Face IDs for cells at boundary patch
Like Tree2Likes
  • 2 Post By vigneshTG
Old   June 17, 2016, 18:56
Default Face IDs for cells at boundary patch
Praveen Srikanth
praveensrikanth91 is on a distinguished road
Hello Forum users,
I am working with the conjugate heat transfer solver where I am trying to find the temperature at a liquid vapor interface by interpolating the temperatures from the liquid and the gas regions and taking an average. I interpolate the temperatures with
surfaceScalarField TI_liquid = fvc::interpolate(liquidT);
surfaceScalarField TI_gas = fvc::interpolate(gasT);
but this does it for the entire region. I also know the cells next to the boundary which I get using the respective patchIDs
const labelList& gasPFaceCells = gasMesh_.boundary()[gasPatchID_].faceCells();
But I am not sure how to find the face IDs for the boundary faces for these cells which I can then use to get the interpolated temperature at the boundary. I have been going through this forum without much luck so any help is most appreciated
praveensrikanth91 is offline   Reply With Quote
Old   June 23, 2016, 08:13
Vignesh
vigneshTG is on a distinguished road
If you have not figured it out,
//To access the mesh information for the boundary
const polyPatch& cPatch = mesh.boundaryMesh()[patchI];
//Starting index of the face in a patch
label faceId_start = cPatch.start() ;
List of cells close to a boundary
const labelUList& faceCells = cPatch.faceCells();
forAll(cPatch, faceI)
// index of each face
label faceID = faceId_start +faceI;
//id of the owner cell having the face
label faceOwner = faceCells[faceI] ;
If there is a better way, do let me know !!
Noémie and Sayed Mostafa like this.
Thanks and Regards
Vignesh
vigneshTG is offline   Reply With Quote
Old   July 6, 2016, 12:55
Praveen Srikanth
Hey Vignesh,
Thank you so much for that. I did not realise that the face numbers on the patch were going to be continuous.
	const cell& gasFaces = gasMesh_.cells()[gasPfCellI];
	label gasfaceI = 0;
	forAll(gasFaces, i)
		label gasPatchI = gasMesh_.boundaryMesh().whichPatch(gasFaces[i]);
		if(gasPatchI == gasPatchID_)
			gasfaceI = gasFaces[i];
			Info<<"gasFaceI = "<< gasfaceI<<endl;
I used boundary().faceCells() on the boundary patches to get the cells on the boundary like you did. It seems to work fine as far as I can see. I will let you know if I find something wrong with it. Thanks again.
boundary cell, chtmultiregionfoam, conjugate heat transfer, face
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 7 September 18, 2024 06:52
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
