reactingFoam fvOption ignition
Like Tree2Likes
  • 2 Post By khalifa
Old   September 20, 2015, 22:03
Default reactingFoam fvOption ignition
khalifa is on a distinguished road
Hello dear Foamers,
I am simulating 1-d premixed laminar flame with reactingFoam and need to ignite the process using fvOption file. I need to set the ignition strength of 5 e9 J/m3·s for 0.0002 s. how can I translate these paramters to fvOption file ?
Thanks
khalifa is offline   Reply With Quote
Old   September 25, 2015, 22:05
Question ignition parameters
kai wiseel
kaaaixx is on a distinguished road
Hello khalifa,
I am stucking nearly at the same point.. Did you find a answer of how the ignition parameters are linked to "the real" ignition energy?
Thanks in advance,
Kai
kaaaixx is offline   Reply With Quote
Old   September 30, 2015, 06:52
Originally Posted by kaaaixx View Post
Hello khalifa,
Thanks in advance,
Kai
Hello Kai,
actually I found this
-----------------------------*- C++ -*----------------------------------*\
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
source1
    type            fixedTemperatureConstraint;
    active          true;
    timeStart       1e-7;
    duration        1e-7;
    selectionMode   cellSet;
    cellSet         ignitionCells;
    fixedTemperatureConstraintCoeffs
        mode            uniform;
        temperature     3000;
/*energySource1
    type            scalarSemiImplicitSource;
    active          true;
    timeStart       0;
    duration        0.0002;
  selectionMode   cellSet; //cellSet // points //cellZone
    scalarSemiImplicitSourceCoeffs
        volumeMode      absolute;
        injectionRateSuSp
            h           (10 0);
but to be honest , both criteria (modifieng h or t) did not deliver reasonable results at the end. I mean , combustion occurred, but I think the energy equation was effected and the final temperature that I got is not really correct. in addition, I really dont know what is the unit of 10 in h (10 0); I just kept trying value until the mixture ignited without exceeding the 3000 k limit.
could you please try it and share your experience with it ?
Old   September 30, 2015, 07:00
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
Hi, if i'm right, then you want to insert energy source in energy equation.
You can do this with next two types of fvOption objects:
- SemiImplicitSource
- CodedSource
mkraposhin is offline   Reply With Quote
Old   September 30, 2015, 07:15
- CodedSource
Thank you for your kind response.
Actually this is what I am trying to do, and this is the energy source implementation in my fvOptions file
/*energySource1
    active          true;
    timeStart       0;
    duration        0.0002;
        injectionRateSuSp
            h           (10 0);
now if you colud please help me further, as I am still a beginner with openFoam, is it correct to specify h as the energy source ? wont it be confused with any other term of the energy equationo ? and secondly, do you know what is the 0 value stands for ?
Old   September 30, 2015, 07:37
mkraposhin's Avatar
Matvey Kraposhin
/*energySource1
    active          true;
    timeStart       0;
    duration        0.0002;
        injectionRateSuSp
            h           (10 0);
Well, sorry, i didn't saw piece of code, related to energy.
So, you must select options as follows:
1. volumeMode should be changed from absolute to specific, because, as i see from starting post, your source have dims: J/m3/s
If you will leave volumeMode as absolute, then values of sources will be normalized by volume of cell sets, that you specified in cellSet.
2. h specifies only name for which balance equation is applied. energy equation can be applied both to specific internal energy (e) or specific enthalpy (h). You can check correct variable in file thermophysicalProperties:
energy sensibleEnthalpy; - that means, that you are solving energy equation with primary variable specific enthalpy
3. Values in brackets are sources:
- first value is an explicit source (Su), must be 5 e9 J/m3·s, but you specified 10 J/s
- second value is an implicit source (Sp), it will be substituted to equation of energy as follows: Dh/Dt = Sp*h
Old   September 30, 2015, 07:49
Thank you alot.
this my thermophyiscalProperties related code
thermoType
type hePsiThermo;
mixture reactingMixture;
transport sutherland;
thermo janaf;
equationOfState perfectGas;
specie specie;
so yes you are correct it uses sensibleEnthalpy. As far as I understood for what I should do , is to use this snesibleEnthalpy in the fvOptions file instead of h?
energySource1
    active          true;
    timeStart       0;
    duration        0.0001;
        volumeMode      specific;
        injectionRateSuSp
           h         (5e9 0);
Thanks again
Old   September 30, 2015, 07:52
Thank you alot.
energySource1
    active          true;
    timeStart       0;
    duration        0.0001;
        injectionRateSuSp
           h          (5e9 0);
Thanks again
I guess I got it now, it should be kept h. and the solver will solve it for sensible enthalpy. sorry for the too many silly questions
I really appreciate your help . it works perfect
wayne14 and SH_Zhong like this.
Old   January 6, 2019, 19:45
Olivier Dambron
olivierdambron is on a distinguished road
Hi there, I am facing the same challenge without really undertanding how to set the sensible enthalpy h.
I am trying to set a temperature or w/m2 as the injecitonRateSup for buoyantPimpleFoam.
Any small tip would be greatly appreciated.
Best
olivierdambron is offline   Reply With Quote
how to achieve ignition of premixed flame using ReactingFoam Dan1788 OpenFOAM Running, Solving & CFD 25 June 12, 2022 05:52
reactingFoam: ignition point? Jui OpenFOAM Running, Solving & CFD 8 September 9, 2014 16:50
Doubt in code ignition reactingFoam RCB123456 OpenFOAM Running, Solving & CFD 0 August 16, 2014 06:30
Ignition in reactingFoam pas32 OpenFOAM Programming & Development 4 August 13, 2014 10:00
Ignition point in reactingFoam? lfgmarc OpenFOAM Programming & Development 0 July 11, 2011 19:00
