Integration of part of the simulation domain
Like Tree1Likes
  • 1 Post By chriss85
Old   September 16, 2015, 10:40
Default Integration of part of the simulation domain
Edwin
Edwon is on a distinguished road
Hi Foamers!
I am trying to do a simple water volume calculation in a two-phase flow. To find the volume of the water in inter(DyM)Foam, I can simply use
dimensionedScalar waterVolume = sum(mesh.V()*alpha1);
However, for my simulations I need to know the volume of water in a certain part of the simulation domain, for example, let's say x<0 and x>=0. One of my attempts was this:
dimensionedScalar waterVolumeLeft = sum(mesh.V()*alpha1*neg(mesh.C().internalField().component(vector::X)));
dimensionedScalar waterVolumeRight = sum(mesh.V()*alpha1*pos(mesh.C().internalField().component(vector::X)));
However, this does not result in the correct volume: as a test I add both pos(..) and neg(..), which should result in the same waterVolume, but instead it gives this in a test run:
waterVolume: 1.31441405254865e-11, left+right:7.109575809296095e-12.
I've also tried to write the x-positions to a volScalarField, and looping over the elements, but I keep getting a (consistent) volume of 7.1095...e-12, with something like this:
volScalarField xPositions
    IOobject
        "xPositions",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::NO_WRITE
    mesh,
    dimensionedScalar("xPositions",dimensionSet(0,1,0,0,0,0,0), 0.0)
forAll(xPositions,iter)
    xPositions[iter]=mesh.C().internalField()[iter].component(vector::X);
dimensionedScalar waterVolumeLeftCheck  = 0.0;
dimensionedScalar waterVolumeRightCheck = 0.0;
    if (xPositions[iter]<0)
        waterVolumeLeftCheck+=mesh.V()[iter]*alpha1[iter];
    else
        waterVolumeRightCheck+=mesh.V()[iter]*alpha1[iter];
Can anyone point me in the right direction with this? Any help is appreciated!
Best,
Edwin
Edwon is offline   Reply With Quote
Old   September 16, 2015, 12:02
Edwin
Hmm after another search, I just found this topic:
http://www.cfd-online.com/Forums/ope...integrate.html
It looks like the fvc::domainIntegrate(alpha1*neg(xPositions)) function is the solution. I still don't see how my other attempts failed to give the right answer..
Old   September 16, 2015, 12:18
chriss85 will become famous soon enough
Just a rough sketch:
scalar volume = 0;
forAll(mesh, cellI)
if(mesh.C().x() <= 0)
volume += mesh.V()[cellI]*alpha1[cellI];
chriss85 is offline   Reply With Quote
Old   September 16, 2015, 13:04
Edwin
scalar volume = 0;
forAll(mesh, cellI)
That was my first try as well, but it gives an incorrect value. I link to a solution to the problem in my previous post.
Old   September 16, 2015, 15:56
Wouter van der Meer
wouter is on a distinguished road
hello Edwon,
Did you try this with a little larger volume, because it could be a numerical accuracy problem.
hope this helps,
Wouter
wouter is offline   Reply With Quote
Old   September 17, 2015, 05:40
Did you run this on multiple cores or on a single core? The code I showed is only suitable for a single core. If you need multiple cores, you need to run reduce(volume, sumOp<scalar>()); at the end to add the results of all the separate meshes together.
Edwon likes this.
Old   September 17, 2015, 06:20
Edwin
I just checked, that also solves the problem! (I assumed that the contributions of all cores would add up automagically)
I still find it strange that sum(mesh.V()*alpha1) works on multiple cores, and sum(mesh.V()*alpha1*neg( mesh.C().internalField().component(vector::X) )) does not. But, we (you) found out what was causing the discrepancy and that is what counts!
@Wouter, I've just checked, that was not the case. Haven't thought to look at that before, though.
integration, interfoam, sum()
PEM fuel cell simulation pchoopanya Mesh Generation & Pre-Processing 1 March 1, 2016 00:56
VAWT simulation rotation domain steve20024 Main CFD Forum 0 March 2, 2015 04:37
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Floating point exception: Zero divide liladhar CFX 11 December 16, 2013 05:07
How to define size of domain for free surface simulation? Sunya Main CFD Forum 2 June 9, 2009 00:33
