Implementation of turbulence->divDevReff(U)
Like Tree8Likes
  • 1 Post By rushs777
  • 1 Post By ChGr
  • 6 Post By kaifu
Old   July 11, 2016, 17:08
Default Implementation of turbulence->divDevReff(U)
rushs777 is on a distinguished road
I am a new user to Open Foam, and I am trying to understand the code in the UEqn.H file in simpleFoam. On line 9, as part of establishing the left-hand side of the U equation, there is the command "+ turbulence->divDevReff(U)". My understand is that the implementation of divDevReff(U) will be selected by the turbulence model choice made in constant/TurbulenceProperties. Several sources (http://openfoamwiki.net/index.php/Bu...DevReff.28U.29, http://www.cfdsupport.com/OpenFOAM-T...t/node209.html), seemed to support this. However, whenever I look in any of the files I have for Open Foam v3.0, I can find no function definition in any of the turbulence models. In fact, the only thing I can find in regards to divDevReff(U) is a series of virtual functions defined in IncompressibleTurbulenceModel.C (http://www.openfoam.com/documentatio...96_source.html). Seeing as how most of the solvers have a line like this, plus the tutorials were working, there is just something about this I'm not getting. Would anyone mind sharing with me how this works, and where the definitions are for divDevReff(U) in the different turbulence classes? Thanks!
lpz456 likes this.
rushs777 is offline   Reply With Quote
Old   July 12, 2016, 03:53
ChGr is on a distinguished road
Hey,
the definition of divDevReff(U) can be found in the file linearViscousStress.
https://github.com/OpenFOAM/OpenFOAM...iscousStress.C
Michael@UW likes this.
ChGr is offline   Reply With Quote
Old   July 12, 2016, 12:07
Thanks for the reply, but that is actually divDevRhoReff, and I am looking for divDevReff. Do you know where that is located?
Old   July 12, 2016, 16:24
check here:
https://github.com/OpenFOAM/OpenFOAM...bulenceModel.C
Old   May 4, 2018, 00:55
Kai
kaifu is on a distinguished road
In OF 5.x
incompressible::turbulenceModel is defied as
typedef IncompressibleTurbulenceModel<transportModel> turbulenceModel;
the above class is inherit form class template TurbulenceModel
template<class TransportModel>
class IncompressibleTurbulenceModel
    public TurbulenceModel
        geometricOneField,
        geometricOneField,
        incompressibleTurbulenceModel,
        TransportModel
where the class template
TurbulenceModel
geometricOneField,
geometricOneField,
TransportModel
is inherit from class incompressibleTurbulenceModel, as
template
    class Alpha,
    class Rho,
    class BasicTurbulenceModel,
class TurbulenceModel
    public BasicTurbulenceModel
class incompressibleTurbulenceModel is inherit from class turbulenceModel as
    public turbulenceModel
in solver simpleFoam if we seclect kEpsilon as turbulenceModel
the function divDevRhoReff is interpretted in the following way
template<class BasicTurbulenceModel>
class kEpsilon
    public eddyViscosity<RASModel<BasicTurbulenceModel>>
class eddyViscosity
    public linearViscousStress<BasicTurbulenceModel>
Foam::tmp<Foam::fvVectorMatrix>
Foam::linearViscousStress<BasicTurbulenceModel>::divDevRhoReff
    volVectorField& U
) const
    return
      - fvc::div((this->alpha_*this->rho_*this->nuEff())*dev2(T(fvc::grad(U))))
      - fvm::laplacian(this->alpha_*this->rho_*this->nuEff(), U)
Kai
kaifu is offline   Reply With Quote
divdevreff, turbulence, ueqn.h
Turbulence model implementation errors elbertj OpenFOAM Programming & Development 10 November 29, 2016 09:28
Implementation of Free-stream Turbulence into SU2 ericthefatguy SU2 3 January 15, 2015 13:36
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 05:30
