Solved: "error: no matching function for call to ... <double,..> candidate is <Type>
Like Tree1Likes
  • 1 Post By banji
Old   April 21, 2016, 08:37
Default Solved: "error: no matching function for call to ... <double,..> candidate is <Type>
Olabanji
banji is on a distinguished road
Hi Foamers,
Recently, I was trying to compile a part of the OpenFOAM library for fast and easy profiling and error message below kept recurring
fvmwLaplacian.C: In function 'Foam::tmp<Foam::fvMatrix<Type> > Foam::fvmw::laplacianw(const Foam::GeometricField<GType, Foam::fvsPatchField, Foam::surfaceMesh>&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = double, GType = double]':
banola.C:70:32:   instantiated from here
fvmwLaplacian.C:131:70: error: no matching function for call to 'fvmLaplacianUncorrected(const Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&)'
fvmwLaplacian.C:131:70: note: candidate is:
fvmwLaplacian.C:45:26: note: template<class Type, class GType> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvmw::fvmLaplacianUncorrected(const surfaceScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
Spent some time on it and didn't believe what caused the problem. This is the reason why I thought I should share my solution path with whomever faces similar problem.
When you look into the fvmLaplacian.H file (see below)
namespace fvmw
    template<class Type, class GType> //Here is the problem :confused:
    tmp<fvMatrix<Type> > fvmLaplacianUncorrected
        const surfaceScalarField& gammaMagSf,
    const GeometricField<Type, fvPatchField, volMesh>&
All I did was change the template part of the snippet shown above to the new one below since I observed the extra "class GType" was kind of redundant (not used at all in the function.
namespace fvmw
    //template<class Type, class GType> //Here is the problem :confused:
    template<class Type>  //New
Hopefully this helped someone.
TeddyL likes this.
banji is offline   Reply With Quote
double, error, matching, type
Help with if statement CHARLES OpenFOAM Programming & Development 17 August 22, 2021 04:14
Error no matching function zoptirik OpenFOAM Programming & Development 3 January 24, 2018 10:11
[Commercial meshers] star-ccm mesh to O\/F DLC OpenFOAM Meshing & Mesh Conversion 77 September 19, 2016 10:25
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
