Difference between = and ==
Like Tree16Likes
  • 1 Post By manuc
  • 11 Post By marupio
  • 3 Post By manuc
  • 1 Post By elmo555
Old   February 22, 2016, 05:35
Default Difference between = and ==
Manu Chakkingal
manuc is on a distinguished road
Hello
I came across the usage of = and ==.
Does
= implies at calculating and assigning value of RHS to the LHS
== (initially assumed to be equality check operator), but found in cases where equations are solved and assigned similar to =
What is the exact difference /w the two and where it should be used in specific
Luttappy likes this.
manuc is offline   Reply With Quote
Old   February 22, 2016, 12:27
David Gaden
marupio is on a distinguished road
C++ allows operator overloading, which means that these operators could mean anything. A good design would be to keep it logical and consistent.
In OpenFOAM, we can use mathematical operators on GeometricFields, such as the velocity field. It makes sense that = means assignment, but OpenFOAM is very clever, and will apply the correct meaning to each of the boundary conditions on the field.
In the case of fixedValue, OpenFOAM will assume that you are doing routine physics calculations on your field... in these cases, we don't want to overwrite the fixedValue assigned at the start. So, U = A + B would do nothing to any of U's fixed value boundary conditions.
But there are situations where you do want to override the fixedValue. For instance, some boundary conditions use fixedValue as a base, but calculate a new value at every timestep. They need to override the value.
The design decision that was made is to use operator== for that. Kind of like a 'super assignment'. So for field variables, and the associated math, == is not a test... it is assignment.
In general, use operator= unless you are really certain you need to override any of the fixedValue.
hk318i, jherb, Saideep and 8 others like this.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   February 23, 2016, 06:57
Manu Chakkingal
Thank you for the reply ..
In short == is a forceful assignment at boundaries..while = leaves out the boundaries during assignment
Saideep, elmo555 and Kummi like this.
Old   October 11, 2017, 11:07
sibo
sibo is on a distinguished road
Hi David,
Thanks for your detailed explanation.
I want to create a dynamic mesh solver and the situation in my case is exactly the same as you mentioned.
I want to use fixedValue as a base for the wall's boundary condition and then give it a calculated displacement value to make it move every time step.
Therefore, I use this "==" operator. want to assign the calculated "dispVals" to "PointDisplacement".
PointDisplacement.boundaryField()[patchID] == dispVals;
But when I compile, i got the following error message:
error: no match for ‘operator==’ (operand types are ‘const Foam::pointPatchField<Foam::Vector<double> >’ and ‘Foam::vectorField {aka Foam::Field<Foam::Vector<double> >}’)
I have no idea why this error comes out, can you help me with this?
Any suggestion would be greatly appreciated!
Thanks!
sibo is offline   Reply With Quote
Old   January 18, 2018, 11:46
Lennart
elmo555 is on a distinguished road
Thanks!
You'll probably need to use boundaryFieldRef() instead of boundaryField(), because boundaryField() returns a const, and you're trying to write into the field:
PointDisplacement.boundaryFieldRef()[patchID] == dispVals;
Michael@UW likes this.
elmo555 is offline   Reply With Quote
