massflowrateVelocity Coupled Boundary Condition in fireFoam |
June 1, 2015, 14:29 |
Mehtab
Rep Power: 11 |
Dear Foamers,
I am trying to implement a mass flow boundary condition from past few days. But I think I could not go further without any help. Here is my code: Code:
void Foam::customflowRateInletVelocityFvPatchVectorField::updateCoeffs() { if (updated()) { return; } const basicThermo& thermo = db().lookupObject<basicThermo>("thermophysicalProperties"); const singleStepReactingMixture<gasHThermoPhysics>& singleMixture ( dynamic_cast<const singleStepReactingMixture<gasHThermoPhysics>&> //refCast<const singleStepReactingMixture<gasThermoPhysics> > (thermo) ); const label patchI = patch().index(); const scalarField& Yfg = thermo.composition().Y(0).internalField(); const compressible::LESModel& turbulence = db().lookupObject<compressible::LESModel> ( "LESProperties" ); const dictionary& transportProperties = db().lookupObject<IOdictionary> ( "transportProperties" ); dictionary mySubDict ( transportProperties.subDict("mySubDict") ); dimensionedScalar nu_(mySubDict.lookup("nu")); // const fvMesh& mesh = patch().boundaryMesh().mesh(); const volScalarField& Ts = db().lookupObject<volScalarField>("T"); const volScalarField& P_ = db().lookupObject<volScalarField>("P"); //heat of vaporization in J/kg scalar hv=510830.00; //boiling temperature in K scalar Tb=111.67; //Molecular weight in kg/mol scalar Wf=0.016043; //universal gas constant J/mol.K scalar R=8.31444621; // scalar nu=26.4e-6; scalar L=0.3; // scalar alpha=38.3e-6; const fvPatchField<scalar>& rhop = patch().lookupPatchField<volScalarField, scalar>(rhoName_); scalarList phi = patch().lookupPatchField<surfaceScalarField, scalar>(phiName_); const scalarField alphap = turbulence.alphaEff()().boundaryField()[patchI]; const volVectorField& Up = db().lookupObject<volVectorField>("U"); scalar ReL = mag(Up)*L /(nu_); scalar ScL = nu_ / (alphap); scalar ShL = 0.037*pow(ScL,1/3)*pow(ReL,4/5); scalar hm = ShL*alphap/L; //volume fraction of liquid fuel in gas phase double Yfl = exp(-hv*Wf*(1/R)*((1/Ts)-(1/Tb))); // convert to equivalent gaseous fuel phi = hm*P_*Wf/(R*Ts)*log((Yfg-1.)/(Yfl-1.)); const surfaceScalarField& phiName = db().lookupObject<surfaceScalarField>(phiName_); scalarField U = -phi/patch().magSf(); vectorField n = patch().nf(); // const surfaceScalarField& phi = // db().lookupObject<surfaceScalarField>(phiName_); if (phiName.dimensions() == dimVelocity*dimArea) { // volumetric flow-rate operator==(n*U); } else if (phiName.dimensions() == dimDensity*dimVelocity*dimArea) { const fvPatchField<scalar>& rhop = patch().lookupPatchField<volScalarField, scalar>(rhoName_); // mass flow-rate operator==(n*U/rhop); if (debug) { scalar phi = gSum(rhop*(*this) & patch().Sf()); Info<< patch().boundaryMesh().mesh().name() << ':' << patch().name() << ':' << this->dimensionedInternalField().name() << " <- " // << nbrMesh.name() << ':' // << nbrPatch.name() << ':' << this->dimensionedInternalField().name() << " :" << " mass flux[Kg/s]:" << -phi << endl; } } customflowRateInletVelocityFvPatchVectorField/customflowRateInletVelocityFvPatchVectorField.C: In member function ‘virtual void Foam::customflowRateInletVelocityFvPatchVectorFiel d::updateCoeffs()’: customflowRateInletVelocityFvPatchVectorField/customflowRateInletVelocityFvPatchVectorField.C:16 0:37: error: ‘const class Foam::basicThermo’ has no member named ‘composition’ const scalarField& Yfg = thermo.composition().Y(0).internalField(); ^ customflowRateInletVelocityFvPatchVectorField/customflowRateInletVelocityFvPatchVectorField.C:21 2:33: error: cannot convert ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ to ‘Foam::scalar {aka double}’ in initialization scalar ReL = mag(Up)*L /(nu_); ^ customflowRateInletVelocityFvPatchVectorField/customflowRateInletVelocityFvPatchVectorField.C:21 6:28: error: ‘ScL’ was not declared in this scope scalar ShL = 0.037*pow(ScL,1/3)*pow(ReL,4/5); ^ customflowRateInletVelocityFvPatchVectorField/customflowRateInletVelocityFvPatchVectorField.C:21 8:28: error: cannot convert ‘Foam::tmp<Foam::Field<double> >’ to ‘Foam::scalar {aka double}’ in initialization scalar hm = ShL*alphap/L; ^ customflowRateInletVelocityFvPatchVectorField/customflowRateInletVelocityFvPatchVectorField.C:22 3:50: error: cannot convert ‘Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >’ to ‘double’ in initialization double Yfl = exp(-hv*Wf*(1/R)*((1/Ts)-(1/Tb))); ^ customflowRateInletVelocityFvPatchVectorField/customflowRateInletVelocityFvPatchVectorField.C:15 2:57: warning: unused variable ‘singleMixture’ [-Wunused-variable] const singleStepReactingMixture<gasHThermoPhysics>& singleMixture ^ customflowRateInletVelocityFvPatchVectorField/customflowRateInletVelocityFvPatchVectorField.C:20 1:33: warning: unused variable ‘rhop’ [-Wunused-variable] const fvPatchField<scalar>& rhop = ^ customflowRateInletVelocityFvPatchVectorField/customflowRateInletVelocityFvPatchVectorField.dep: 697: recipe for target 'Make/linux64GccDPOpt/customflowRateInletVelocityFvPatchVectorField.o' failed make: *** [Make/linux64GccDPOpt/customflowRateInletVelocityFvPatchVectorField.o] Error 1 1) I am trying to access fuel mass fraction Yfg from the solver. the error says basicthermo has no member named composition. I saw similar codes in other post for calculating fuel mass fraction and used it. How can I access fuel mass fraction inside boundary condition patch? 2) I want to make sure if code for accessing kinematic viscosity is correct or not. Please comment. 3) For calculating ReL,ScL and ShL, it shows similar like "error: cannot convert ‘Foam::tmp<Foam::Field<double> >’ to ‘Foam::scalar {aka double}’ in initialization". I know there is some problem in accessing nu and alpha as scalar while I am accessing them as fields. Please help me to sort out these errors. Thanks in advance..... |
July 22, 2019, 07:39 |
Rep Power: 8 |
Hey,
were you able to figure it out? Regards, Okorie |
July 22, 2019, 11:38 |
Zhiheng Wang
Rep Power: 10 |
please claify your objective what you want to add or achieve , I have corrected and written this boundary condition.
Regards |
July 22, 2019, 11:42 |
Zhiheng Wang
Rep Power: 10 |
If you are trying to put a liquid pool interface boundary condition you dont need to go to region-Models.
As your equation suggest you are trying for mass flux based on Clausius-Clapeyron equation and stefan flow velocity. In such case see for my previous posts you will get exact boundary condition you can compile. Regards |
July 26, 2019, 07:46 |
Rep Power: 8 |
Hi Zhiheng,
I have gone through your posts again and I came across a boundary condition that you attached. I have attached it also so if possible you can confirm if its the same one. I have gone through it and it seems that you made use of the Clausius-Clapeyron relation to get the volume fraction but I don't believe you made use of the Stefan diffusion for the velocity unless it has different formulas. My problem is with using fireFoam, I can't get the volume fraction of the fuel vapor when implementing as a boundary condition. Is it possible to calculate it using the mass fraction of Oxygen and Nitrogen. |
several fields modified by single boundary condition | schröder | OpenFOAM Programming & Development | 3 | April 21, 2015 06:09 |
[swak4Foam] groovyBC for coupled boundary condition | yeharav | OpenFOAM Community Contributions | 2 | July 6, 2014 02:34 |
Velocity profile boundary condition | Tuca | FLOW-3D | 1 | April 23, 2013 13:02 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 05:13 |
regarding coupled boundary condition | VAIBHAV | Main CFD Forum | 0 | November 9, 2007 20:40 |
