Access to cellid in cellSet
Like Tree10Likes
  • 2 Post By Tobi
  • 3 Post By yehaixuan
  • 5 Post By chengyu
Old   August 15, 2015, 11:49
Default Access to cellid in cellSet
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hello all,
If I read a cellSet like:
cellSet foobar(mesh, nameOfSet);
it will read the cellSet in constant/polyMesh/sets/nameOfSet.
I did not figure it out how to get access to the values of the cellSet (cellId 's)?
Any suggestion would be appreciated.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   August 15, 2015, 13:07
anonymous
ssss is on a distinguished road
As cellSet is a topoSet child class class maybe you can have a look in the way they use iterators and labels in topoSet, for example in the functions:
Foam::topoSet::invert
Foam::topoSet::updateLabels
Sorry that I cannot help you more, as my C++ knowledge is pretty basic
ssss is offline   Reply With Quote
Old   August 15, 2015, 15:27
Tobi's Avatar
Tobias Holzmann
Thanks for the replay.
I also checked topoSet in doxygen but I did not find any function. There has to be a way
Foam is so awesome but I do not know the classes very well.
Keep foaming,
Tobias Holzmann
Old   August 15, 2015, 15:43
Tobi's Avatar
Tobias Holzmann
Solved!
As always soooo easy. I wanted to have access only to the cellSet cells in some postProcessing. Due to the fact that cellSet is inherit by a hash table.
Therefore I get it with that:
cellSet test(mesh, nameOfSet);
forAll(mesh.C(), id)
    if  (test[id])
           //- Only get the cells which are included in the cellSet
ssss and daamec like this.
Keep foaming,
Tobias Holzmann
Old   September 13, 2016, 12:24
Haixuan Ye
yehaixuan is on a distinguished road
Originally Posted by Tobi View Post
Solved!
    if  (test[id])
Just for completeness. Your solution will loop all the cells. In my opinion, it may not be efficient when the cellSet is only a small portion of the mesh.
I suggest to use test.toc() to access the contents of the table directly.
test.toc()
Tobi, daamec and fly_light like this.
yehaixuan is offline   Reply With Quote
Old   April 16, 2017, 22:05
Default Use the native access method provided by OpenFOAM
Yu Cheng
chengyu is on a distinguished road
Hey guys,
I am also looking for the access method to cellSet, after digging into the code, I found a native way provided by OpenFOAM in the file fvOption.C, see the lines (147-148) and lines (236-240). For convenience, I paste the code here
           cellSet selectedCells(mesh_, cellSetName_);
           cells_ = selectedCells.toc();
        V_ = 0.0;
        forAll(cells_, i)
            V_ += mesh_.V()[cells_[i]];
Sun, ruloz, Michael@UW and 2 others like this.
chengyu is offline   Reply With Quote
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
[snappyHexMesh] MultiRegion(Snappy): how to define new zones Cartuns11 OpenFOAM Meshing & Mesh Conversion 6 May 3, 2019 13:02
irregular model simulation with chtMultiregionFoam lg88 OpenFOAM 59 July 28, 2016 12:44
Creating a cellSet fom yPlus buffi OpenFOAM Post-Processing 0 December 17, 2012 05:19
Online libraries - with access to Journals momentum_waves Main CFD Forum 2 December 12, 2007 11:08
