Accessing Pressure in my OpenFOAM code
Like Tree3Likes
  • 1 Post By Jerryfan
  • 2 Post By Jerryfan
Old   July 25, 2016, 13:59
Default Accessing Pressure in my OpenFOAM code
Dominic
Verse is on a distinguished road
Hello, I'd like a way to access the pressure parameter in my test case through OpenFOAM syntax. So far, the answers I've seen only refer me to this method:
const volScalarField & p = Foam::fvPatchField<Type>::db().lookupObject<volSca larField>("P");
But I received the following error:
error: invalid use of ‘this’ in non-member function
const volScalarField& p = this->db().lookupObject<volScalarField>("P");
Any idea what's going on? Thank you!
Verse is offline   Reply With Quote
Old   July 25, 2016, 15:53
Jerry
Jerryfan is on a distinguished road
Hi Verse,
where do you use this line of code? Is it in the main function? If it is, you can do it this way
const volScalarField & p = mesh.lookupObject<volSca larField>("P");
since pressure field is registered to mesh at the time of construction. Hope this can work for you.
LogiDF likes this.
Jerryfan is offline   Reply With Quote
Old   July 25, 2016, 16:51
Dominic
Hi Jerry, thank you for the answer, it works terrifically.
I was wondering if I could do the same with a different file of a different type, namely pointMotionU?
I tried the following and I seem to have run into a different error...
const pointVectorField& MotionU = mesh.lookupObject<pointVectorField>("pointMotionU");
error: forward declaration of ‘class Foam::pointMesh’
 class pointMesh;
Old   July 25, 2016, 18:24
Jerry
Hi Verse,
I think the problem is because of pointVectorField. Try to replace it with vectorField. It might work.
Verse and LogiDF like this.
Old   July 26, 2016, 10:18
Dominic
Hi Jerry, the solution turned out to be a bit more complicated, but doing this helped solve the problem:
	pointVectorField& MotionU = const_cast<pointVectorField&>
		mesh.objectRegistry::lookupObject<pointVectorField>
			"pointMotionU"
Hopefully future users can see this post to avoid my mistake.
Thank you for the help!
Old   July 26, 2016, 11:25
Jerry
Hi Verse,
You are right. The const_cast has to be added in front to cast away the constness as lookupObject returns const type variable.
const Type& Foam:bjectRegistry::lookupObject(const word& name) const
how to call 'p' as pressure into my code from OpenFOAM? atmcfd OpenFOAM Programming & Development 9 March 25, 2016 18:13
Parallelizing a code that involves OpenFOAM Nicolas Périnet OpenFOAM 3 November 24, 2011 01:27
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
