Error compiling new turbulence model
Like Tree3Likes
  • 1 Post By hk318i
  • 1 Post By potentialFoam
  • 1 Post By Adlak
Old   March 30, 2016, 05:00
Default Error compiling new turbulence model
jasv is on a distinguished road
I'm trying to compile a new turbulence model (modified SpalartAllmaras) in openFOAM 3.0.1 and I'm having errors I don't know how to fix.
A minimal script of what I want to do just taking the original Spalart Allmaras model, renaming it and trying to compile is:
#!/bin/bash
# Copy original files
srcDIR=$FOAM_SRC"/TurbulenceModels/turbulenceModels/RAS/SpalartAllmaras"
ownDIR=$FOAM_USER_APPBIN"/sameSpalartAllmaras"
mkdir -p $ownDIR
cp $srcDIR/* $ownDIR
# Rename original 'SpalartAllmaras' to 'sameSpalartAllmaras' in files
sed -i s/SpalartAllmaras/sameSpalartAllmaras/g $ownDIR/*
mv $ownDIR/SpalartAllmaras.C $ownDIR/sameSpalartAllmaras.C
mv $ownDIR/SpalartAllmaras.H $ownDIR/sameSpalartAllmaras.H
mkdir $ownDIR/Make
# Create Make/options
cat <<EOF > $ownDIR/Make/options
EXE_INC = \\
    -I\$(LIB_SRC)/finiteVolume/lnInclude \\
    -I\$(LIB_SRC)/meshTools/lnInclude \\
    -I\$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude
LIB_LIBS = \\
    -lfiniteVolume \\
    -lmeshTools
EOF
# Create Make/files
cat <<EOF > $ownDIR/Make/files
EXE = \$(FOAM_USER_APPBIN)/sameSpalartAllmaras
LIB = \$(FOAM_USER_LIBBIN)/libmyincompressibleRASModels
EOF
# Compile
cd $ownDIR
wclean lib
wmake libso
When I try to compile I first get lot of warnings (#654, #1125)
In file included from /usr/.../openfoam/3.0.1/intel-openmpi/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/messageStream.H(216),
    /usr/.../openfoam/3.0.1/intel-openmpi/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/OSstream.H(52): warning #654: overloaded virtual function "Foam::Ostream::write" is only partially overridden in class "Foam::OSstream"
    /usr/.../openfoam/3.0.1/intel-openmpi/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/processorPolyPatch.H(112): warning #1125: function "Foam::PrimitivePatch<Face, FaceList, PointField, PointType>::movePoints(const Foam::Field<PointType> &) [with Face=Foam::face, FaceList=Foam::SubList, PointField=const Foam::pointField &, PointType=Foam::point]" is hidden by "Foam::processorPolyPatch::movePoints" -- virtual function override intended?
          void movePoints(PstreamBuffers&, const pointField&);
and then errors like
sameSpalartAllmaras.C(40): error: function "Foam::RASModels::sameSpalartAllmaras<BasicTurbulenceModel>::chi" has already been defined
  tmp<volScalarField> sameSpalartAllmaras<BasicTurbulenceModel>::chi() const
before the compilation is aborted.
I encounter similar errors when trying to compile other OF 3.0.x turbulence models (1, 2) posted on github by users of this forum.
Am I missing something very basic or are the Make/* files incomplete? Do you know where is the problem?
I posted this question as a reply to another thread with a similar topic some days ago. Let me know if I should delete it.
jasv is offline   Reply With Quote
Old   March 30, 2016, 12:03
Hassan Kassem
hk318i is on a distinguished road
First, both codes on Github are working fine. The only trick to compile first one is to modify the options to locate findroot function. The second one works fine using OpenFOAM-dev not OpenFOAM-3.0.
What is missing from your code is "makeMyCompressibleTurbulenceModel.C" and "makeMyIncompressibleTurbulenceModel.C" for compressible and incompressible flow. Try to use the same structure as on these codes.
It is just a macro, that's all.
Bw,
Hassan
hk318i is offline   Reply With Quote
Old   March 31, 2016, 06:21
Thanks! I've managed to make it work using the same structure as helio's code.
Do you know if there is any central repository with turbulence models implemented in OpenFOAM?
Old   March 31, 2016, 06:42
Hassan Kassem
You are welcome.
Sorry, Currently I'm working on FSI in inviscid flow and not following the new turbulence models. I was just curious about the new C++ implementation of turbulence models in new OF version.
Old   October 24, 2016, 10:36
Default SpalartAllmaras RC
Peter
potentialFoam is on a distinguished road
Dear Foamers,
I would like to create the SpalartAllmaras tubulence model with Rotation/Curvature Correction (SA-RC), see e.g. here:
https://turbmodels.larc.nasa.gov/spalart.html
in OF version 3.0.1.
Fortunately, H. Kassem shows here
http://hassankassem.me/posts/newturbulencemodel/
how to introduce new turbulence models for OF 3.0.x. Very great - thanks a lot!
Besides, I found the source code for the SA-RC model here
http://hobbyfoam.blogspot.de/2015/02...curvature.html
for OF version 2.3.0. Thanks also!!
If I merge both, I do not accomplish. Particularly, I am not sure how to introduce the correction function 'fr1' at the end of the '.C' file and the way how 'fr1' is calculated several lines above.
The error is strange.
1.) The compiler does not complain.
2.) Using the airFoil2D tutorial test case requires setting a divScheme in system/fvSchemes for Sxx (...)
3.) Using a 3D wing testcase leads to the following error type:
Foam::error::printStack(Foam::Ostream&)
Here, you find the code:
makeTurModel.C
SpalartAllmarasRC.H
SpalartAllmarasRC.C
The 'Make' directory contains:
files:
makeTurModel.C
LIB = $(FOAM_USER_LIBBIN)/libSpalartAllmarasRC
and options:
EXE_INC = \
    -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude \
    -I$(LIB_SRC)/transportModels/incompressible/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
LIB_LIBS = \
    -lturbulenceModels \
    -lincompressibleTurbulenceModels \
    -lincompressibleTransportModels \
    -lfiniteVolume \
    -lmeshTools
I will be quite glad if someone has an idea
potentialFoam is offline   Reply With Quote
Old   October 26, 2016, 11:53
Hassan Kassem
I am glad that my post helped you.
Regarding this error because it is not a compiler error, it is not easy to pinpoint the source of it without extensive testing. From my point of view, this code looks fine except lines 101 and 115 (.C file). These lines are dangerous because if W or S is zero, SqrW and SqrD will be zero as well. This could be the source of error but I don't know alot about W or S values, therefore I could be wrong about that.
Best Wishes,
Hassan Kassem
potentialFoam likes this.
@HIKassem | HassanKassem.me
Old   November 4, 2016, 08:29
Peter
@Hassan:
Thank you very much for watching my code!
This seemed to be the major error, as the model is running now. Nevertheless, a printStack-error occurs after some time. If I find a solution, I will upload the core here...
hk318i likes this.
Old   November 11, 2016, 07:48
Default turbulence model compilation erroe
Mukesh Adlak
Adlak is on a distinguished road
Originally Posted by hk318i View Post
Best Wishes,
Hassan Kassem
I am trying to compile my dynamicsmagorinsky model in openfoam 3.0.x but getting following error :
symbol lookup error: /home/adlak/OpenFOAM/adlak-3.0.x-cfdsupport/platforms/linux64Gcc49DPInt32Opt/lib/libdynamicSmagorinsky.so: undefined symbol: _ZNK4Foam9LESModels18dynamicSmagorinskyINS_15EddyD iffusivityINS_18ThermalDiffusivityINS_27Compressib leTurbulenceModelINS_11fluidThermoEEEEEEEE2CkEv
If any one can help then it will be a great help for me. I followed steps given here http://hassankassem.me/posts/newturbulencemodel/
Adlak is offline   Reply With Quote
Old   November 21, 2016, 17:14
Mohamed Elghorab
crazzy.pirate43 is on a distinguished road
Dear Adlak,
I'm new in openfoam and try also to implement my own turbulence model. I have many new parameters to add but I don't know how to define them inside the UEqn. for example, I have in my new UEqn. a vector C where:
C=x*y*z
where (x,y,z) are vectors so if you please can you help me in how I can define C in the same file of UEqn.??
Thanks in advance
crazzy.pirate43 is offline   Reply With Quote
Old   November 22, 2016, 04:41
Peter
I think you should not focus on UEqn.C, but rather watch a similar turbulence model (similar to the one you want to implement) and modify it.
As said already above, here
you find a good overview of how to do that.
Regards,
Peter
Old   November 22, 2016, 07:52
Mukesh Adlak
Originally Posted by crazzy.pirate43 View Post
Dear Adlak,
C=x*y*z
Thanks in advance
Dear crazzy.pirate43
I dont think u need to modify UEqn. If u want to modify then u should modify ur newturbulencemodel.c and .h file accordingly. And for compilation u can follow the steps given here
I am also trying to do that but not succeed at.
crazzy.pirate43 likes this.
Old   November 23, 2016, 11:38
Mohamed Elghorab
Thanks a lot for your quick reply. Now I will come back and search again in that way and I will tell you with the news
Old   December 5, 2016, 09:36
Mohamed Elghorab
Hi Adlak,
I think I did it but when I tried to run it I got some error message at t=550 sec like :
srun: Job step aborted: Waiting up to 5 seconds for job step to finish.
slurmstepd: error: *** STEP 222951.0 ON cnode57 CANCELLED AT 2016-12-04T13:42:26 DUE TO TIME LIMIT ***
I tried to google it but actually there is no specific way to pass this error, Do you have any comment on that and how to solve it??
Mohamed
Old   December 6, 2016, 05:13
Mukesh Adlak
Hi Adlak,
Mohamed
Might be this is the max time for which u can run ur job on cluster. Resubmit the job from latest time step.
Old   December 7, 2016, 09:44
Mohamed Elghorab
Hi adlak,
Thanks a lot I realized that it was due to the max. time for my job on the cluster.
Thanks again
Old   December 10, 2016, 05:20
Mukesh Adlak
Best Wishes,
Hassan Kassem
Hi hassan,
I am trying to compile dynamicLagrangian model but getting following error :
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libpthread.so.0"
#3 ? in "/lib/x86_64-linux-gnu/libm.so.6"
#4 pow in "/lib/x86_64-linux-gnu/libm.so.6"
#5 Foam:ow(Foam::Field<double>&, Foam::UList<double> const&, double const&) at ??:?
#6 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:ow<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::dimensioned<double> const&) at ??:?
#7 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:ow<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, double const&) at ??:?
#8 Foam::LESModels:LM<Foam::IncompressibleTurbulenc eModel<Foam::transportModel> >::correct() at ??:?
#9 ? at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? at ??:?
Floating point exception (core dumped)
can anyone help me ?
Old   February 8, 2017, 05:04
CHUNG Ching Chun
richard.chung.jones is on a distinguished road
Originally Posted by Adlak View Post
Hi hassan,
#9 ? at ??:?
#11 ? at ??:?
It is because you got something dividing by zero.
richard.chung.jones is offline   Reply With Quote
Old   February 26, 2017, 02:30
Bo Kong
huangfei is on a distinguished road
Hi hassan,
#9 ? at ??:?
#11 ? at ??:?
I am trying to compile the dynamicSmagorinsky model in version 4.0 post by AlbertoPa. But I get some errors:
dynamicSmagorinsky.C:155:6: error: ‘template<class BasicTurbulenceModel> class Foam::LESModels::dynamicSmagorinsky’ used without template parameters
bool dynamicSmagorinsky::read()
dynamicSmagorinsky.C: In function ‘bool Foam::LESModels::read()’:
dynamicSmagorinsky.C:159:9: error: ‘filter_’ was not declared in this scope
filter_.read(this->coeffDict());
dynamicSmagorinsky.C:159:22: error: invalid use of ‘this’ in non-member function
dynamicSmagorinsky.C: In member function ‘virtual void Foam::LESModels::dynamicSmagorinsky<BasicTurbulenc eModel>::correct(const Foam::tmp<Foam::GeometricField<Foam::Tensor<double >, Foam::fvPatchField, Foam::volMesh> >&)’:
dynamicSmagorinsky.C:180:16: error: ‘kMin_’ was not declared in this scope
bound(k_, kMin_);
dynamicSmagorinsky.C:180:21: error: there are no arguments to ‘bound’ that depend on a template parameter, so a declaration of ‘bound’ must be available [-fpermissive]
bound(k_, kMin_);
Do you know how to solve these problems?
Thanks~
huangfei is offline   Reply With Quote
Old   September 12, 2020, 07:36
Jiaui Zhang
charryzzz is on a distinguished road
bound(k_, kMin_);
bound(k_, kMin_);
Thanks~
You can add the head file #include "bound.H"
charryzzz is offline   Reply With Quote
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
