Creating solver without pressure corrections
Like Tree1Likes
  • 1 Post By Lisandro Maders
Old   October 1, 2015, 17:38
Default Creating solver without pressure corrections
Lisandro Maders
Lisandro Maders is on a distinguished road
I am trying to create a solver that solves only the following equations:
1) Continuity
2) Momentum
3) Generic transport equation of variable Z
The fact is that my pressure field is constant, it almost does not vary. And also I take the density from a table based on Z values. So I do not need to make that pressure corrections that SIMPLE algorithm and others do. So how to proper write the .C solver file? Or if you can suggest me to take a look in some specific code that has this simplification it would be good as well.
Regards,
Lisandro
Lisandro Maders is offline   Reply With Quote
Old   October 1, 2015, 21:15
Default What I have done so far..
Lisandro Maders
Here is what I have done so far, but it is dividing by zero (at least I interpreted the error like this) somewhere in rhoEqn..
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    #include "createMesh.H"
    #include "initFGM.H"
    #include "createFields.H"
    simpleControl simple(mesh);
    #include "CourantNo.H"
//    #include "compressibleCourantNo.H"
    while (simple.loop())
        Info<< "Time = " << runTime.timeName() << nl << endl;
        while (simple.correctNonOrthogonal())
        Info << " Antes de rhoEqn.H " << endl;
        Info << " Escrevendo rho " << rho << endl;
        Info << " Escrevendo phi " << phi << endl;
        #include "rhoEqn.H"
        #include "UEqn.H"
        #include "pvEqn.H"
        #include "ztEqn.H"
        if (runTime.write())
            #include "writeFGMfields.H"
            #include "writeThermoPropertyFields.H"
        Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
            << "  ClockTime = " << runTime.elapsedClockTime() << " s"
            << nl << endl;
    Info<< "End\n" << endl;
    return 0;
Anything incredibly wrong at a first look?
Jamamoto takasi likes this.
Old   October 7, 2015, 10:31
Default Still weird
Lisandro Maders
Jamamoto,
I interpreted your "like" as: that looks right! However, the results I am getting for velocity field are very weird, which tells me I missed something in this simplification.
Could you or someone else give me some help on this? Is there any solver in OpenFOAM that does not make use of such simplification (no pressure/momentum corrections)..
Thanks!
correction, momentum, pressure, simple, simplification
Pressure equation for compressible solver Akshay OpenFOAM Programming & Development 8 October 3, 2015 10:22
Help! Divergence detected in AMG solver: pressure correction user0314 FLUENT 3 September 2, 2011 17:12
Using pressure based solver for compressible flows aamer Main CFD Forum 2 June 15, 2011 13:45
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM 0 April 4, 2010 19:06
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
