What is "faceMomentum" in twoPhaseEulerFoam in OF 3.0.0
Like Tree5Likes
  • 2 Post By openfoammaofnepo
  • 1 Post By hillman860
  • 1 Post By GerhardHolzinger
  • 1 Post By fs82
Old   February 23, 2016, 17:10
Default What is "faceMomentum" in twoPhaseEulerFoam in OF 3.0.0
openfoammaofnepo is on a distinguished road
In the very latest openfoam e.g. 3.0.0, the multiphase solver folder has lots of update. In the twoPhaseEulerFoam solver, there are two sets of velocity and pressure source files, i.e. pU and pUf. In twoPhaseEulerFoam.C, they are chosed based on the switch "faceMomentum". I checked the source files for "pUf/UEqns.H" and "pU/UEqns.H". There are some differences, for instance, for the U equation, the time derivative term in pUf/UEqns.H is not considered. Could anybody familar this solver give some explanations about this? This is a little confused. Thank you.
lourencosm and Kummi like this.
openfoammaofnepo is offline   Reply With Quote
Old   March 4, 2016, 05:57
Default faceMomentum
Sankar
hillman860 is on a distinguished road
It is switch between face-based and cell-based formulation.
Have you seen the seen the comment in git?
https://github.com/OpenFOAM/OpenFOAM...777bb10a3e1dda
Kummi likes this.
hillman860 is offline   Reply With Quote
Old   March 4, 2016, 05:59
Dear Sankar,
I also saw that information last week. Thank you so much for your reply.
best regards,
OFFO
Old   March 7, 2016, 19:54
In the solver twoPhaseEulerFoam in OF300, we have the following two lines in createFields.H:
volScalarField& alpha1 = phase1;
volScalarField& alpha2 = phase2;
I think alpha1 and alpha2 are the phase volume fractions for dispersed and continuous phases. However, I did not find, for phase1 and phase2 can return the volume fraction. phase1 and phase2 are the objects of phaseModel, which are defined in twophaseSystem. But I did not find their forms that shows returning the volume fraction. Anybody knows about this issue? Thank you so much.
OFFO
Old   April 19, 2016, 11:34
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
The phase model class is derived, among others, from volScalarField. I.e. the phaseModel is a scalar field. Guess which one?
The constructor of phaseModel tells us more:
Foam::phaseModel::phaseModel
    const phaseSystem& fluid,
    const word& phaseName,
    const label index
    volScalarField
        IOobject
            IOobject::groupName("alpha", phaseName),
            fluid.mesh().time().timeName(),
            fluid.mesh(),
            IOobject::READ_IF_PRESENT,
            IOobject::AUTO_WRITE
        fluid.mesh(),
        dimensionedScalar("alpha", dimless, 0)
    fluid_(fluid),
    // and so on ...
Thus, the code you posted makes perfect sense.
Kummi likes this.
GerhardHolzinger is offline   Reply With Quote
Old   April 19, 2016, 16:11
    const label index
    volScalarField
        IOobject
            fluid.mesh(),
        fluid.mesh(),
    fluid_(fluid),
    // and so on ...
Dear Gerhard,
Thank you so much for your. clear now!
Old   January 6, 2017, 05:37
Dr. Fabian Schlegel
fs82 is on a distinguished road
The reason for faceMomentum is not always obvious, but sometimes, you might have seen some striping or oscillations in your phase velocities. The reason for that is not fully understood, but is very similar to the pressure oscillations which are damped by the RhieChow interpolation. faceMomentum extends this idea to damp the oscillations in the velocities for multiphase flows. However, it is experimental and the whole theory is not clear to me. The experimental status is, to my opinion, also the reason why you miss the time derivative. If you check the solver you will find in pEqn.H
surfaceScalarField alphaRhof10
    "alphaRhof10",
    fvc::interpolate
        max(alpha1.oldTime(), phase1.residualAlpha())
       *rho1.oldTime()
surfaceScalarField alphaRhof20
    "alphaRhof20",
    fvc::interpolate
        max(alpha2.oldTime(), phase2.residualAlpha())
       *rho2.oldTime()
and a little bit later this lines
surfaceScalarField rAUf1
    IOobject::groupName("rAUf", phase1.name()),
    1.0
        (alphaRhof10 + Vmf)/runTime.deltaT()
      + fvc::interpolate(U1Eqn.A())
      + Kdf
surfaceScalarField rAUf2
    IOobject::groupName("rAUf", phase2.name()),
    1.0
        (alphaRhof20 + Vmf)/runTime.deltaT()
      + fvc::interpolate(U2Eqn.A())
      + Kdf
and finally
    // Phase-1 predicted flux
    surfaceScalarField phiHbyA1
        IOobject::groupName("phiHbyA", phase1.name()),
        phi1
    phiHbyA1 =
        rAUf1
            (alphaRhof10 + Vmf)
           *MRF.absolute(phi1.oldTime())/runTime.deltaT()
          + fvc::flux(U1Eqn.H())
          + Vmf*ddtPhi2
          + Kdf*MRF.absolute(phi2)
          - Ff1()
    // Phase-2 predicted flux
    surfaceScalarField phiHbyA2
        IOobject::groupName("phiHbyA", phase2.name()),
        phi2
    phiHbyA2 =
        rAUf2
            (alphaRhof20 + Vmf)
           *MRF.absolute(phi2.oldTime())/runTime.deltaT()
          + fvc::flux(U2Eqn.H())
          + Vmf*ddtPhi1
          + Kdf*MRF.absolute(phi1)
          - Ff2()
I marked the lines which are needed for the time derivative bold. If you write this lines (Vmf is not needed, it represents the contribution of the virtual mass) on a paper and transfer it to an equation you will end up with the time derivative
(rho^n*alpha^n*U^(n+1) - rho^n*alpha^n*U^n)/dT
The first (implicit) term of the time derivative goes to rAUf and the second (explicit) one to phiHByA. This works for Euler forward, Euler backward and may be for CrankNicolson, but not for Euler backward second order (backward). Here you see the experimental status of the solver and the option in fvSchemes is not recognized by the solver.
If somebody argue this terms exists in a similar fashion also in the cellCentered version, than it might be right, but there are tiny but important differences
volScalarField rAU1
    IOobject::groupName("rAU", phase1.name()),
    1.0
        U1Eqn.A()
      + max(phase1.residualAlpha() - alpha1, scalar(0))
       *rho1/runTime.deltaT()
volScalarField rAU2
    IOobject::groupName("rAU", phase2.name()),
    1.0
        U2Eqn.A()
      + max(phase2.residualAlpha() - alpha2, scalar(0))
       *rho2/runTime.deltaT()
and
    volVectorField HbyA1
        IOobject::groupName("HbyA", phase1.name()),
        U1
    HbyA1 =
        rAU1
            U1Eqn.H()
           *rho1*U1.oldTime()/runTime.deltaT()
    volVectorField HbyA2
        IOobject::groupName("HbyA", phase2.name()),
        U2
    HbyA2 =
        rAU2
            U2Eqn.H()
           *rho2*U2.oldTime()/runTime.deltaT()
In the cellCentered version these terms are needed to avoid division by zero, or in other words zero equals zero in case a phase fraction gets zero. The important difference in the cellCentered Version is, that this term normally euqals zero (check the max condition) and only in the case of alpha < resisdualAlpha it gets larger than zero. In the faceMomentum version this term is always larger than zero. Hope this helps.
Best regards
Fabian
Kummi likes this.
fs82 is offline   Reply With Quote
Old   April 27, 2017, 12:14
In EEqns.H of reactingTwoPhaseEulerFoam solver, we have the following to update the thermodynamic properties:
fluid.correctThermo();
I am interested in looking at the source files of this function. So I checked the class of twoPhaseSystem.H and twoPhaseSystem.C, and actually this function can be found in phaseSystem.C, as follows:
void Foam::phaseSystem::correctThermo()
    forAll(phaseModels_, phasei)
        phaseModels_[phasei].correctThermo();
Here I am a little confused about phaseModels_, which is the object of the class :
        //- Phase models
        phaseModelList phaseModels_;
Now where can I find the function of correctThermo()? Anybody can give me some hints? Thank you so much in advance.
I am using OpenFOAM 3.0.1.
best regards, OFFO
Old   May 11, 2017, 07:27
For record:
template<class BasePhaseModel>
void Foam::MultiComponentPhaseModel<BasePhaseModel>::correctThermo()
    volScalarField Yt
        IOobject
            IOobject::groupName("Yt", this->name()),
            this->fluid().mesh().time().timeName(),
        this->fluid().mesh(),
        dimensionedScalar("zero", dimless, 0)
    PtrList<volScalarField>& Yi = Y();
    forAll(Yi, i)
        if (i != inertIndex_)
            Yt += Yi[i];
    if (inertIndex_ != -1)
        Yi[inertIndex_] = scalar(1) - Yt;
        Yi[inertIndex_].max(0);
    else
        forAll(Yi, i)
            Yi[i] /= Yt;
            Yi[i].max(0);
    BasePhaseModel::correctThermo();
Old   June 21, 2017, 20:06
In twoPhaseEulerFoam, I found that if I change "nAlphaCorr" for alpha.* in fvSolution file from 1 to 2 or any values > 1, then the computations crash. For my own case and for the tutorial /twoPhaseEulerFoam/RAS/fluidizedBed, this happens. Did you also have this similar problem? What causes this? Thanks!
Suppress twoPhaseEulerFoam energy AlmostSurelyRob OpenFOAM Running, Solving & CFD 33 September 25, 2018 18:45
twoPhaseEulerFoam: Exceeding iterations, residual = NaN Flyingcircus OpenFOAM Running, Solving & CFD 0 January 2, 2016 14:18
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 1 November 7, 2015 16:16
Is twoPhaseEulerFoam applicable to 3D cases / delivering erroneous results? ThomasV OpenFOAM 0 November 11, 2013 09:10
twoPhaseEulerFoam freemankofi OpenFOAM 0 May 23, 2011 17:24
