LESModel type unknown in v3.0.1
Like Tree1Likes
  • 1 Post By liangshi
Old   April 1, 2016, 11:34
Default LESModel type unknown in v3.0.1
Liang Shi
liangshi is on a distinguished road
Hi OF users,
I implement a new LES model and successfully compiled with OF 3.0.1 (the files and options are attached below). The new LES model is wrapped into the library libuserincompressibleLESModels.so in the folder $(FOAM_USER_LIBBIN).
To test this model, I included in the controlDict a line like
libs("libuserincompressibleLESModels.so");
However, the pimpleFoam does not recognize this new model, telling me the unknown LESModel error.
(If I use the same configuration and use the build-in LES model, the case runs succusfully.)
Any ideas on the problem?
Thanks
Make/files:
newLESModel/newLESModel.C
LIB = $(FOAM_USER_LIBBIN)/libuserincompressibleLESModels
Make/options:
EXE_INC = \
-I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude
LIB_LIBS = \
-lfiniteVolume \
-lmeshTools
liangshi is offline   Reply With Quote
Old   April 5, 2016, 17:55
Liang Shi
I basically narrow down the problem to the addtoruntimeselection.
Since the version 3.0.x has a different structure for addtoruntimeselection which separates the implementation of basic LES models (e.g., smagorinsky) and addtoruntimeselection, the solver simply does not know the user-defined new model.
In v2.0.x, it is pretty straightforward, just adding these two lines to the implementation
defineTypeNameAndDebug(NEWMODEL,0)
addToRunTimeSelectionTable(LESModel, NEWMODEL, dictionary)
This does not work anymore in v3.0.x.
Any ideas to add the new model to the runtime selection table in v3.0.x?
Many thanks.
Old   April 8, 2016, 10:58
Default AddToRuntimeSelectionTable in OF 3.0.x
Liang Shi
Foam gurus,
How to add the user defined turbulence model to the runtime selection table in OF 3.0.x?
Any ideas or threads?
Many thanks.
Old   April 12, 2016, 17:26
Liang Shi
Solution:
creat a file named makeMyTurbulenceModels.C and compile the new model (newmodel.H) by compiling this file.
#include "IncompressibleTurbulenceModel.H" #include "incompressible/transportModel/transportModel.H" #include "addToRunTimeSelectionTable.H" #include "makeTurbulenceModel.H" #include "LESModel.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { typedef IncompressibleTurbulenceModel<transportModel> transportModelIncompressibleTurbulenceModel; typedef LESModel<transportModelIncompressibleTurbulenceModel> LEStransportModelIncompressibleTurbulenceModel; } #include "newmodel.H" makeTemplatedTurbulenceModel(transportModelIncompressibleTurbulenceModel,LES,newmodel);
Make/files
Make/options
EXE_INC = \
    -I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude/ \
    -I$(LIB_SRC)/transportModels \
LIB_LIBS = \
    -lincompressibleTurbulenceModels
Hope it is helpful.
guanjiang.chen likes this.
time step continuity problem in VAWT simulation lpz_michele OpenFOAM Running, Solving & CFD 5 February 22, 2018 20:50
Modified pimpleFoam solver to MRFPimpleFoam solver hiuluom OpenFOAM Programming & Development 12 June 14, 2015 22:22
Boundary Conditions MtnRunBeachBum OpenFOAM Pre-Processing 1 April 30, 2015 17:33
Strange high velocity in centrifugal pump simulation huangxianbei OpenFOAM Running, Solving & CFD 26 August 15, 2014 03:27
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
