runTime mapFields from fineMesh to coarseMesh
Like Tree5Likes
  • 1 Post By Carlen
  • 3 Post By Carlen
  • 1 Post By Maff
Old   April 25, 2015, 08:56
Default runTime mapFields from fineMesh to coarseMesh
Carlen is on a distinguished road
Hi Foamers,
I have recently successfully combined two solvers which solve different fields on two separate meshes(one fine and one coarse). Now I need to couple the fields of these two meshes every timestep. How can I achieve this? I read from this thread http://www.cfd-online.com/Forums/ope...-parallel.html #15 that I need to use a portion of the mapFields code. However, I have two questions, where do I put this code in my solver (eg.interFoam.C)? The second question is how can I read
HashTable<word> patchMap;
myDict.lookup("patchMap") >> patchMap;
wordList cuttingPatches;
myDict.lookup("cuttingPatches") >>  cuttingPatches;
How do I define parameters in myDict?
Also, my two meshes are of the same geometry, do you think the method I mentioned above is appropriate?
Thank you in advance
Carlen
Carlen is offline   Reply With Quote
Old   April 27, 2015, 04:45
Originally Posted by Carlen View Post
Hi Foamers,
Carlen
I managed to solver this problem by looking at the cavity case. Now my code for runTime mapFields looks like this:
IOdictionary carlenMapFieldsDict
             IOobject
              "carlenMapFieldsDict",
              runTime.constant(),
              mesh,
              IOobject::MUST_READ_IF_MODIFIED,
              IOobject::NO_WRITE
          volVectorField U_L(U, mesh);
          volVectorField U_E(U_P, Primary);
          volScalarField p_L(p, mesh);
          volScalarField p_E(p_P, Primary);
          volScalarField T_L(T, mesh);
          volScalarField T_E(T_P, Primary);
          carlenMapFieldsDict.lookup("patchMap") >> patchMap;
          carlenMapFieldsDict.lookup("cuttingPatches") >>  cuttingPatches;
          //set up an interpolation method
          meshToMesh::interpolationMethod mapMethod = meshToMesh::imCellVolumeWeight;
          // create the meshtomesh interpolator object
          Info << "Interpolating U,p,T Fields" << endl;
          meshToMesh InterpolatorObj
            mesh,
            Primary,
            mapMethod,
            patchMap,
            addProcessorPatches(Primary, cuttingPatches)
          //do the interpolation between U of the source mesh and Utgt of the target mesh
          InterpolatorObj.mapSrcToTgt
            U,
            eqOp<vector>(),
            U_P
            p,
            eqOp<scalar>(),
            p_P
            T,
            eqOp<scalar>(),
            T_P
          Info << "Mapping complete" << endl;
The above code compiles and runs without problem. However, the fields are not mapped between two grids. I narrowed the problem to the way in which I define fields in two meshes. Cna anyone please tell me how to define the fields I want to map?
Thank you very much
carlen
Old   April 28, 2015, 16:21
Marcel Vonlanthen
Sylv is on a distinguished road
What do you mean by "the fields are not mapped between two grid"? The solver crashes or the interpolation is wrong/incomplete?
Sylv
Sylv is offline   Reply With Quote
Old   April 28, 2015, 20:23
Sylv
Hi Marcel,
The interpolation is simply not carried out.
carlen
Old   April 29, 2015, 05:36
Marcel Vonlanthen
Hi Marcel,
carlen
So the solver just go through the interpolation without crashing and the target field remained unchanged, right? Are the mesh identical? Is one grid coarser? If yes, which one (target or source)?
Be more detailed in your answers. It is tough to understand the problem with just "not carried out" or "doesn't work"....
Sylv
Old   April 29, 2015, 21:28
Sylv
Hi Marcel,
I managed to make the interpolation work from a fine mesh (mesh) to a coarse (Secondary) mesh (they are of the same geometry) using code below:
             IOobject
              runTime.constant(),
              mesh,
              IOobject::NO_WRITE
          IOobject Utarget
              "U",
              Secondary.time().timeName(),
              Secondary,
              IOobject::MUST_READ
          volVectorField Utgt(Utarget, Secondary);
          meshToMesh Interp
            mesh,
            Secondary,
            mapMethod,
            patchMap,
            addProcessorPatches(Secondary, cuttingPatches)
          Info << "Interpolating U Field" << endl;
          Interp.mapSrcToTgt
            U,
            eqOp<vector>(),
            Utgt
          Utgt.write();
However, the outcome is not ideal. You can see in the picture that the U field mapped on the coarse field is smeared. I wonder if I implement the mapping correctly.
Carlen
ch1 likes this.
Old   May 1, 2015, 04:32
Anyone please help me with this problem. I am stuck.
carlen
Old   May 10, 2015, 16:20
Retired Super Moderator
Bruno Santos
Hi Carlen,
I have this thread of yours on my to-do list, but I won't be able to look into this any time soon
Nonetheless, please provide a test case and the code ready to be used/tested, so that it takes less time for someone to step in and help.
In addition, you might want to take a look into the source code for this library/toolkit: https://github.com/smenon/dynamicTopoFvMesh - it has the ability to re-mesh the whole domain on-the-fly, although last I saw, it could only handle tetrahedral meshes.
This issue also reminds me of a similar topic: http://www.cfd-online.com/Forums/ope...pdate-fsi.html - you might be able to find some additional helpful ideas on that thread!!
Best regards,
Bruno
Old   May 15, 2015, 08:10
Thank you bruno,
I solved the problem by applying the same initial boundary condition for both the fine and coarse meshes. Now the interpolations is working as intended.
Old   February 2, 2017, 10:07
Maff is on a distinguished road
Hi Carlen,
I have been trying to implement mapField during runTime, in a similar way to the one you used (thank you for the useful posts btw).
I stumbled upon the same problem you had: the mapped field is smeared exactly as you posted.
You wrote that you solved the problem by applying the same initial boundary condition. It doesn't seem to work for me. Could you be more specific?
Maff is offline   Reply With Quote
Old   February 5, 2017, 12:09
I solved my problem by replacing
eqOp<vector>()
with
plusEqOp<vector>()
I'm not sure why, but it seems to work.
Ebrahim likes this.
Old   February 10, 2017, 04:58
Ebrahim
Ebrahim is on a distinguished road
eqOp<vector>()
with
plusEqOp<vector>()
Hi Maff,
I have the same issue as yours and I solved it by replacing eqOp<vector>() with plusEqOp<vector>() as well.
Did you find the reason? Actually, I do not know what is changed by this replacement!
/Ebrahim
Ebrahim is offline   Reply With Quote
Old   February 23, 2017, 09:30
Does anyone know how to save the meshToMesh addressing, so that it doesn't need to calculate it at every restart?
With some meshes it's a very time consuming process.
I found that with meshToMesh debug set to 1, it saves the srcToTgtCellAddr_, but I would need a way to write the whole result of
          meshToMesh Interp
            mesh,
            Secondary,
            mapMethod,
            patchMap,
so that it can read it if present.
I guess I would need to write my own meshToMesh.C.
Any idea?
Old   April 5, 2017, 13:25
Ehimen
Elliptic CFD is on a distinguished road
          meshToMesh Interp
            mesh,
            Secondary,
            mapMethod,
            patchMap,
Any idea?
Which of the meshToMesh libraries in OpenFOAM are you using?
I had the same problem of the cell addressing recalculating at every timestep when I used meshToMesh.H. I now use meshToMesh0.H and the interpolation between two regions is much faster, although, I am clueless on how to get it to work for parallel cases.
By the way, it seems that meshToMesh0.H is only available for the third and fourth versions of OpenFOAM.
Elliptic CFD is offline   Reply With Quote
Old   April 5, 2017, 13:33
Ehimen
Originally Posted by Ebrahim View Post
Hi Maff,
/Ebrahim
In OpenFOAM 3+, mapFields.C (which uses meshToMesh0) has the eqOp in the code while mapFieldsPar (which uses meshToMesh) has the plusEqOp in the code.
The difference may depend on which of the mesh to mesh libraries that you use.
Cheers
Old   November 14, 2022, 22:39
Xiaobo YAO
hdotyao is on a distinguished road
Hi Carlen,
I am also trying to implement mapFields into a solver. (chtMultiRegionFoam) May I ask where do you put your mapFields code in your solver.c?
Best,
Yao
hdotyao is offline   Reply With Quote
Issues with mapFields BlackBoatNavArch OpenFOAM Pre-Processing 38 May 28, 2021 17:29
Problem in3D model processing mebinitap OpenFOAM 2 December 12, 2014 05:40
Strange random behaviour of mapFields blaise OpenFOAM Pre-Processing 0 November 3, 2014 10:37
The -parallel parameter of mapFields utility in OpenFOAM v2.3.0 shuoxue OpenFOAM Pre-Processing 1 April 28, 2014 06:59
transientSimpleDyMFoam, mapFields and decomposePar pad OpenFOAM Running, Solving & CFD 0 December 3, 2010 06:22
