Source term in the compressible momentum equation
Like Tree1Likes
  • 1 Post By kebsiali
Old   April 9, 2015, 18:13
Default Source term in the compressible momentum equation
Daniel Duque
dduque is on a distinguished road
Hello everyone.
I'm studying this piece of code for the source term in the momentum equation. It's a laminar, compressible simulation in which mu is NOT constant.
tmp<fvVectorMatrix> laminar::divDevRhoReff(volVectorField& U) const
    return
      - fvm::laplacian(muEff(), U)
      - fvc::div(muEff()*dev2(T(fvc::grad(U))))
I'm guessing it means these right hand side terms in the Navier-Stokes momentum equation:
Laplacian( mu U) + div ( mu ( gradU^t - (2/3) divU I ) )
If mu was constant I would be happy, even if the second term is mathematically equal to (1/3) grad divU. There is surely some reason to write it this way. But I am concerned with the first term, which should be:
div ( mu gradU)
Perhaps that's what fvm::laplacian(muEff(), U) is ??
(It could also be mu Laplacian U, which wouldn't be good.)
Btw, it seems the fluid is supposed to be Stokesian, so that lamba+(2/3) mu =0, am I right?
Thanks!
Daniel
dduque is offline   Reply With Quote
Old   April 9, 2015, 18:33
ali alkebsi
kebsiali is on a distinguished road
In openfoam fvm::laplacian(a, b) is
\nabla \cdot \left( a \nabla b \right)
where a is to be linearized (explicit) and b is to be discretized
so yes is the answer to that little question
and dev is the deviatoric part which is the same as what you expect i think
dduque likes this.
kebsiali is offline   Reply With Quote
Old   April 10, 2015, 05:58
Daniel Duque
Great! Everything is fine, then. Yes, dev is the deviatoric part, and dev2 is a funny
dev2(s)=s - (2/3) trace(s) I
The deviatoric is
dev(s)=s - (1/3) trace(s) I ,
but it's precisely dev2 which is needed in this case.
compressible flow, laplacian operator, momentum equation, momentum source, navier-stokes solver
Source Term due to evaporation in energy transport equation styleworker OpenFOAM Programming & Development 3 September 7, 2022 04:09
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
UDF for source term in momentum equation Enrico FLUENT 9 May 30, 2014 12:34
Adding a momentum source term segersson OpenFOAM Running, Solving & CFD 5 March 3, 2006 00:06
