setting a Constant Inlet flow - Interfoam
Like Tree1Likes
  • 1 Post By bdh1103
Old   February 10, 2016, 16:20
Default setting a Constant Inlet flow - Interfoam
Bradley
bdh1103 is on a distinguished road
Hello.
I am trying to modify a case of Interfoam to include real world geometry with a constant inlet flow rate.
For a basis, I started with this case: https://www.youtube.com/watch?v=1zQbU-E4k1U
I am able to replicate the box to cell case for any configuration using a step file and Salome. However, I can not figure out how to set a constant inlet flow instead of box to cell. Here is an example of the constant flow I'm trying to create: https://www.youtube.com/watch?v=0K2QBjFS5VM
In addition to alpha.water, I would like for the simulation to show the velocity of the fluid.
Please let me know if I have left any relevant information out. This is my first time using the CFD forums.
My relevant code is below
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object setFieldsDict;
defaultFieldValues
volScalarFieldValue alpha.water 0
regions
boxToCell
box (0 -0.12 0.195) (0.05 0.03 0.23);
fieldValues
volScalarFieldValue alpha.water 1
__________________________________________________ ____________________
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
wall
type fixedValue;
value uniform (0 0 0);
inlet
type pressureInletOutletVelocity;
value uniform (0 0 -1);
outlet
FoamFile
version 2.0;
format ascii;
class volScalarField;
object alpha.water;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
wall
type zeroGradient;
outlet
type inletOutlet;
inletValue uniform 0;
value uniform 0;
inlet
type inletOutlet;
value uniform 0;
Bashar likes this.
bdh1103 is offline   Reply With Quote
Old   February 12, 2016, 01:41
Hesam
rapierrz is on a distinguished road
Hi Bradley,
For inlet you can assign alpha=1 to inlet water:
inlet
type fixedValue;
value uniform 1;
rapierrz is offline   Reply With Quote
Old   February 12, 2016, 13:51
Bradley
Thank you very much for your time and willingness to help. Unfortunately, setting alpha equal to 1 for the inlet doesn't quite work. It creates a thin layer of liquid where my inlet is located (at t=0) and then immediately falls. It doesn't form a continuous flow.
Old   February 12, 2016, 16:24
Smile
Hesam
In this case alpha1 distribution depend on your velocity at inlet.
In my case,I assign a fixed value to alpha at inlet(alpha=1 or water) and
assign alpha=0 (or air) to internal field.after 1 second water fill the whole of
the domain.
Old   February 15, 2016, 14:16
Bradley
Again, I am very new to OpenFOAM so I am extremely grateful for all suggestions and I thank you. Unfortunately, It still does not seem to be working, even when the suggested code is copied and pasted directly. I've attached two files to demonstrate my issue. The inlet patch is red, giving an alpha=1 as desired at time=0. However, in the next time frame, the figure remains exactly the same. The liquid does not seem to be flowing.
In addition, interFoam is having a hard time solving the problem now. It must use a time step around the magnitude of E-26. I'm not sure what could have caused such a drastic change.
Old   February 15, 2016, 18:41
Wouter van der Meer
wouter is on a distinguished road
Hello bdh1103,
I think you missed setFields command to start the volume of liquid.
edit:
sorry misread your first item.
Your problem is probably that at time zero there is a big change, because you do not start with a stable situation. I think you need to make the influent first going up, so it can fill with liquid or you must first fill the top box with liquid (setFields) and than start with a flow from the top.
Hope that helps,
Wouter
wouter is offline   Reply With Quote
Old   February 15, 2016, 18:45
Bradley
Hello wouter,
Thank you for your input and suggestion. I actually left the box to cell coordinates in the code but gave the dimensions (0 0 0) (0 0 0) so I could isolate the effect of only the inlet stream (or at least the one I'm trying to create).
If you have any other recommendations, please do not hesitate to put them.
I've searched for weeks for a solution to this problem.
Old   February 16, 2016, 09:12
Paulo Vatavuk
vatavuk is on a distinguished road
Hi Bradley,
I don't know why, but this kind of inlet condition that you are trying to use, don't work with interFoam version 2.3 and all newer versions. I was trying to solve a similar case and wasn't able to get convergence with this inlet condition.
If you look at the weirOverflow tutorial you'll notice that the inlet is done through variableHeightFlowRateInletVelocity for U and variableHeightFlowRate for alpha.water. Using this kind of inlet I was able to converge the simulations. So, I suggest that you try it.
Another solution would be using an older version, like 2.2, to do the simulation.
Best Regards,
Paulo
vatavuk is offline   Reply With Quote
Old   February 17, 2016, 14:37
Default Update
Bradley
First, I would like to thank you, Paulo. This answer makes sense.
I'm attempting to implement your suggestion but I am having a little difficulty. perhaps you could be of assistance.
Here is the current relevant code (error message displayed at the end).
__________________________________________________ _______________________
| \\ / O peration | Version: 3.0.1 |
FoamFile
version 2.0;
format ascii;
location "0";
object alpha.water;
boundaryField
wall
type zeroGradient;
inlet
type variableHeightFlowRate;
lowerBound 1; // I have also tried setting this to 0.
upperBound 1;
value uniform 1;
outlet
type inletOutlet;
value uniform 0;
FoamFile
version 2.0;
format ascii;
location "0";
object U;
#include "include/initialConditions"
boundaryField
wall
type fixedValue;
inlet
type variableHeightFlowRateInletVelocity;
flowRate $inletFlowRate;
alpha alpha.water;
outlet
inletFlowRate 75;
#inputMode merge
__________________________________________________ ________________________
Here is the error code after setFields-->decompPar-->mpirun -n 8 interFoam -parallel
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.001
Time = 0.001
PIMPLE: iteration 1
smoothSolver: Solving for alpha.water, Initial residual = 0, Final residual = 0, No Iterations 0
Phase-1 volume fraction = 0 Min(alpha.water) = 0 Max(alpha.water) = 0
MULES: Correcting alpha.water
[4] #0 Foam::error:rintStack(Foam::Ostream&)[5] [6] #0 Foam::error:rintStack(Foam::Ostream&)[7] #0 Foam::error:rintStack(Foam::Ostream&)[0] #0 Foam::error:rintStack(Foam::Ostream&)[1] #[2] #0 Foam::error:rintStack(Foam::Ostream&)[3] #0 Foam::error:rintStack(Foam::Ostream&)0 #0Foam::error:rintStack(Foam::Ostream&) Foam::error:rintStack(Foam::Ostream&) at ??:?
[0] #1 Foam::sigFpe::sigHandler(int) at ??:?
[6] #1 Foam::sigFpe::sigHandler(int) at ??:?
[3] #1 Foam::sigFpe::sigHandler(int) at ??:?
[2] #1 Foam::sigFpe::sigHandler(int) at ??:?
[4] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #1 Foam::sigFpe::sigHandler(int) at ??:?
[5] #1 Foam::sigFpe::sigHandler(int) at ??:?
[0] #2 ? at ??:?
[7] #1 Foam::sigFpe::sigHandler(int) at ??:?
[2] #2 ? at ??:?
[6] #2 ? at ??:?
[1] #2 ? at ??:?
[3] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3 Foam::variableHeightFlowRateInletVelocityFvPatchVe ctorField::updateCoeffs() at ??:?
[5] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
[4] #2 ?[2] #3 Foam::variableHeightFlowRateInletVelocityFvPatchVe ctorField::updateCoeffs() in "/lib/x86_64-linux-gnu/libc.so.6"
[6] #3 Foam::variableHeightFlowRateInletVelocityFvPatchVe ctorField::updateCoeffs() in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3 Foam::variableHeightFlowRateInletVelocityFvPatchVe ctorField::updateCoeffs() in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #3 Foam::variableHeightFlowRateInletVelocityFvPatchVe ctorField::updateCoeffs() at ??:?
[7] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
... this goes on for awhile....
[ubuntu:03518] *** Process received signal ***
[ubuntu:03518] Signal: Floating point exception (8)
[ubuntu:03518] Signal code: (-6)
[ubuntu:03518] Failing at address: 0x3e800000dbe
[ubuntu:03518] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36d40) [0x7f05147b8d40]
[ubuntu:03518] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7f05147b8cc9]
[ubuntu:03518] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36d40) [0x7f05147b8d40]
[ubuntu:03518] [ 3] /opt/openfoam30/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam53variableHeightFlowRat eInletVelocityFvPatchVectorField12updateCoeffsEv+0 x384) [0x7f0517812d94]
[ubuntu:03518] [ 4] interFoam(_ZN4Foam14GeometricFieldINS_6VectorIdEEN S_12fvPatchFieldENS_7volMeshEE22GeometricBoundaryF ield12updateCoeffsEv+0x3d) [0x455b7d]
[ubuntu:03518] [ 5] interFoam(_ZN4Foam8fvMatrixINS_6VectorIdEEEC1ERKNS _14GeometricFieldIS2_NS_12fvPatchFieldENS_7volMesh EEERKNS_12dimensionSetE+0x229) [0x45f569]
[ubuntu:03518] [ 6] interFoam() [0x45f6bb]
[ubuntu:03518] [ 7] interFoam() [0x431e9e]
[ubuntu:03518] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f05147a3ec5]
[ubuntu:03518] [ 9] interFoam() [0x4382e0]
[ubuntu:03518] *** End of error message ***
mpirun noticed that process rank 2 with PID 3513 on node ubuntu exited on signal 8 (Floating point exception).
I've also tried modifying the weirOverflow tutorial itself to no avail.
Old   February 24, 2016, 15:38
Bradley
UPDATE:
I have tried to alter the weirflow tutorial as well as the water channel tutorial. I can not get
either case to work.
Old   March 6, 2016, 10:29
Paulo Vatavuk
An update of my post above:
Recently I sent a bug report about the inlet conditions for interfoam.
See the report in this link http://www.openfoam.org/mantisbt/view.php?id=2013
As explained by Henry, the problem was related to the condition in
p_rgh and not in the conditions for U and alpha, as I tought.
So it's possible to create an inlet condition, for version 2.3 and newer, as long as you use the correct boundary conditon for p_rgh which is fixedFluxPressure.
Best regards,
Paulo
constant, flow, geometry, interfoam, real
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Two Mass flow inlet bc convergence problem nabidinhomessi Main CFD Forum 5 December 14, 2015 08:11
Multiphase Flow BC-Mass Flow inlet not available? yimingchen.ok@gmail.com Siemens 1 July 18, 2014 07:08
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 15:03
