Implementing phase change in a heat transfer solver |
May 6, 2016, 10:32 |
I'm working on a heat transfer solver for incompressible flows. In particular, this solver must be able to take account of phase change. To do this I would like to compute the dryness by implementing this: If else and I have no idea how to implement the if condition in a way to go through each mesh cells. Does anyone know how to do so in OpenFOAM ? Thanks in advance Last edited by ThibautDer; May 9, 2016 at 07:21. |
May 9, 2016, 09:38 |
Kapa Lilla
Rep Power: 17 |
You can go through every volScalar/Vector/Tensor field as:
forAll(h, cellI) { if(h[cellI]<hSat) { T[cellI] = ...; } .... } This will loop over all the cells where h is defined, practically all the cells. Best, Lilla |
May 9, 2016, 09:49 |
Thank you !
May 9, 2016, 16:18 |
Zhiheng Wang
Rep Power: 10 |
Hi kapa Lilla
I could not get you " You can go through every volScalar/Vector/Tensor field as: forAll(h, cellI) { if(h[cellI]<hSat) { T[cellI] = ...; } .... } " Can you please elaborate a little ???? |
heat transfer, laminar flow, phase change |
How to simulate the flow and heat transfer of phase change materials? | rosol | FLUENT | 9 | April 10, 2016 15:22 |
Looking for a solver (Mach 0.4, Turbulent, Heat Transfer, Second Order) | fredo490 | OpenFOAM Running, Solving & CFD | 3 | March 27, 2013 05:07 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
what approach for direct mixing fluids with heat transfer and phase change? | hennas | Main CFD Forum | 0 | June 9, 2009 16:44 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 19:53 |
