How to impose a boundary condition inside a solver
Like Tree2Likes
  • 1 Post By ssss
  • 1 Post By Democritus
Old   April 20, 2016, 03:51
Default How to impose a boundary condition inside a solver
Democritus's Avatar
Xiaoqiu HE
Democritus is on a distinguished road
Hi Dear Foamers~!
I am trying to test a program by prescribing the dirichlet BCs and source terms which are all calculated from the prescribed exact solution:
fvScalarMatrix p1SinEquation
    fvm::Sp(1, p1) + fvc::div(v)
); // v is already known
solve( p1SinEquation == p1SourceTerm )
//impose the source term
p1SourceTerm = p1_Exact + fvc::div(v);
//impose the BC
const fvBoundaryMesh & meshBoundary = mesh.boundary();
  forAll( meshBoundary, fvPatchID )
    const fvPatch & instantPatch = meshBoundary[ fvPatchID ];
    forAll( instantPatch, elmtID )
      p1.boundaryField()[fvPatchID][elmtID]
      p1_Exact.boundaryField()[fvPatchID][elmtID];
By this way I succecced in imposing the BC and source term, but after the calculation, the field p1's boundary value changes, which means that the fixed Dirichlet boundary conditions shifted. How to make it fixed firmly during all the program runtime?
I am open for all advices and thanks in advance!
Democritus is offline   Reply With Quote
Old   April 20, 2016, 05:43
anonymous
ssss is on a distinguished road
You could create a variable inside the solver and create a custom boundary conditions using swak4foam or codexFixed custom BC
Democritus likes this.
ssss is offline   Reply With Quote
Old   April 20, 2016, 07:10
Default Thank you for your reply!
Democritus's Avatar
Xiaoqiu HE
Thank you! I am trying my best to implement a new BC on the base of fixed value BC.
Old   April 20, 2016, 10:47
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Use swak4Foam and live gets so easy
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   April 27, 2016, 01:53
Zhiheng Wang
Zhiheng Wang is on a distinguished road
Hi Tobi,
I am facing problem to write grrovy BC while the Boundary Condition is coupled/mapped of 0/T and 0/U , can I write a coupled or mapped boundary I have tried by Code stream but it was a disaster.
U=(diff*(gradYi)/(1-Yi))
and
gradT= rho*U*Hf/kappa Can i write this with groovy BC for inlet ???
Zhiheng Wang is offline   Reply With Quote
Old   April 27, 2016, 04:29
Tobi's Avatar
Tobias Holzmann
Yes you can use values from other patches and also map stuff.
Keep foaming,
Tobias Holzmann
Old   April 28, 2016, 01:35
Zhiheng Wang
How to use map conditions ???? With groovy BC. I have no Idea about it.
Old   May 9, 2016, 04:59
Democritus's Avatar
Xiaoqiu HE
Hi Dear Foamers~
Here I want to share my solution about this issue. I only use OpenFOAM in order to impose a BC. The field I want to deal is pS, pC, vS, vC.
First I implemented codes for imposing the BC
    const fvBoundaryMesh & thisBoundary = mesh.boundary(); //here I get the boundary of the mesh
    forAll( thisBoundary, fvPatchID ) // go through all the patchs of the boundary
      const fvPatch & thisPatch = thisBoundary[ fvPatchID ];
      Info << "\n Imposing the boundary condition on the fvPatch of " <<
      thisPatch.name() << endl;
      const vectorField & position = thisPatch.Cf(); // get the cell face centers' positions
      forAll( thisPatch, elmtID ) // imposing values on the centers of all the cell faces of this patch
        const scalar & x = position[elmtID].component(0);
        const scalar & y = position[elmtID].component(1);
        //you can replace your function on the right side of the =
        pS.boundaryField()[fvPatchID][elmtID] = -1 * Foam::exp(-1 * x) * Foam::cos( x );
        pC.boundaryField()[fvPatchID][elmtID] = Foam::exp(-1 * x) * Foam::sin( x );
        vS.boundaryField()[fvPatchID][elmtID].component(0) = -1 * Foam::exp(-1 * x) * Foam::cos( x );
        vS.boundaryField()[fvPatchID][elmtID].component(1) = 2 * Foam::cos( x ) * Foam::sin( y ) ;
        vC.boundaryField()[fvPatchID][elmtID].component(0) = Foam::exp(-1 * x) * Foam::sin( x );
        vC.boundaryField()[fvPatchID][elmtID].component(1) = Foam::sin( x ) * Foam::cos( y );
Then I writed these fileds into files. In the files I changed the BC type from "calculated" to "fixedValue". Then I copy these files into the cases that I want to use it.
As old saying in China goes, "抛砖引玉", which means "showing a brick on the market in order to motivate others to show sapphire on the market", here I post my solution for dear foamers' reference and I am always open for any advice of improvement.
Thanks!
mostafa kareem likes this.
boudary condition, dirichlet
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
