Unsteady state calculation including porous media
Like Tree1Likes
  • 1 Post By KeiJun
Old   December 11, 2015, 03:42
Default Unsteady state calculation including porous media
KeiJun is on a distinguished road
Dear Sir,
I am going to calculate the unsteady state calculation including porous media using "pimpleFoam" solver.
Can I do it by system/fvOptions file, in which I construct porous regions?
And then, which should I use "explicitPorosity Source" or "interRegionExplicitPorositySource"?
And if able to do, in case of the steady state, can I calculate porous media not using "porousSimpleFoam" solver but "simpleFoam" solver & fvOptions file?
KeiJun
Gang Wang likes this.
KeiJun is offline   Reply With Quote
Old   December 11, 2015, 09:45
Default stick with pimpleFoam and simpleFoam
Fabian Roesler
fabian_roesler is on a distinguished road
you can use fvOptions with pimpleFoam and simpleFoam. As you ony have one region solved by those solvers you have to use explicitPorositySource for singe region cases.
porous SimpleFoam is an old solver with directly implemented capability to solve for porosity regions. I'd recommend to stick with pimpleFoam and simpleFoam.
Cheers
Fabian
fabian_roesler is offline   Reply With Quote
Old   December 14, 2015, 10:56
Default Problem with SimpleFoam + fvOptions for Porous Media
DOFuser is on a distinguished road
Dear all,
I have performed a simulation with porousSimpleFoam which run well for determining the flow field in a simple cylindrical domain in the middle of which I placed a porous media for representing the effect of a grid. The porosity model I used is the implicit version of Darcy-Forchheimer law.
Then I tried to migrate from the solver 'porousSimpleFoam' to the solver 'simpleFoam' joined with 'fvOptions' set with the 'explicitPorositySource' type in order to check if I was able to reproduce the results I have previously obtained, but the simulation blew up.
I think that this is due to the explicit approach by which the porous source is treated. But I am not able to figure out an alternative way to treat the problem, since the 'explicitPorositySource' is the only type available.
Does anyone have any suggestion to solve this issue?
Thanks in advance.
DOFuser is offline   Reply With Quote
Old   December 18, 2015, 11:57
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Till this part
Originally Posted by DOFuser View Post
...to check if I was able to reproduce the results I have previously obtained, but the simulation blew up...
is kept as it is, nobody could help you.
Post error message, post your settings, post archive of your case. There are LOTS of reasons for your simulation to blow up.
alexeym is offline   Reply With Quote
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Multiphase flow in porous media and relative permeabilities sirpolar Fluent Multiphase 1 July 24, 2016 06:41
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Modeling unsteady multiphase flow in porous media - convergence problem Vaibhav Kumar Main CFD Forum 1 July 22, 2012 05:32
combustion in porous media burner zuby ANSYS 0 July 27, 2009 03:26
