How does the non-blocking communication overlap computation with communication?
Like Tree2Likes
  • 2 Post By zhulianhua
Old   December 23, 2015, 11:59
Default How does the non-blocking communication overlap computation with communication?
Lianhua Zhu
zhulianhua is on a distinguished road
I'm investigating the parallel mechanism of OpenFOAM.
I found the following code snippets that doing the message passing job.
// Correct the boundary conditions
template<class Type, template<class> class PatchField, class GeoMesh>
void Foam::GeometricField<Type, PatchField, GeoMesh>::
correctBoundaryConditions()
    this->setUpToDate();
    storeOldTimes();
    boundaryField_.evaluate();
void Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::
evaluate()
    if (debug)
        Info<< "GeometricField<Type, PatchField, GeoMesh>::"
               "GeometricBoundaryField::"
               "evaluate()" << endl;
    if
        Pstream::defaultCommsType == Pstream::blocking
     || Pstream::defaultCommsType == Pstream::nonBlocking
        label nReq = Pstream::nRequests();
        forAll(*this, patchi)//Process each boundary patch
            this->operator[](patchi).initEvaluate(Pstream::defaultCommsType);
        // Block for any outstanding requests
        if
            Pstream::parRun()
         && Pstream::defaultCommsType == Pstream::nonBlocking
            Pstream::waitRequests(nReq);
            this->operator[](patchi).evaluate(Pstream::defaultCommsType);
    else if (Pstream::defaultCommsType == Pstream::scheduled)
        const lduSchedule& patchSchedule =
            bmesh_.mesh().globalData().patchSchedule();
        forAll(patchSchedule, patchEvali)
            if (patchSchedule[patchEvali].init)
                this->operator[](patchSchedule[patchEvali].patch)
                    .initEvaluate(Pstream::scheduled);
            else
                    .evaluate(Pstream::scheduled);
    else
        FatalErrorIn("GeometricBoundaryField::evaluate()")
            << "Unsuported communications type "
            << Pstream::commsTypeNames[Pstream::defaultCommsType]
            << exit(FatalError);
template<class Type>
void Foam::processorFvPatchField<Type>::initEvaluate
    const Pstream::commsTypes commsType
    if (Pstream::parRun())
        this->patchInternalField(sendBuf_);
        if (commsType == Pstream::nonBlocking && !Pstream::floatTransfer)//?
            // Fast path. Receive into *this
            this->setSize(sendBuf_.size());
            outstandingRecvRequest_ = UPstream::nRequests();
            UIPstream::read
                Pstream::nonBlocking,
                procPatch_.neighbProcNo(),
                reinterpret_cast<char*>(this->begin()),
                this->byteSize(),
                procPatch_.tag(),
                procPatch_.comm()
            outstandingSendRequest_ = UPstream::nRequests();
            UOPstream::write
                reinterpret_cast<const char*>(sendBuf_.begin()),
                this->byteSize(),
                procPatch_.tag(),
                procPatch_.comm()
        else
            procPatch_.compressedSend(commsType, sendBuf_);
void Foam::processorFvPatchField<Type>::evaluate
            // Fast path. Received into *this
            if
                outstandingRecvRequest_ >= 0
             && outstandingRecvRequest_ < Pstream::nRequests()
                UPstream::waitRequest(outstandingRecvRequest_);
            outstandingSendRequest_ = -1;
            outstandingRecvRequest_ = -1;
        else
            procPatch_.compressedReceive<Type>(commsType, *this);//直接接收
        if (doTransform())
            transform(*this, procPatch_.forwardT(), *this);
We can see, if using non-blocking communication, the Pstream::waitRequests() is executed between this->operator[](patchi).initEvaluate() and this->operator[](patchi).evaluate(), nothing else!
For non-blocking communication, processorFvPatchField::initEvaluate() prepares to send/recv, and processorFvPatchField::evaluate() checks the commnication is done.
I thought the bulk internal field operations should been put between the processorFvPatchField::initEvaluate() and the processorFvPatchField::evaluate() to "overlap the computation with commnication" ? What's wrong with my interpretation of the OpenFOAM codes?
Thanks.
Lianhua
qjh888 and scleakey like this.
zhulianhua is offline   Reply With Quote
Old   October 19, 2016, 22:00
Janry
qjh888 is on a distinguished road
Hi There,
I've just going deep to this piece of code.
And currently, my code dosen't work for parallel.
After adding some debug flags, I'm coming to this piece of code.
Do you have some progress of that?
Would you mind to share your experience?
Thanks!
Janry
qjh888 is offline   Reply With Quote
parallel computation
redistributeMeshPar with scotch fails matteoL OpenFOAM Pre-Processing 0 March 30, 2015 12:13
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 04:13
problem in the CFX12.1 parallel computation BalanceChen ANSYS 2 July 7, 2011 11:26
