Minimal hacking to interFoam to add funny gravity
Like Tree1Likes
  • 1 Post By Phicau
Old   March 9, 2016, 17:08
Default Minimal hacking to interFoam to add funny gravity
Daniel Duque
dduque is on a distinguished road
I had this idea to model a Rayleigh-Taylor instability for the simplest possible case. I needed a funny gravity field that would pull up on one of the phases, and down on the other. I hacked the interFoam solver minimally, and I think I have got correct results. My first trial was actually succesful. UEqn.H was changed to:
    MRF.correctBoundaryVelocity(U);
    fvVectorMatrix UEqn
        fvm::ddt(rho, U) + fvm::div(rhoPhi, U)
      + MRF.DDt(rho, U)
      + turbulence->divDevRhoReff(rho, U)
        fvOptions(rho, U)
            // fake gravity field
            + (2*alpha1-1) * rho * g
    UEqn.relax();
    fvOptions.constrain(UEqn);
    if (pimple.momentumPredictor())
        solve
            UEqn
            fvc::reconstruct
                    mixture.surfaceTensionForce()
                  - ghf*fvc::snGrad(rho)
//                  - fvc::snGrad(p_rgh)
                  - fvc::snGrad(p)
              ) * mesh.magSf()
        fvOptions.correct(U);
Not much of a change, I introduce the funny gravity and make sure it's p, not p_rgh, the one whose gradient is evaluated.
But then I thought adding the gravity on the right-hand side of the equation would be more correct:
    fvVectorMatrix UEqn
      + MRF.DDt(rho, U)
        fvOptions(rho, U)
    UEqn.relax();
        solve
            UEqn
            fvc::reconstruct
                  - fvc::snGrad(p)
              ) * mesh.magSf()
Well, no, with the latter version the system does not evolve at all. I wonder why. More importantly, I wonder if I am doing the right thing. Results are ok, but they look somewhat squearish when compared with a Lagrangian (SPH-like) simulation
Thanks in advance for any help!
dduque is offline   Reply With Quote
Old   March 9, 2016, 21:54
Pablo Higuera
Phicau is on a distinguished road
Hi Daniel,
probably you have not switched on the momentum predictor in fvSolution, it is usually switched off by default.
Best,
Pablo
Phicau is offline   Reply With Quote
Old   March 10, 2016, 06:09
Daniel Duque
Originally Posted by Phicau View Post
Hi Daniel,
Best,
Pablo
Thanks, Pablo.
You are right, it would seem that " if (pimple.momentumPredictor()) " would require the momentum predictor step. However, I have tried enabling it and now the velocity seems to evolve ... but not the pressure, which does not change, or the color field.
Aside from " momentumPredictor yes;" at the PIMPLE section, I had to add the following to fvSolutions.
  UFinal
        $U;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-06;
        relTol          0;
What I don't get is, that equation contains the standard rho ( grad p + g ) term, so it should be solved no matter what. Right ??
[It's actually grad( p - rho g z ) + rho z grad(rho), but it's the same ]
Old   March 10, 2016, 08:12
Pablo Higuera
Hi again,
not really, you should always include it in the first one (to assemble the system of equations properly), and if you want a momentum predictor, also in the second equation.
Momentum predictor just solves an intermediate step and updates U. Then it applies that value to obtain the independent terms (explicit) and solve the PPE. Otherwise, the U used is the one from the beginning of the time step.
Best,
Pablo
dduque likes this.
Old   March 10, 2016, 09:03
Daniel Duque
Thanks, that seems to work. I find little difference with the previous results, but that may be ok. To check incompressibility, I am running foamCalc div phi, and the resulting field is between about -3e-4 and 3e-4. I guess that's small. Perhaps all this could go in another thread.
interfoam;ueqn, rayleigh-taylor
InterFoam: Add an equation to only one phase voingiappone OpenFOAM Programming & Development 41 June 7, 2022 10:04
InterFoam: add a source term in alpha eq. Alucard OpenFOAM Programming & Development 12 November 5, 2017 20:16
Add source term in alphaEqn.H of interFoam tayo OpenFOAM 1 October 23, 2013 04:40
how to add source-term in momentum equation for interFoam? anon_g OpenFOAM 9 October 18, 2011 13:47
add temperature equation to interFoam nygbook OpenFOAM Running, Solving & CFD 3 September 4, 2011 08:28
