modified chtMultiRegionFOAM: how to exchange the pressure field between two regions? |
December 4, 2015, 12:44 |
arough
Rep Power: 13 |
Dear FOAMers,
I modified chtMultiRegionFOAM solver but I have some difficulties : in my case the pressure is calculated in region 1 but in the interface between the two regions I need this pressure to be used in region 2 as data can you help me how to use a result from region 1 as data for region 2 Thanks in advance. |
December 10, 2015, 18:17 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Arough,
I received the PM you sent me and I came looking for a thread you had on this topic. This is an interesting issue, because if I remember correctly, both chtMultiRegionFoam and chtMultiRegionSimpleFoam do not calculate the pressure equations/fields within the solid regions. I need to know the following details from your case:
Bruno
December 11, 2015, 00:23 |
Cyprien
Rep Power: 18 |
Hi rou,
you may have a look to these posts: http://www.cfd-online.com/Forums/ope...tml#post420495 http://www.cfd-online.com/Forums/ope...ontinuity.html The tutorial mentioned in these threads was very useful! It was for temperature, but the idea remains the same for pressure. Cheers, Cyprien |
December 14, 2015, 10:48 |
arough
Rep Power: 13 |
thank you for your replay
Cyprien I will check these posts |
December 28, 2015, 12:31 |
#5 | ||
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Rou: I hope you don't mind, I'll try to answer your private message here on this thread: Quote:
Best regards, Bruno
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
How to get the velocity field from the pressure field | Hermano | Main CFD Forum | 2 | November 29, 2011 09:32 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
