March 22, 2016, 15:26 |
Error in compiling new drag model
Kasra
Rep Power: 12 |
Hi every one,
I apply OF 211 third party on Ubuntu 1404. (for specific reasons) also there are 230(third party) and 240(deb pack) versions but deactivated in bashrc by #. I would like to create modification on "GidaspowErgunWenYu" model which applied in "twoPhaseEulerFoam" solver. I've tried ways, the best and complete one was on http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam for further sanitary I've decided to make a new solver based on which mentioned above but it faced to some problems about missing head files (or directory). finally by adding lines in twoPhaseEulerFoam/make/options files I could overcome. this suggestion taken from http://www.cfd-online.com/Forums/ope...ilation-2.html Code:
before correction it looked like EXE_INC = \ -I../bubbleFoam \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/transportModels/incompressible/lnInclude \ -IturbulenceModel \ -IkineticTheoryModels/lnInclude \ -IinterfacialModels/lnInclude \ -IphaseModel/lnInclude \ -Iaveraging EXE_LIBS = \ -lEulerianInterfacialModels \ -lfiniteVolume \ -lmeshTools \ -lincompressibleTransportModels \ -lphaseModel \ -lkineticTheoryModel Code:
EXE_INC = \ -I$(FOAM_SOLVERS)/multiphase/bubbleFoam \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/transportModels/incompressible/lnInclude \ -IturbulenceModel \ -IkineticTheoryModels/lnInclude \ -IinterfacialModels/lnInclude \ -IphaseModel/lnInclude \ -Iaveraging EXE_LIBS = \ -L$(FOAM_USER_LIBBIN) \ -lEulerianInterfacialModels \ -lfiniteVolume \ -lmeshTools \ -lincompressibleTransportModels \ -lphaseModel \ -lkineticTheoryModel \ Code:
SOURCE=dragModels/GidaspowErgunWenYu/GidaspowErgunWenYu.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I../phaseModel/lnInclude -I../interfacialModels/lnInclude -IlnInclude -I. -I/home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/GidaspowErgunWenYu.o In file included from dragModels/GidaspowErgunWenYu/GidaspowErgunWenYu.C:26:0: dragModels/GidaspowErgunWenYu/GidaspowErgunWenYu.H:39:23: fatal error: dragModel.H: No such file or directory #include "dragModel.H" ^ compilation terminated. make: *** [Make/linux64GccDPOpt/GidaspowErgunWenYu.o] Error 1 furthermore when I do Code:
ls $FOAM_USER_LIBBIN Code:
libEulerianInterfacialModels.so libkineticTheoryModel.so libphaseModel.so Last edited by k.farnagh; March 24, 2016 at 13:41. |
March 23, 2016, 12:47 |
How to set make/option file for calling dragModel.H
Kasra
Rep Power: 12 |
for compiling modified drag model, I confront with error below Code:
kasra@kasra-Lenovo-IdeaPad-Z510:~/Desktop/twoPhaseEulerFoamer/interfacialModels$ wmake SOURCE=dragModels/GidaspowErgunWenYu/GidaspowErgunWenYu.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I../phaseModel/lnInclude -I../interfacialModels/lnInclude -IlnInclude -I. -I/home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/GidaspowErgunWenYu.o In file included from dragModels/GidaspowErgunWenYu/GidaspowErgunWenYu.C:26:0: dragModels/GidaspowErgunWenYu/GidaspowErgunWenYu.H:39:23: fatal error: dragModel.H: No such file or directory #include "dragModel.H" ^ compilation terminated. make: *** [Make/linux64GccDPOpt/GidaspowErgunWenYu.o] Error 1 would you please guide me to this purpose? Last edited by k.farnagh; March 24, 2016 at 04:11. |
March 24, 2016, 10:24 |
Kasra
Rep Power: 12 |
after effortful process, I decided to use the option file that exists in twoPhaseEulerFoam/interfacialModels/make/ of OF240 for OF211. I could make modified solver with this trick before. but for creating modified drag model, terminated to Code:
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -I../phaseModel/lnInclude -IlnInclude -I. -I/home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/dragModel.o Make/linux64GccDPOpt/newDragModel.o Make/linux64GccDPOpt/GidaspowErgunWenYumod.o -L/home/kasra/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib \ -lOpenFOAM -ldl -lm -o OpenFOAM.out /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 0 has invalid symbol index 11 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 1 has invalid symbol index 12 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 2 has invalid symbol index 2 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 3 has invalid symbol index 2 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 4 has invalid symbol index 11 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 5 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 6 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 7 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 8 has invalid symbol index 12 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 9 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 10 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 11 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 12 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 13 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 14 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 15 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 16 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 17 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 18 has invalid symbol index 13 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_info): relocation 19 has invalid symbol index 21 /usr/bin/ld: /usr/lib/debug/usr/lib/x86_64-linux-gnu/crt1.o(.debug_line): relocation 0 has invalid symbol index 2 /usr/lib/gcc/x86_64-linux-gnu/4.8/../../../x86_64-linux-gnu/crt1.o: In function `_start': (.text+0x20): undefined reference to `main' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::fvPatchField<double>::New(Foam::word const&, Foam::word const&, Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&) [clone .constprop.103]': GidaspowErgunWenYumod.C:(.text+0x8bd): undefined reference to `Foam::fvPatchField<double>::debug' GidaspowErgunWenYumod.C:(.text+0x8ce): undefined reference to `Foam::fvPatchField<double>::patchConstructorTablePtr_' GidaspowErgunWenYumod.C:(.text+0xa96): undefined reference to `Foam::fvPatchField<double>::patchConstructorTablePtr_' GidaspowErgunWenYumod.C:(.text+0xb83): undefined reference to `Foam::fvPatchField<double>::patchConstructorTablePtr_' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::type() const': GidaspowErgunWenYumod.C:(.text._ZNK4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE4typeEv[_ZNK4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE4typeEv]+0x3): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::typeName' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::DimensionedField<double, Foam::volMesh>::type() const': GidaspowErgunWenYumod.C:(.text._ZNK4Foam16DimensionedFieldIdNS_7volMeshEE4typeEv[_ZNK4Foam16DimensionedFieldIdNS_7volMeshEE4typeEv]+0x3): undefined reference to `Foam::DimensionedField<double, Foam::volMesh>::typeName' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::fvPatchField<double>::type() const': GidaspowErgunWenYumod.C:(.text._ZNK4Foam12fvPatchFieldIdE4typeEv[_ZNK4Foam12fvPatchFieldIdE4typeEv]+0x3): undefined reference to `Foam::fvPatchField<double>::typeName' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryFieldC2ERKNS_16DimensionedFieldIdS2_EERKS4_[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryFieldC5ERKNS_16DimensionedFieldIdS2_EERKS4_]+0x49): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::debug' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC2ERKNS_3tmpIS3_EE[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC5ERKNS_3tmpIS3_EE]+0x156): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::debug' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC2ERKS3_[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC5ERKS3_]+0xda): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::debug' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::operator==(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEeqERKNS_3tmpIS3_EE[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEeqERKNS_3tmpIS3_EE]+0x2b): undefined reference to `Foam::fvMesh::operator!=(Foam::fvMesh const&) const' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::storeOldTime() const': GidaspowErgunWenYumod.C:(.text._ZNK4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE12storeOldTimeEv[_ZNK4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE12storeOldTimeEv]+0x1f): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::debug' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam12fvPatchFieldIdE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE[_ZN4Foam12fvPatchFieldIdE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE]+0x82): undefined reference to `Foam::fvPatchField<double>::debug' GidaspowErgunWenYumod.C:(.text._ZN4Foam12fvPatchFieldIdE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE[_ZN4Foam12fvPatchFieldIdE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE]+0xc1): undefined reference to `Foam::fvPatchField<double>::dictionaryConstructorTablePtr_' GidaspowErgunWenYumod.C:(.text._ZN4Foam12fvPatchFieldIdE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE[_ZN4Foam12fvPatchFieldIdE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE]+0x13e): undefined reference to `Foam::fvPatchField<double>::dictionaryConstructorTablePtr_' GidaspowErgunWenYumod.C:(.text._ZN4Foam12fvPatchFieldIdE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE[_ZN4Foam12fvPatchFieldIdE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE]+0x2f3): undefined reference to `Foam::fvPatchField<double>::disallowGenericFvPatchField' GidaspowErgunWenYumod.C:(.text._ZN4Foam12fvPatchFieldIdE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE[_ZN4Foam12fvPatchFieldIdE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE]+0x304): undefined reference to `Foam::fvPatchField<double>::dictionaryConstructorTablePtr_' GidaspowErgunWenYumod.C:(.text._ZN4Foam12fvPatchFieldIdE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE[_ZN4Foam12fvPatchFieldIdE3NewERKNS_7fvPatchERKNS_16DimensionedFieldIdNS_7volMeshEEERKNS_10dictionaryE]+0x3f7): undefined reference to `Foam::fvPatchField<double>::dictionaryConstructorTablePtr_' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryFieldC2ERKNS_14fvBoundaryMeshERKNS_16DimensionedFieldIdS2_EERKNS_10dictionaryE[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryFieldC5ERKNS_14fvBoundaryMeshERKNS_16DimensionedFieldIdS2_EERKNS_10dictionaryE]+0x50): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::debug' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::dictionary const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE9readFieldERKNS_10dictionaryE[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE9readFieldERKNS_10dictionaryE]+0x56): undefined reference to `Foam::fvMesh::boundary() const' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::word const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryFieldC2ERKNS_14fvBoundaryMeshERKNS_16DimensionedFieldIdS2_EERKNS_4wordE[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryFieldC5ERKNS_14fvBoundaryMeshERKNS_16DimensionedFieldIdS2_EERKNS_4wordE]+0x4b): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::debug' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::fvPatchField<double>::snGrad() const': GidaspowErgunWenYumod.C:(.text._ZNK4Foam12fvPatchFieldIdE6snGradEv[_ZNK4Foam12fvPatchFieldIdE6snGradEv]+0x1f): undefined reference to `Foam::fvPatch::deltaCoeffs() const' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::DimensionedField<double, Foam::volMesh>::readIfPresent(Foam::word const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam16DimensionedFieldIdNS_7volMeshEE13readIfPresentERKNS_4wordE[_ZN4Foam16DimensionedFieldIdNS_7volMeshEE13readIfPresentERKNS_4wordE]+0x1e): undefined reference to `Foam::DimensionedField<double, Foam::volMesh>::typeName' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readIfPresent()': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE13readIfPresentEv[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE13readIfPresentEv]+0xc6): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::typeName' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&, Foam::dimensionSet const&, Foam::word const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC2ERKNS_8IOobjectERKNS_6fvMeshERKNS_12dimensionSetERKNS_4wordE[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC5ERKNS_8IOobjectERKNS_6fvMeshERKNS_12dimensionSetERKNS_4wordE]+0xc8): undefined reference to `Foam::fvMesh::boundary() const' GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC2ERKNS_8IOobjectERKNS_6fvMeshERKNS_12dimensionSetERKNS_4wordE[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC5ERKNS_8IOobjectERKNS_6fvMeshERKNS_12dimensionSetERKNS_4wordE]+0xe4): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::debug' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator-<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&)': GidaspowErgunWenYumod.C:(.text._ZN4FoammiINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKNS_11dimensionedIdEERKS7_[_ZN4FoammiINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKNS_11dimensionedIdEERKS7_]+0x10d): undefined reference to `Foam::calculatedFvPatchField<double>::typeName' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam3powINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS7_RKNS_11dimensionedIdEE[_ZN4Foam3powINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS7_RKNS_11dimensionedIdEE]+0x109): undefined reference to `Foam::calculatedFvPatchField<double>::typeName' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::reuseTmpGeometricField<double, double, Foam::fvPatchField, Foam::volMesh>::New(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::word const&, Foam::dimensionSet const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam22reuseTmpGeometricFieldIddNS_12fvPatchFieldENS_7volMeshEE3NewERKNS_3tmpINS_14GeometricFieldIdS1_S2_EEEERKNS_4wordERKNS_12dimensionSetE[_ZN4Foam22reuseTmpGeometricFieldIddNS_12fvPatchFieldENS_7volMeshEE3NewERKNS_3tmpINS_14GeometricFieldIdS1_S2_EEEERKNS_4wordERKNS_12dimensionSetE]+0x6a): undefined reference to `Foam::calculatedFvPatchField<double>::typeName' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&)': GidaspowErgunWenYumod.C:(.text._ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS7_SA_[_ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS7_SA_]+0x11a): undefined reference to `Foam::calculatedFvPatchField<double>::typeName' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator*<double, Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&)': GidaspowErgunWenYumod.C:(.text._ZN4FoammlIdNS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIT_T0_T1_EEEERKNS_11dimensionedIdEERKS8_[_ZN4FoammlIdNS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIT_T0_T1_EEEERKNS_11dimensionedIdEERKS8_]+0x115): undefined reference to `Foam::calculatedFvPatchField<double>::typeName' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o:GidaspowErgunWenYumod.C:(.text._ZN4FoammlIdNS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIT_T0_T1_EEEERKS8_RKNS_11dimensionedIdEE[_ZN4FoammlIdNS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIT_T0_T1_EEEERKS8_RKNS_11dimensionedIdEE]+0x10e): more undefined references to `Foam::calculatedFvPatchField<double>::typeName' follow Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::word const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC2ERKNS_4wordERKS3_[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC5ERKNS_4wordERKS3_]+0x179): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::debug' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC2ERKNS_8IOobjectERKS3_[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC5ERKNS_8IOobjectERKS3_]+0xe1): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::debug' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readOldTimeIfPresent()': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE20readOldTimeIfPresentEv[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEE20readOldTimeIfPresentEv]+0x101): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::debug' Make/linux64GccDPOpt/GidaspowErgunWenYumod.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&)': GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC2ERKNS_8IOobjectERKNS_6fvMeshE[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC5ERKNS_8IOobjectERKNS_6fvMeshE]+0xab): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::typeName' GidaspowErgunWenYumod.C:(.text._ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC2ERKNS_8IOobjectERKNS_6fvMeshE[_ZN4Foam14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEC5ERKNS_8IOobjectERKNS_6fvMeshE]+0x1d0): undefined reference to `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::debug' collect2: error: ld returned 1 exit status make: *** [OpenFOAM.out] Error 1 kasra@kasra-Lenovo-IdeaPad-Z510:~/OpenFOAM/kasra-2.1.1/applications/solvers/twoPhaseEulerFoamm/interfacialModels$ |
March 26, 2016, 09:45 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Kasra,
I've merged your two threads on this topic. I need specific details in order to be able to help you:
Bruno
March 27, 2016, 06:34 |
Kasra
Rep Power: 12 |
Hi dear Bruno,
First of all Thanks for reply. Its better merged threads and I appreciate you. About first question, As there were not any specified way for installing source pack of 211 in Ubuntu 1404, I've followed below link steps for 1210. https://openfoamwiki.net/index.php/I...M-2.1.1/Ubuntu I must to say this manner terminated to some difficulties about setting environment (step 5 or Source). As I remember, something were lost or could not be found. Anyway, installation finished (maybe successfully). second one: twoPhaseEulerFoam has been copied from 211. I've just used option file contents of 240 for this new solver based on 211. and the last: if you want to know about main make/file it looks Code:
twoPhaseEulerFoamm.C EXE = $(FOAM_USER_APPBIN)/twoPhaseEulerFoamm and if you want to know about interfacialModel/make/file it looks Code:
dragModels/dragModel/dragModel.C dragModels/dragModel/newDragModel.C dragModels/Ergun/Ergun.C dragModels/GidaspowErgunWenYu/GidaspowErgunWenYu.C dragModels/GidaspowErgunWenYumod/GidaspowErgunWenYumod.C dragModels/GidaspowSchillerNaumann/GidaspowSchillerNaumann.C dragModels/SchillerNaumann/SchillerNaumann.C dragModels/Gibilaro/Gibilaro.C dragModels/WenYu/WenYu.C dragModels/SyamlalOBrien/SyamlalOBrien.C LIB = $(FOAM_USER_LIBBIN)/libEulerianInterfacialModels Sincerely Yours, Kasra |
March 27, 2016, 11:00 |
Bruno Santos
Rep Power: 128 |
Hi Kasra,
I've done the following steps, in order to make things work as intended:
I didn't understand why you wanted to use the "options" file from OpenFOAM 2.4.0... Best regards, Bruno |
March 28, 2016, 09:58 |
Kasra
Rep Power: 12 |
Hi dear Bruno,
I've received your modified folder and have put it in desktop. I've just done Code:
wclean all wmake all and just for peace of mind, If I want to add a new drag model same this one later on, is it ok to add it in dragModels and its address in "file" file then do wmake in interfacialModels location? An about your question I must to say there were not any specific force for doing that. As I haven't knowledge how to link or invoke header files, I just tried it as a solution but your solution is better definitely. I want to thank you for all the support and concern. Sincerely Yours, Kasra |
March 28, 2016, 12:02 |
#8 | |
Bruno Santos
Rep Power: 128 |
March 29, 2016, 04:26 |
#9 |
Kasra
Rep Power: 12 |
Dear Bruno, I cannot thank you enough for helping me.
March 30, 2016, 18:10 |
#10 |
Kasra
Rep Power: 12 |
Hi Dear Bruno,
I confront with these error when I want to wmake some modification on drag model. Code:
/home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:281:1: note: in expansion of macro ‘MAXMIN’ MAXMIN(long long, long long, long long) ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:265:16: note: no known conversion for argument 1 from ‘Foam::dimensioned<double>’ to ‘long long int’ inline retType max(const type1 s1, const type2 s2) \ ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:281:1: note: in expansion of macro ‘MAXMIN’ MAXMIN(long long, long long, long long) ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:265:16: note: long int Foam::max(long int, int) inline retType max(const type1 s1, const type2 s2) \ ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:280:1: note: in expansion of macro ‘MAXMIN’ MAXMIN(long, long, int) ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:265:16: note: no known conversion for argument 1 from ‘Foam::dimensioned<double>’ to ‘long int’ inline retType max(const type1 s1, const type2 s2) \ ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:280:1: note: in expansion of macro ‘MAXMIN’ MAXMIN(long, long, int) ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:265:16: note: long int Foam::max(long int, long int) inline retType max(const type1 s1, const type2 s2) \ ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:279:1: note: in expansion of macro ‘MAXMIN’ MAXMIN(long, long, long) ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:265:16: note: no known conversion for argument 1 from ‘Foam::dimensioned<double>’ to ‘long int’ inline retType max(const type1 s1, const type2 s2) \ ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:279:1: note: in expansion of macro ‘MAXMIN’ MAXMIN(long, long, long) ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:265:16: note: int Foam::max(int, int) inline retType max(const type1 s1, const type2 s2) \ ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:278:1: note: in expansion of macro ‘MAXMIN’ MAXMIN(int, int, int) ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:265:16: note: no known conversion for argument 1 from ‘Foam::dimensioned<double>’ to ‘int’ inline retType max(const type1 s1, const type2 s2) \ ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:278:1: note: in expansion of macro ‘MAXMIN’ MAXMIN(int, int, int) ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:265:16: note: short int Foam::max(short int, short int) inline retType max(const type1 s1, const type2 s2) \ ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:277:1: note: in expansion of macro ‘MAXMIN’ MAXMIN(short, short, short) ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:265:16: note: no known conversion for argument 1 from ‘Foam::dimensioned<double>’ to ‘short int’ inline retType max(const type1 s1, const type2 s2) \ ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:277:1: note: in expansion of macro ‘MAXMIN’ MAXMIN(short, short, short) ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:265:16: note: char Foam::max(char, char) inline retType max(const type1 s1, const type2 s2) \ ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:276:1: note: in expansion of macro ‘MAXMIN’ MAXMIN(char, char, char) ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:265:16: note: no known conversion for argument 1 from ‘Foam::dimensioned<double>’ to ‘char’ inline retType max(const type1 s1, const type2 s2) \ ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/label.H:276:1: note: in expansion of macro ‘MAXMIN’ MAXMIN(char, char, char) ^ make: *** [Make/linux64GccDPOpt/GidaspowErgunWenYuRich1989.o] Error 1 make: *** Waiting for unfinished jobs.... I've just done "wclean all","wmake all" within "interfacialModel" folder after some renaming and steps 4,5 mentioned. A lateral question is, may I omit addresses related to another drag models in "file" file for faster compiling? Would you please help me in this problem too? Attached file is drag model mentioned. Sincerely Yours, Kasra Last edited by k.farnagh; April 9, 2016 at 08:07. |
April 10, 2016, 16:54 |
#11 |
Bruno Santos
Rep Power: 128 |
Hi Kasra,
You can do the following in the file "interfacialModels/Make/files": Code:
dragModels/dragModel/dragModel.C dragModels/dragModel/newDragModel.C /* dragModels/Ergun/Ergun.C */ /* dragModels/GidaspowErgunWenYu/GidaspowErgunWenYu.C */ /* dragModels/GidaspowErgunWenYumod/GidaspowErgunWenYumod.C */ dragModels/GidaspowErgunWenYuRich1989/GidaspowErgunWenYuRich1989.C /* dragModels/GidaspowSchillerNaumann/GidaspowSchillerNaumann.C */ /* dragModels/SchillerNaumann/SchillerNaumann.C */ /* dragModels/Gibilaro/Gibilaro.C */ /* dragModels/WenYu/WenYu.C */ /* dragModels/SyamlalOBrien/SyamlalOBrien.C */ LIB = $(FOAM_USER_LIBBIN)/libEulerianInterfacialModelsMod OK, going into the details of the problem:
edit: For finding examples on how to use "dimensionedScalar": https://openfoamwiki.net/index.php/I...hing_for_files Best regards, Bruno
April 11, 2016, 05:40 |
#12 |
Kasra
Rep Power: 12 |
Hi dear friend, Bruno
Thanks for reply. you are the best. Ar is dimensionless like Re you know. so if I have called "g=9.81" from somewhere defined dimensionally I would not have seen this error in previous structure. is it true deduction? If you think this solution is acceptable too or worth mentioning, would you please explain how to invoke "g" from constant file of problem. edit: I've applied this drag model for a case and have seen: Code:
Create time Create mesh for time = 0 Reading g Reading transportProperties Calculating face flux field phia Calculating face flux field phib Reading field alpha Reading field p kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; alphak 1; alphaEps 0.76923; } wallFunctionCoeffs { kappa 0.41; E 9.8; } Reading field k Reading field epsilon Calculating field nutb Calculating field nuEffa Calculating field nuEffb Calculating field DDtUa and DDtUb Calculating field g.h Selecting dragModel for phase a: GidaspowErgunWenYuRich1989 Selecting dragModel for phase b: GidaspowErgunWenYuRich1989 dragPhase is a Selecting viscosityModel HrenyaSinclair Selecting conductivityModel Syamlal Selecting radialModel Gidaspow Selecting granularPressureModel Lun Selecting frictionalStressModel JohnsonJackson Courant Number mean: 0.000722971 max: 0.00329451 PIMPLE: Operating solver in PISO mode Starting time loop Reading/calculating field UaMean Reading/calculating field UbMean Reading/calculating field alphaMean Reading/calculating field pMean fieldAverage: starting averaging at time 0 Courant Number mean: 0.000722249 max: 0.00329122 Max Ur Courant Number = 0.00470174 deltaT = 9.99001e-05 Time = 9.99001e-05 DILUPBiCG: Solving for alpha, Initial residual = 1.30785e-05, Final residual = 2.50114e-21, No Iterations 1 Dispersed phase volume fraction = 0.241546 Min(alpha) = 0 Max(alpha) = 0.6 DILUPBiCG: Solving for alpha, Initial residual = 1.46833e-08, Final residual = 3.43305e-24, No Iterations 1 Dispersed phase volume fraction = 0.241546 Min(alpha) = 0 Max(alpha) = 0.6 --> FOAM FATAL ERROR: LHS and RHS of + have different dimensions dimensions : [0 0 0 0 0 0 0] + [0 -0.57 1.14 0 0 0 0] From function operator+(const dimensionSet&, const dimensionSet&) in file dimensionSet/dimensionSet.C at line 514. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::operator+(Foam::dimensionSet const&, Foam::dimensionSet const&) at ??:? #3 Foam::dimensioned<double> Foam::operator+<double>(Foam::dimensioned<double> const&, Foam::dimensioned<double> const&) at ??:? #4 Foam::operator+(double, Foam::dimensioned<double> const&) at ??:? #5 Foam::GidaspowErgunWenYuRich1989::K(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:? #6 at ??:? #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 at ??:? Aborted (core dumped) EDIT2: BTW I've done below changes and model has worked extremely . Code:
dimensionedScalar g ( "g", dimensionSet(0, 1, -2, 0, 0, 0 ,0), 9.81 ); dimensionedScalar ArUnlimited ( pow(phasea_.d(),3) * (phasea_.rho() - phaseb_.rho()) * phaseb_.rho() * g / pow(phaseb_.nu()*phaseb_.rho(),2) ); Sincerely Yours, Kasra Last edited by k.farnagh; April 20, 2016 at 05:27. |
April 18, 2016, 05:45 |
#13 |
Kasra
Rep Power: 12 |
There are something else beside my last post that I appreciate you guide me to solve them. I've done some modification on "SyamlalOBrien" drag model and it needed some coding. (Attached) First of all, I think this model like previous needs allocating dimension to some numbers that I've defined them as scalar wrongly. eg 0.1 is superficial velocity and has velocity dimension in fact. Also I'll be glad to know how to invoke this parameter from "0" file of problem here. Then there are some problems about manipulation of "if" code and defining sub parameters there are there (c and d. you can see in code). As I've not got any rules to utilize "if" code or combining several "if" together, it looks joke instead of code. So I'll be happy for any alternatives. This message appears during compilation (parts of end) Code:
/home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/VectorSpaceI.H:693:13: note: template<class Form, class Cmpt, int nCmpt> bool Foam::operator<=(const Foam::VectorSpace<Form, Cmpt, nCmpt>&, const Foam::VectorSpace<Form, Cmpt, nCmpt>&) inline bool operator<= ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/VectorSpaceI.H:693:13: note: template argument deduction/substitution failed: dragModels/SyamlalOBriendc/SyamlalOBriendc.C:103:29: note: ‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ is not derived from ‘const Foam::VectorSpace<Form, Cmpt, nCmpt>’ if (beta <= scalar(0.85)) ^ dragModels/SyamlalOBriendc/SyamlalOBriendc.C:108:15: error: no match for ‘operator>’ (operand types are ‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ and ‘double’) if (beta > scalar(0.85)) ^ dragModels/SyamlalOBriendc/SyamlalOBriendc.C:108:15: note: candidates are: In file included from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/UList.H:445:0, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/List.H:43, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/HashTable.C:30, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/Istream.H:184, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/token.H:452, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/UILListIO.C:28, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/UILList.C:92, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/UILList.H:285, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/ILList.H:39, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/IDLList.H:35, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/entry.H:45, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/dictionary.H:53, from lnInclude/dragModel.H:40, from dragModels/SyamlalOBriendc/SyamlalOBriendc.H:40, from dragModels/SyamlalOBriendc/SyamlalOBriendc.C:26: /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/UList.C:217:6: note: bool Foam::UList<T>::operator>(const Foam::UList<T>&) const [with T = double] bool Foam::UList<T>::operator>(const UList<T>& a) const ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/UList.C:217:6: note: no known conversion for argument 1 from ‘double’ to ‘const Foam::UList<double>&’ In file included from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/VectorSpace.H:164:0, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/dimensionedType.H:41, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/dimensionedScalar.H:38, from ../phaseModel/lnInclude/phaseModel.H:36, from lnInclude/dragModel.H:41, from dragModels/SyamlalOBriendc/SyamlalOBriendc.H:40, from dragModels/SyamlalOBriendc/SyamlalOBriendc.C:26: /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/VectorSpaceI.H:650:13: note: template<class Form, class Cmpt, int nCmpt> bool Foam::operator>(const Foam::VectorSpace<Form, Cmpt, nCmpt>&, const Foam::VectorSpace<Form, Cmpt, nCmpt>&) inline bool operator> ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/VectorSpaceI.H:650:13: note: template argument deduction/substitution failed: dragModels/SyamlalOBriendc/SyamlalOBriendc.C:108:28: note: ‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ is not derived from ‘const Foam::VectorSpace<Form, Cmpt, nCmpt>’ if (beta > scalar(0.85)) ^ In file included from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/dimensionedType.H:298:0, from /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/dimensionedScalar.H:38, from ../phaseModel/lnInclude/phaseModel.H:36, from lnInclude/dragModel.H:41, from dragModels/SyamlalOBriendc/SyamlalOBriendc.H:40, from dragModels/SyamlalOBriendc/SyamlalOBriendc.C:26: /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/dimensionedType.C:450:6: note: template<class Type> bool Foam::operator>(const Foam::dimensioned<Type>&, const Foam::dimensioned<Type>&) bool operator> ^ /home/kasra/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/dimensionedType.C:450:6: note: template argument deduction/substitution failed: dragModels/SyamlalOBriendc/SyamlalOBriendc.C:108:28: note: ‘Foam::volScalarField {aka Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>}’ is not derived from ‘const Foam::dimensioned<Type>’ if (beta > scalar(0.85)) ^ dragModels/SyamlalOBriendc/SyamlalOBriendc.C:116:27: error: ‘c’ was not declared in this scope neg(beta - 0.85)*(c*pow(beta, 1.28)) ^ dragModels/SyamlalOBriendc/SyamlalOBriendc.C:117:37: error: ‘d’ was not declared in this scope + pos(beta - 0.85)*(pow(beta, d)) ^ make: *** [Make/linux64GccDPOpt/SyamlalOBriendc.o] Error 1 make: *** Waiting for unfinished jobs.... I think Ur which is applied for Re is slip velocity and is updated at each moment (OF211). if it's true, I want to know about how I can formulize sub parameters exist in "kineticTheoryProperties" file in term of "Ur". Thank you. Sincerely Yours, Kasra Last edited by k.farnagh; April 24, 2016 at 09:52. |
May 21, 2016, 04:08 |
#14 |
Kasra
Rep Power: 12 |
please help me. I'm looking forward your guide. |
Induced drag, pressure drag, viscous drag. | aleix.de.toro | FLUENT | 2 | August 24, 2015 19:00 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Applying drag force in the fluid model | CanadaFlanker | CFX | 7 | May 6, 2014 00:13 |
multiphase model and drag law | Yasmail AKARIOUH | FLUENT | 0 | April 29, 2008 08:44 |
multiphase flow modelling, Drag model | Anant | CFX | 1 | February 4, 2008 05:18 |
