Questions about mixtures
Like Tree1Likes
  • 1 Post By chriss85
Old   October 28, 2016, 10:31
Default Questions about mixtures
chriss85 will become famous soon enough
I would like to introduce mixtures at some point, where thermophysical properties are calculated using some kind of averaging or mixing law.
I have seen that OpenFOAM supports this to some extent with the multiComponentMixture class. As far as I can tell, it calculates a temporary mixture object which is created by employing the addition operators in the single phase submodels. Sutherland coefficients may be added up and weighted by the phase fractions for example.
However, this is not going to work for me, as I'm using data tables to provide my thermophysical data, and adding up the whole tables would be way too slow to consider it. Instead, I would prefer to pick values from the separate tables of each phase and average these values directly. Will I have to write a new mixture class for this? If so, how can the submodels (for example the class for equation of state or transport model) know its species name so that different paths for data tables may be generated?
chriss85 is offline   Reply With Quote
Old   October 31, 2016, 09:48
Still working on this. For reference, here is a visualization of the class structure of the thermophysical library, using the tabular classes I am using and the intended multiphase configuration. I think this may help with understanding the layout of the thermophysical model library in general.
File Type: jpg thermophysicalModels Class Structure.jpg (167.3 KB, 40 views)
wyldckat likes this.
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
Definig a mixture including other mixtures jipaz Fluent Multiphase 0 August 22, 2015 19:23
NACA0012 Validation Case Questions ozzythewise Main CFD Forum 3 August 3, 2010 15:39
Enthalpy equation for multicomponent mixtures alberto_cuoci OpenFOAM 1 October 8, 2009 11:59
