May 26, 2015, 19:48 |
Inlet pressure condition varying in time
alvaro
Rep Power: 11 |
Hi all,
I'm trying to set a inlet pressure from a data curve of pressure and time. I use the OpenFoam v2.3.0 and I have seen the patch timeVaryingMappedFixedValueFvPatchField, but what little I understand about this patch is that it is necessary to create a folder for each time step within " constatn/boundaryData/inlet " and set the pressure value inside each time folder. Please, correct me if I'm wrong, I'm new in OpenFoam. The point is I would like to know if there is the possibility to make that the pressure values are being read from a text file for example. Regards. |
May 27, 2015, 04:37 |
ali alkebsi
Rep Power: 14 |
Try to look at the T-junction tutorial
https://github.com/OpenCFD/OpenFOAM-...oam/t-junction what they did is write the following in 0/p inlet { //type totalPressure; //p0 uniform 100040; type timeVaryingTotalPressure; p0 100040; // only used for restarts outOfBounds clamp; fileName "$FOAM_CASE/constant/p0vsTime"; U U; phi phi; rho none; psi none; gamma 1; value uniform 100040; } and then create a file constant/p0vsTime which contains a table or list of the time vs pressure as following ( ( 0 100010) ( 1 100040) ) now just like this you can make your file in the same listing way and then put its path in 0/p |
May 27, 2015, 08:11 |
alvaro
Rep Power: 11 |
Hi Ali,
I didn't know that tutorial and I think it's what I'm looking for. Thank you so much! |
May 27, 2015, 09:34 |
alvaro
Rep Power: 11 |
I forgot it... I'm using OpenFoam v2.3.0 and the patch "timeVaryingUniformTotalPressure" is not in this version, it's in v1.7 only I think. Could I implement this patch in my OF version in easy way? Regards. |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 10:34 |
time varying vector boundary condition using patch normal | mpeti | OpenFOAM Running, Solving & CFD | 8 | June 21, 2012 12:50 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 08:56 |
