conjugateHeatFoam solver with evaporation and condensation |
February 13, 2016, 08:17 |
Hesam
Rep Power: 11 |
Hi friends,
I develope interPhaseChangeFoam+conjugateHeatFoam solvers for simulation of temperature base evaporation and condensation with conjugate heat transfer ,But in my case cooling rate of hot piece is very high and piece cooling down rapidly .I don't know reason of this problem.another problem is that without any limiter,vapor temperature increase to temperature of piece that is not correct. Can anyone Help me to correct my problems? Thank you. Solver and Case are attached: case: http://s6.picofile.com/file/82386473...ce_tar.gz.html solver: |
April 27, 2016, 20:44 |
Shyam Sunder
Rep Power: 11 |
Which version of OpenFOAM you are using?
April 28, 2016, 02:18 |
Hesam
Rep Power: 11 |
Hi Shyam,
OpenFOAM 16ext |
February 25, 2020, 00:15 |
#4 | |
Ilhwan Yeo
Rep Power: 6 |
I want to simulate the channel flow with conjugate heat transfer that has evaporation and condensation. Could you give me the case file? This is my email address. sorry I found your case Laye. thanks Thanks. |
March 15, 2021, 07:36 |
conjugate heat transfer + mulitphase
#5 | |
John Kim
Rep Power: 5 |
I have a question for you. I found out that there is interthermalphasechangefoam which is about two phase flow with evap and cond. However, I am failing to apply conjugate heat transfer problem. Can you give me some help? Is there another code that can solve this problem? Nevermind. I found the solver. Sorry for interrupting you |
condensation, conjugate heat trans., evaporation, evaporation-condensation, two phase flow |
Evaporation and condensation model in VOF | ic3lemon | Fluent Multiphase | 0 | December 12, 2015 07:56 |
Evaporation & condensation in 2D Heat Exchanger | Somnath rangrej | Main CFD Forum | 0 | December 8, 2015 12:25 |
Evaporation and condensation Model in Fluent | amy24d | Fluent Multiphase | 5 | May 26, 2015 13:20 |
Evaporation & Condensation model | Amit | FLUENT | 0 | September 7, 2012 07:53 |
Water Evaporation and condensation modeling | Linjie | FLUENT | 3 | February 6, 2012 14:08 |
