Parameter input file
Like Tree1Likes
  • 1 Post By H.Tofighian
Old   September 19, 2016, 03:18
Default Parameter input file
Foreign (non-US/Canada)
LucDirven is on a distinguished road
I have been using OpenFOAM for a few weeks now and all the threads on this forum has helped me tremendously. However, I am stuck know on the following issue:
I want to make a input parameter dictionary that OpenFOAM reads before running blockMesh and the solver. In this parameter file I want to define (for example) a geometry property, lets say the size of a cube used by blockMesh. How can I read the dictionary?
This thread has been helpfull:
http://www.cfd-online.com/Forums/ope...ictionary.html
I understand that you can read the dictionary with IOdictionary, but where do a place this code? In the controlDict?
Any help would be great!
LucDirven is offline   Reply With Quote
Old   April 27, 2020, 06:02
Athanasios Niotis
thanosniotis is on a distinguished road
Hello there,
I am trying to to the same! I would like to define somehow in an external directory the values of the points of blockMesh as well as the values in toposet dicts for the regions of the mesh refinement. Is there anybody with an idea how this could be achieved?
Best Regards,
Thanos
thanosniotis is offline   Reply With Quote
Old   April 27, 2020, 07:22
Hesam Tofighian
H.Tofighian is on a distinguished road
Why don't you use the "m4" to make "blockMeshDict" automatically?
you can define your parameter in "m4" file (for example: blockMeshDict.m4) and then use the following command:
m4 -P blockMeshDict.m4 > blockMeshDict
check the link to find out how to use "m4":
thanosniotis likes this.
H.Tofighian is offline   Reply With Quote
iodictionary, openfoam, parameter variation
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 18:25
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
