/usr/bin/ld: cannot find -llagrangianTurbulence /usr/bin/ld: cannot find -lfluidTherm
Like Tree3Likes
  • 1 Post By alexeym
  • 1 Post By floquation
Old   November 13, 2015, 18:22
Default /usr/bin/ld: cannot find -llagrangianTurbulence /usr/bin/ld: cannot find -lfluidTherm
Luis
Luiggito is on a distinguished road
When I try to compile my solver with wmake the next error appears:
/usr/bin/ld: cannot find -lfluidThermophysicalModels
Do somebody knows where can these libraries be found?
Thank you.
Luiggito is offline   Reply With Quote
Old   November 14, 2015, 11:06
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
They should be in $FOAM_LIBBIN (the value depends on where OpenFOAM is installed, what compiler/OS you are using) folder.
Democritus likes this.
alexeym is offline   Reply With Quote
Old   March 30, 2016, 09:48
Democritus's Avatar
Xiaoqiu HE
Democritus is on a distinguished road
Hi~
Would you please tell me how to add this path to the system's default compile search path? I have a prompted error:
/usr/bin/ld: cannot find -lfiniteVolume
/usr/bin/ld: cannot find -lmeshTools
It seems that the wmake do not search these libs in $FOAM_LIBBIN, so how to indicate the wmake to search libs in $FOAM_LIBBIN path?
Thank you!
Democritus is offline   Reply With Quote
Old   March 30, 2016, 10:18
floquation's Avatar
Kevin van As
floquation will become famous soon enough
(On Unix systems) The system variable "$LD_LIBRARY_PATH" is used for that.
LD_LIBRARY_PATH=$FOAM_LIBBIN:$LD_LIBRARY_PATH
This should however be done automatically if you source OpenFOAM's bashrc file, through the config/settings.sh script.
floquation is offline   Reply With Quote
Old   March 30, 2016, 10:38
Democritus's Avatar
Xiaoqiu HE
Thank you very much for your response!
I have checked the my ~/.bashrc , the last line was
. /opt/openfoam30/etc/bashrc
Then I changed it to
source /opt/openfoam30/etc/bashrc
But I have the same error. I will try to restart my PC then recheck this problem.
I will also update the situation.
Thank you very much for your help!
Old   March 30, 2016, 10:49
Democritus's Avatar
Xiaoqiu HE
Quick Update~
I still have these prompted error
collect2: error: ld returned 1 exit status
/opt/openfoam30/wmake/Makefile:147: recipe for target 'a.out' failed
make: *** [a.out] Error 1
Old   March 30, 2016, 11:12
floquation's Avatar
Kevin van As
Firstly, what operating system are you using? As I must mention that my knowledge resides within Linux.
Can you post the output of the following command:
echo -e ${LD_LIBRARY_PATH//:/\\n} && echo "" && echo "$FOAM_LIBBIN"
This will print two environmental variables (in a nice format) to the terminal.
If correct, the very last line shown (i.e. $FOAM_LIBBIN) should be contained within the printed list (i.e. $LD_LIBRARY_PATH).
Also make sure that $FOAM_LIBBIN actually has the libraries you need. You can test this using:
find $FOAM_LIBBIN -iname "*finitevolume*"
find $FOAM_LIBBIN -iname "*meshtools*"
Does this give a result that looks something like?:
/opt/.../lib/libfiniteVolume.so
(And similar for meshTools.)
Old   March 30, 2016, 22:28
Democritus's Avatar
Xiaoqiu HE
Thank you very much! As a starter of Linux, your advice and thoughts about the problem shed light on the knowledge that I should learn~
The OS I am using is ubuntu 15.10; Basing on your suggestion, the first thing I check is the real path of my $FOAM_LIBBIN, I check it as following
hxq@hxq-All-Series:~$ cd $FOAM_LIBBIN
hxq@hxq-All-Series:/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib$
meaning: $FOAM_LIBBIN = /opt/openfoam30/platforms/linux64GccDPInt32Opt/lib
then I typed the first command and get following results:
hxq@hxq-All-Series:~$ echo -e ${LD_LIBRARY_PATH//:/\\n} && echo "" && echo "$FOAM_LIBBIN"
/opt/ThirdParty-3.0.1/platforms/linux64Gcc/gperftools-svn/lib
/opt/paraviewopenfoam44/lib/paraview-4.4
/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib/openmpi-system
/opt/ThirdParty-3.0.1/platforms/linux64GccDPInt32Opt/lib/openmpi-system
/usr/lib/openmpi/lib
/home/hxq/OpenFOAM/hxq-3.0.1/platforms/linux64GccDPInt32Opt/lib
/opt/site/3.0.1/platforms/linux64GccDPInt32Opt/lib
/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib/dummy
I think that means the path is properly set.
Then I try to search the finiteVolume and meshTools lib in this path, I get:
hxq@hxq-All-Series:~$ find $FOAM_LIBBIN -iname "*finitevolume*"
/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so
hxq@hxq-All-Series:~$ find $FOAM_LIBBIN -iname "*meshTools*"
/opt/openfoam30/platforms/linux64GccDPInt32Opt/lib/libmeshTools.so
The lib files are in the right path and the path is properly set!
I am really confused. Should I reinstall the OpenFOAM as the tricks of Windows?
Thank you!
Old   March 30, 2016, 22:56
Democritus's Avatar
Xiaoqiu HE
Quick Update!
The problem is solved! I have made a very very stupid mistake!
In my project's Make/files, once it was like these
helmholtzFoam_Hxq.C
EXE = .
Then I change it to
helmholtzFoam_Hxq.C
EXE = ~/myCode/helmholtzFoam_Hxq/helmholtzFoam_Hxq
Then the compile process goes well!
Thank you floquation, for your precious time and advice on my problem!
Old   May 2, 2016, 01:54
Zhiheng Wang
Zhiheng Wang is on a distinguished road
Quick Update~
You can also modify your make file LIB as -I($LSRC)/finiteVolume/lnInclude \
some time LD_LIBRARY_PATH needs to be fixed every time.
Zhiheng Wang is offline   Reply With Quote
OpenFoam171: error /usr/bin/ld: cannot find -llduSolvers Schipper OpenFOAM Programming & Development 9 August 26, 2020 06:31
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
/usr/bin/ld: cannot find -lincompressibleRASModels (OF-1.7.x) kumar OpenFOAM Installation 6 March 17, 2011 03:29
Allwmake error: /usr/bin/ld: cannot find -lautoMesh ranas OpenFOAM Bugs 2 August 3, 2009 22:55
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
