November 6, 2015, 15:07 |
Issue compiling solver for OF 2.4
Klaus
Rep Power: 22 |
I use OpenFoam 2.4. When I try to compile solvers developed for earlier versions of OpenFoam, (basically any 2.x version) I run into the same problem: ... /opt/openfoam240/src/OpenFOAM/lnInclude/runTimeSelectionTables.H:77:9: warning: control reaches end of non-void function [-Wreturn-type] } \ ^ /opt/openfoam240/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H:125:9: note: in expansion of macro ‘declareRunTimeSelectionTable’ declareRunTimeSelectionTable ^ make: *** [Make/linux64GccDPOpt/SSTtransition.o] Fehler 1 (Fehler means error) What has changed and how can I fix it? Klaus |
November 6, 2015, 17:13 |
Guess, Fehler is somewhere else, since the excerpt you have posted contains only warning. Could you post the whole output? Last edited by alexeym; November 7, 2015 at 00:57. Reason: extra "in" |
November 6, 2015, 17:45 |
full output
Klaus
Rep Power: 22 |
wmakeLnInclude: linking include files to ./lnInclude
ln: Die symbolische Verknüpfung »./additional.H“ konnte nicht angelegt werden: Die Datei existiert bereits ln: Die symbolische Verknüpfung »./SSTtransition.H“ konnte nicht angelegt werden: Die Datei existiert bereits ln: Die symbolische Verknüpfung »./SSTtransition.C“ konnte nicht angelegt werden: Die Datei existiert bereits Making dependency list for source file SSTtransition.C SOURCE=SSTtransition.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam240/src/turbulenceModels -I/opt/openfoam240/src/transportModels -I/opt/openfoam240/src/finiteVolume/lnInclude -I/opt/openfoam240/src/meshTools/lnInclude -I/opt/openfoam240/src/turbulenceModels/incompressible/RAS/lnInclude -I/home/klaus/OpenFOAM/klaus-2.4.0/run/findroot -IlnInclude -I. -I/opt/openfoam240/src/OpenFOAM/lnInclude -I/opt/openfoam240/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/SSTtransition.o In file included from /opt/openfoam240/src/OpenFOAM/lnInclude/token.H:49:0, from /opt/openfoam240/src/OpenFOAM/lnInclude/Istream.H:47, from /opt/openfoam240/src/OpenFOAM/lnInclude/ISstream.H:39, from /opt/openfoam240/src/OpenFOAM/lnInclude/IOstreams.H:38, from /opt/openfoam240/src/OpenFOAM/lnInclude/VectorSpace.C:27, from /opt/openfoam240/src/OpenFOAM/lnInclude/VectorSpace.H:171, from /opt/openfoam240/src/OpenFOAM/lnInclude/Vector.H:44, from /opt/openfoam240/src/OpenFOAM/lnInclude/vector.H:39, from /opt/openfoam240/src/OpenFOAM/lnInclude/fieldTypes.H:35, from /opt/openfoam240/src/OpenFOAM/lnInclude/primitiveFieldsFwd.H:36, from /opt/openfoam240/src/turbulenceModels/incompressible/turbulenceModel/turbulenceModel.H:46, from /opt/openfoam240/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H:47, from SSTtransition.H:81, from SSTtransition.C:26: /opt/openfoam240/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H: In instantiation of ‘static Foam::autoPtr<Foam::incompressible::RASModel> Foam::incompressible::RASModel::adddictionaryConst ructorToTable<RASModelType>::New(const volVectorField&, const surfaceScalarField&, Foam::transportModel&, const Foam::word&) [with RASModelType = Foam::incompressible::RASModels::SSTtransition; Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]’: /opt/openfoam240/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H:125:9: required from ‘Foam::incompressible::RASModel::adddictionaryCons tructorToTable<RASModelType>::adddictionaryConstru ctorToTable(const Foam::word&) [with RASModelType = Foam::incompressible::RASModels::SSTtransition]’ SSTtransition.C:43:1: required from here /opt/openfoam240/src/OpenFOAM/lnInclude/runTimeSelectionTables.H:76:66: error: cannot allocate an object of abstract type ‘Foam::incompressible::RASModels::SSTtransition’ return autoPtr< baseType >(new baseType##Type parList); \ ^ /opt/openfoam240/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H:125:9: note: in expansion of macro ‘declareRunTimeSelectionTable’ declareRunTimeSelectionTable ^ In file included from SSTtransition.C:26:0: SSTtransition.H:97:7: note: because the following virtual functions are pure within ‘Foam::incompressible::RASModels::SSTtransition’: class SSTtransition ^ In file included from /opt/openfoam240/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H:47:0, from SSTtransition.H:81, from SSTtransition.C:26: /opt/openfoam240/src/turbulenceModels/incompressible/turbulenceModel/turbulenceModel.H:217:37: note: virtual Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > > Foam::incompressible::turbulenceModel::divDevRhoRe ff(const volScalarField&, Foam::volVectorField&) const virtual tmp<fvVectorMatrix> divDevRhoReff ^ In file included from /opt/openfoam240/src/OpenFOAM/lnInclude/token.H:49:0, from /opt/openfoam240/src/OpenFOAM/lnInclude/Istream.H:47, from /opt/openfoam240/src/OpenFOAM/lnInclude/ISstream.H:39, from /opt/openfoam240/src/OpenFOAM/lnInclude/IOstreams.H:38, from /opt/openfoam240/src/OpenFOAM/lnInclude/VectorSpace.C:27, from /opt/openfoam240/src/OpenFOAM/lnInclude/VectorSpace.H:171, from /opt/openfoam240/src/OpenFOAM/lnInclude/Vector.H:44, from /opt/openfoam240/src/OpenFOAM/lnInclude/vector.H:39, from /opt/openfoam240/src/OpenFOAM/lnInclude/fieldTypes.H:35, from /opt/openfoam240/src/OpenFOAM/lnInclude/primitiveFieldsFwd.H:36, from /opt/openfoam240/src/turbulenceModels/incompressible/turbulenceModel/turbulenceModel.H:46, from /opt/openfoam240/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H:47, from SSTtransition.H:81, from SSTtransition.C:26: /opt/openfoam240/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H: In static member function ‘static Foam::autoPtr<Foam::incompressible::RASModel> Foam::incompressible::RASModel::adddictionaryConst ructorToTable<RASModelType>::New(const volVectorField&, const surfaceScalarField&, Foam::transportModel&, const Foam::word&) [with RASModelType = Foam::incompressible::RASModels::SSTtransition; Foam::volVectorField = Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>; Foam::surfaceScalarField = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]’: /opt/openfoam240/src/OpenFOAM/lnInclude/runTimeSelectionTables.H:77:9: warning: control reaches end of non-void function [-Wreturn-type] } \ ^ /opt/openfoam240/src/turbulenceModels/incompressible/RAS/lnInclude/RASModel.H:125:9: note: in expansion of macro ‘declareRunTimeSelectionTable’ declareRunTimeSelectionTable ^ make: *** [Make/linux64GccDPOpt/SSTtransition.o] Fehler 1 |
November 7, 2015, 01:08 |
The real error is here: Code:
/opt/openfoam240/src/OpenFOAM/lnInclude/runTimeSelectionTables.H:76:66: error: cannot allocate an object of abstract type ‘Foam::incompressible::RASModels::SSTtransition’ return autoPtr< baseType >(new baseType##Type parList); \ |
November 7, 2015, 10:07 |
library is created but isn't recognized
Klaus
Rep Power: 22 |
ok, I added the required function to the source code and compilation worked BUT the library isn't recognized. I added it to the controlDict.
libs ("libSSTtransition.so"); I know that the code was initially created on Ubuntu 10.04 for OF2.1, I am running Ubuntu LTS 14.04 and OF2.4 this is the log: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : /home/klaus/OpenFOAM/klaus-2.4.0/platforms/linux64GccDPOpt/lib/libSSTtransition.so: undefined symbol: _ZNK4Foam14incompressible9RASModels4SSTtransition1 3divDevRhoReffERKNS_14GeometricFieldIdNS_12fvPatch FieldENS_7volMeshEEERNS3_INS_6VectorIdEES4_S5_EE --> FOAM Warning : From function dlLibraryTable:pen(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libSSTtransition.so" Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model SSTtransition [0] [0] [0] --> FOAM FATAL ERROR: [0] Unknown RASModel type SSTtransition Valid RASModel types: 18 ( LRR LamBremhorstKE LaunderGibsonRSTM LaunderSharmaKE LienCubicKE LienCubicKELowRe LienLeschzinerLowRe NonlinearKEShih RNGkEpsilon SpalartAllmaras kEpsilon kOmega kOmegaSST kkLOmega laminar qZeta realizableKE v2f ) [0] [0] [0] From function RASModel::New(const volVectorField&, const surfaceScalarField&, transportModel&, const word&) [0] [3] [3] [3] --> FOAM FATAL ERROR: [3] Unknown RASModel type SSTtransition Valid RASModel types: 18 ( LRR LamBremhorstKE LaunderGibsonRSTM LaunderSharmaKE LienCubicKE LienCubicKELowRe LienLeschzinerLowRe NonlinearKEShih RNGkEpsilon SpalartAllmaras kEpsilon kOmega kOmegaSST kkLOmega laminar qZeta realizableKE v2f ) [3] [3] [3] From function RASModel::New(const volVectorField&, const surfaceScalarField&, transportModel&, const word&) [1] [1] [1] --> FOAM FATAL ERROR: [2] [2] [2] --> FOAM FATAL ERROR: in file RASModel/RASModel.C at line 140. [0] FOAM parallel run exiting [0] [3] in file RASModel/RASModel.C at line 140. [3] FOAM parallel run exiting [3] [1] Unknown RASModel type SSTtransition Valid RASModel types: 18 ( LRR LamBremhorstKE LaunderGibsonRSTM LaunderSharmaKE LienCubicKE LienCubicKELowRe LienLeschzinerLowRe NonlinearKEShih RNGkEpsilon SpalartAllmaras kEpsilon kOmega kOmegaSST kkLOmega laminar qZeta realizableKE v2f ) [1] [1] [1] [2] Unknown RASModel type SSTtransition Valid RASModel types: 18 ( LRR LamBremhorstKE LaunderGibsonRSTM LaunderSharmaKE LienCubicKE LienCubicKELowRe LienLeschzinerLowRe NonlinearKEShih RNGkEpsilon SpalartAllmaras kEpsilon kOmega kOmegaSST kkLOmega laminar qZeta realizableKE v2f ) [2] [2] [2] From function From function RASModel::New(const volVectorField&, const surfaceScalarField&, transportModel&, const word&) [1] in file RASModel/RASModel.C at line 140. [1] FOAM parallel run exiting [1] RASModel::New(const volVectorField&, const surfaceScalarField&, transportModel&, const word&) [2] in file RASModel/RASModel.C at line 140. [2[4m PyFoam WARNING on line 248 of file /usr/local/lib/python2.7/dist-packages/PyFoam-0.6.5-py2.7.egg/PyFoam/Execution/FoamThread.py : Process 4382 was already dead (B[m ] FOAM parallel run exiting [2] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun has exited due to process rank 0 with PID 4389 on node klaus-Aspire-V3-771 exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [klaus-Aspire-V3-771:04383] 3 more processes have sent help message help-mpi-api.txt / mpi-abort [klaus-Aspire-V3-771:04383] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Killing PID 4382 |
November 7, 2015, 16:50 |
Well, at this point, since you did not post any source code, I can only start to guess what it wrong. So
dlopen error : /home/klaus/OpenFOAM/klaus-2.4.0/platforms/linux64GccDPOpt/lib/libSSTtransition.so: undefined symbol: _ZNK4Foam14incompressible9RASModels4SSTtransition1 3divDevRhoReffERKNS_14GeometricFieldIdNS_12fvPatch FieldENS_7volMeshEEERNS3_INS_6VectorIdEES4_S5_EE |
November 9, 2015, 13:44 |
fixed
Klaus
Rep Power: 22 |
thank you for your support.
I just copied the missing method code snippet from the OF2.4 version src into .H and .C and it works fine now. Klaus |
July 26, 2018, 11:08 |
Rep Power: 16 |
Hi Klaus,
Could you be slightly more specific about how you solved this problem? I think I am facing the same issue, and it would be great to see your solution. Thanks. |
August 1, 2018, 19:15 |
#9 |
Klaus
Rep Power: 22 |
I suggest to use an editor which allows to compare files side-by-side. "Meld" works fine (http://meldmerge.org/) for me.
If you load a code file from two OpenFOAM versions, you'll clearly see the differences. In case something is missing in one version, you can copy the relevant sections like the declaration and implementation of a function. BUT there have been major code structure changes from version 3 to 4 to 5 which may require a deep understanding of the underlying changes when porting models from older versions of OpenFOAM. |
Compiling own solver: 'libNULL.so' is up to date. but not executable | lindstroem | OpenFOAM Programming & Development | 18 | November 30, 2020 05:32 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
Compiling Solver: Clang error linker commander failed | schwam | OpenFOAM Programming & Development | 11 | May 25, 2014 04:31 |
Error in compiling a modified solver | immortality | OpenFOAM Running, Solving & CFD | 3 | March 29, 2013 00:29 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
