Trying to port dieselFoam to OpenFOAM 3.0
Like Tree2Likes
  • 2 Post By wyldckat
Old   November 27, 2015, 06:05
Default Trying to port dieselFoam to OpenFOAM 3.0
Moritz
Momo1805 is on a distinguished road
Hey there,
can someone help me how to use the dieselFoam solver in the latest version of OF 30?? I downloaded the ext version so I have the tutorial and all the set ups but I can't the solver to work!
Thanks for your help!
Momo1805 is offline   Reply With Quote
Old   November 27, 2015, 17:28
Retired Super Moderator
Bruno Santos
Quick answer: Read this thread: http://www.cfd-online.com/Forums/ope...m-2-1-0-a.html - specially post #7.
Old   January 31, 2016, 11:40
Bruno Santos
Greetings Moritz,
You sent me a PM 16 days ago and only today did I finally manage to take a look into your question. I'll answer on this thread of yours, to keep things in the same topic and public.
Quoting parts of the message you sent me:
Originally Posted by Momo1805
[...] currently writing my thesis about an injection process of iso-butan with OpenFoam.
[...] I already have a partially evaporated gas mixture when I am injecting, so my question would be, is there within the sprayFoam or dieselFoam solvers a possibility to perform a multiphase injection?
OK, I'll write down the steps I've taken to figure out some of the details. The remaining details I'll leave them to you.
  1. I went to the "tutorials" folder and looked at the files located inside the tutorial case "lagrangian/sprayFoam/aachenBomb":
    tut
    cd lagrangian/sprayFoam/aachenBomb
    cd constant
    gedit *
  2. I looked at all of the opened files and saw this:
        compositionModel singlePhaseMixture;
        phaseChangeModel liquidEvaporationBoil;
        singlePhaseMixtureCoeffs
            phases
                liquid
                    C7H16               1;
        liquidEvaporationBoilCoeffs
            enthalpyTransfer enthalpyDifference;
            activeLiquids    ( C7H16 );
  3. I then went to the Github page for the OpenFOAM 3.0.x repository: https://github.com/OpenFOAM/OpenFOAM-3.0.x/
  4. Used the search box at the top of that page and searched for:
    compositionModel
  5. Among the results were tutorial cases that used these different lines:
    compositionModel singleMixtureFraction;
  6. I used the search box again to look for this:
    singlePhaseMixture
  7. After finding the main class file:
    src/lagrangian/intermediate/submodels/Reacting/CompositionModel/SinglePhaseMixture/SinglePhaseMixture.C
    I clicked on the link and went up two steps on the path, so that I could browse the folders. In other words, I went to this folder:
  8. There I found these folders:
    CompositionModel
    NoComposition
    SingleMixtureFraction
    SinglePhaseMixture
  9. I then went into the folder "SingleMixtureFraction".
  10. And then opened the file "SingleMixtureFraction.H".
  11. The description states this:
    Templated parcel multi-phase, multi-component class
    Therefore, this is essentially what you're looking for.
  12. The initial tutorial case uses a single chemical named "C7H16".
  13. From the first search, the following file has a few more details on how to use the mixture fraction model:
    tutorials/lagrangian/reactingParcelFoam/filter/constant/reactingCloud1Properties
Good luck! Best regards,
Bruno
Artur and serles like this.
Old   February 1, 2016, 11:07
Moritz
Hey wyldckat,
thanks a lot for you answer! And if I want to use these composition models within sprayFoam, I just compile a new library and include the composition submodels right? Because there are per default not available in sprayFoam.
Greets
Moritz
Old   February 6, 2016, 07:27
Bruno Santos
Quick answer: You only need to create a new library if and only if you need a different method for mixing the particles/fluids.
If you need new compositions, have a look at the tutorial cases that exist in the "tutorials/lagrangian" folder, because it contains a lot of similar cases. Have a look into the files "constant/thermo*".
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
[pythonFlu] Can someone tell me more about vulashaka elvis OpenFOAM Community Contributions 21 June 6, 2011 05:05
OpenFOAM 15x MinGW Windows Port gocarts OpenFOAM Installation 1 April 17, 2009 11:41
Port OpenFOAM to IBM Cell BE mgarcia OpenFOAM Installation 2 November 1, 2007 08:33
DieselFoam problem with Brookbs cygwin port leosding OpenFOAM Installation 4 August 12, 2006 05:51
