Making a PtrList<PtrList<volScalarField> > or making a square matrix volScalarField |
June 29, 2016, 12:10 |
Paul
Rep Power: 10 |
Hi guys, I'm trying to create a volScalarField for a square matrix of values. Specifically, in a nuclear reactor physics context, I'm trying to make some convenient data structure to hold the scattering cross-section matrix which is a property of a given material and for g energy groups will have g^2 entries.
Having had great success and finding much convenience in storing other properties in the form of PtrList<volScalarField> my first inclination is to attempt to extend this method to a second dimension. For example, for the property sigmaT I've written in createFields.H: Code:
PtrList<volScalarField> sigmaT(energyGroups); forAll(sigmaT, i) { sigmaT.set ( i, new volScalarField ( IOobject ( "sigmaT"+i, runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensionedScalar("", dimensionSet(0,-1,0,0,0,0,0), 0.0), zeroGradientFvPatchScalarField::typeName ) ); } Code:
PtrList<volScalarField> sigmaTo(energyGroups); forAll(sigmaTo, energyJ) { sigmaTo.set ( energyJ, new volScalarField ( IOobject ( "sigmaTo"+Foam::name(energyJ), runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensionedScalar("", dimensionSet(0,-1,0,0,0,0,0), 0.0), zeroGradientFvPatchScalarField::typeName ) ); } PtrList<PtrList<volScalarField> > sigmaFrom(energyGroups); forAll(sigmaFrom,energyI) { sigmaFrom.set(energyI,sigmaTo); } Code:
In file included from /opt/openfoam30/src/OpenFOAM/lnInclude/tmp.H:139:0, from /opt/openfoam30/src/OpenFOAM/lnInclude/PtrListI.H:27, from /opt/openfoam30/src/OpenFOAM/lnInclude/PtrList.H:436, from /opt/openfoam30/src/OpenFOAM/lnInclude/List.C:30, from /opt/openfoam30/src/OpenFOAM/lnInclude/List.H:259, from /opt/openfoam30/src/OpenFOAM/lnInclude/labelList.H:48, from /opt/openfoam30/src/OpenFOAM/lnInclude/UPstream.H:42, from /opt/openfoam30/src/OpenFOAM/lnInclude/Pstream.H:42, from /opt/openfoam30/src/OpenFOAM/lnInclude/parRun.H:35, from /opt/openfoam30/src/finiteVolume/lnInclude/fvCFD.H:4, from MOCMEMRsolver.C:35: /opt/openfoam30/src/OpenFOAM/lnInclude/tmpI.H: In instantiation of ‘Foam::tmp<T>::~tmp() [with T = Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >]’: createFields.H:241:31: required from here /opt/openfoam30/src/OpenFOAM/lnInclude/tmpI.H:111:9: error: ‘class Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ has no member named ‘okToDelete’ if (ptr_->okToDelete()) ^ /opt/openfoam30/src/OpenFOAM/lnInclude/tmpI.H:118:13: error: ‘class Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ has no member named ‘operator--’ ptr_->operator--(); ^ /opt/openfoam30/src/OpenFOAM/lnInclude/tmpI.H: In instantiation of ‘T* Foam::tmp<T>::ptr() const [with T = Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >]’: /opt/openfoam30/src/OpenFOAM/lnInclude/PtrListI.H:140:47: required from ‘Foam::autoPtr<T> Foam::PtrList<T>::set(Foam::label, const Foam::tmp<T>&) [with T = Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >; Foam::label = int]’ createFields.H:241:31: required from here /opt/openfoam30/src/OpenFOAM/lnInclude/tmpI.H:162:10: error: ‘class Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ has no member named ‘resetRefCount’ ptr->resetRefCount(); ^ Cheers. |
June 29, 2016, 15:43 |
David Gaden
Rep Power: 22 |
Look at the VectorN library in foam-extend. It has been used specifically for nuclear reactions before. See Ivor Clifford's work.
~~~ Follow me on twitter @DavidGaden |
June 30, 2016, 06:27 |
Paul
Rep Power: 10 |
Thanks David - I'm actually modifying and gutting one of the descendants of Ivor Clifford's work, a coupled thermal-hydraulics, neutronics, mechanics code called GeN-Foam (although I'm only interested in the neutronics at the moment). I'm trying to stick quite close to its format in the hope of potentially being able to replace its neutronics solver with my own in the future, hence the use of PtrLists.
Unfortunately, it seems to be the case that its implementation of scattering isn't entirely compatible with the method I'm using (or, at least, it would be quite inefficient to use it). If I don't have any luck soon, however, then I'll definitely take a look at foam-extend. Cheers. |
June 30, 2016, 08:50 |
Paul
Rep Power: 10 |
Managed to get it working exactly as desired. More than anything the problem was getting the right syntax:
Info<<"sigmaS\n" << endl; PtrList<PtrList<volScalarField> > sigmaS(energyGroups); forAll(sigmaS, energyI) { sigmaS.set(energyI, new PtrList<volScalarField>(energyGroups)); forAll(sigmaS[energyI], energyJ) { sigmaS[energyI].set ( energyJ, new volScalarField ( IOobject ( "sigmaS"+Foam::name(energyI)+Foam::name(energyJ), runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensionedScalar("", dimensionSet(0,-1,0,0,0,0,0), 0.0), zeroGradientFvPatchScalarField::typeName ) ); } } |
July 6, 2016, 19:45 |
Jerry
Rep Power: 12 |
This is a very good example of using PtrList. I have a simpler question in this case, why do you choose PtrList<PtrList<>> instead of ListList<>? Is there any reason that we cann't use the normal list? |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 06:16 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
