rho Constructor interFoam for creating a varying rho field
Like Tree3Likes
  • 3 Post By santiagomarquezd
Old   April 15, 2015, 12:24
Question rho Constructor interFoam for creating a varying rho field
ali alkebsi
kebsiali is on a distinguished road
Hello Dear Foamers
I have a simple question
in interFoam in createFields.H the rho is constructed as
volScalarField rho
IOobject
"rho",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT
alpha1*rho1 + alpha2*rho2,
alpha1.boundaryField().types()
rho.oldTime();
my question is what do the last couple of commands do
1. alpha1.boundaryField().types()
2. rho.oldTime();
I'm trying to implement a variable rho1 and I'm comparing interFoam with compressibleInterFoam the later does not have those two commands which is why i was wondering, i have nearly 20 self made constructors which are created randomly (without knowing if i have to add somthing like blabla.oldTime(); or blabla.boundaryFiled().types() or not)
kebsiali is offline   Reply With Quote
Old   April 16, 2015, 12:24
ali alkebsi
please!
any response, suggestions ?
Old   April 17, 2015, 06:07
Question Varying rho
ali alkebsi
Hello everybody
I'm working with interFoam and i want to make a varibal phase density
for this task i started by constructing a volScalarField in creatFields as
volScalarField rhof
IOobject
"rhof",
runTime.timeName(),
mesh,
IOobject::NO_READ
mesh
before i put some equation instead of "mesh" but it didnt work because
when i call this rhof into the library incompressibleTwoPhaseMixture.C using
const volScalarField& rhof=U_.mesh().lookupObject<volScalarField>("rhof" );
so that rhof takes place of rho1
now the problem reported by terminal is that rhof is not an object of mesh
this appears when i execute the case as it gives other suggestions that are useable objects and all of them are those for which in the constructor it is as the one shown above with mesh as the last line.
now using this constructor shown above with mesh in the last line so that rhof can be callabe the code searches for a boundary condition for rhof
am i going in the right way or should i just delete everything and give up, nah just joking.
any suggestions are heartfully wellcome
Old   March 18, 2016, 16:14
Bobby
babakflame is on a distinguished road
Originally Posted by kebsiali View Post
Hello Dear Foamers
volScalarField rho
IOobject
"rho",
runTime.timeName(),
mesh,
rho.oldTime();
2. rho.oldTime();
Hi Fellows
Any progress in this question?
I have the same question.
babakflame is offline   Reply With Quote
Old   April 16, 2016, 21:28
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hello Dear Foamers
volScalarField rho
IOobject
"rho",
runTime.timeName(),
mesh,
rho.oldTime();
2. rho.oldTime();
Hi, Kebsiali, regarding these:
   42 // Need to store rho for ddt(rho, U)
   43 volScalarField rho
   44 (
   45     IOobject
   46     (
   47         "rho",
   48         runTime.timeName(),
   49         mesh,
   50         IOobject::READ_IF_PRESENT
   51     ),
   52     alpha1*rho1 + alpha2*rho2,
   53     alpha1.boundaryField().types()
   54 );
   55 rho.oldTime();
in createFields.H alpha1.boundaryField().types() implies copying the boundary conditions from alpha1, and rho.oldTime() forces to call the storeOldTimes() method in order to set the old time field required by ddt(rho, U) as is indicated in 42.
Regards!
kaifu, babakflame and meshman like this.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Error log vw.cfd OpenFOAM 6 August 7, 2009 06:44
How to set a time varying velocity field as a BC? Mikro OpenFOAM Pre-Processing 5 March 19, 2009 05:38
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
