Sigfpe and ihDyMFoam
Like Tree2Likes
  • 1 Post By martinsimon
  • 1 Post By Phicau
Old   January 26, 2016, 10:35
Default Sigfpe and ihDyMFoam
Martin Simon
martinsimon is on a distinguished road
Greetings foamers!
I am a beginner in CFD and this is my first post here.
I apologize in advance:
I am not sure whether this is a repost or not, because I have found similar problems in this forum, but not (at least understood ) the answer.
The problem (I have attached the 0.org):
I am combining interDyMFoam tutorial case floatingObject with ihFoam tutorial case irreg45degTank using ihDyMFoam to simulate a cuboid in waves.
The simulation runs fine for first 3 minutes, but then I get the following error:
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#7 ? at ??:?
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? at ??:?
Floating point exception (core dumped)
I understand that this indicates there is something wrong with physics (dividing by zero), but as far as I can't get my head around where the problem could be.
Thank You in advance!
Martin Simon
benedip likes this.
martinsimon is offline   Reply With Quote
Old   January 27, 2016, 04:54
Pablo Higuera
Phicau is on a distinguished road
Hi Martin,
the eternal problem with interDyMFoam: it gets pressure instabilities and blows up. You should check whether this problem has been caused by a very deformed mesh or just by the solver parameters themselves.
Best,
Pablo
benedip likes this.
Phicau is offline   Reply With Quote
Old   September 21, 2016, 11:01
Default IHDyMFoam for floatingObject
Benedetto Di Paolo
benedip is on a distinguished road
I have a problem with this simulation. I modified floatingObject tutorial in OF2.4 and I used ihFoam for waves generation. I link simulation folder and a video that shows the problem around the floating body. I think that it is due to mesh instability and the problem is with 6DoF in dynamicMeshDict. Do you have any suggestions?
benedip is offline   Reply With Quote
6-dof, floating body, ihdymfoam, waves
