_lenny OpenFOAM Running, Solving & CFD 8 January 31, 2019 11:37
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 03:34
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
Turbulence Models and external flow. Alan FLUENT 3 November 22, 2005 05:46
