creepin flow with a new viscosity model
Like Tree1Likes
  • 1 Post By Sören Sander
Old   March 29, 2015, 20:13
Question creepin flow with a new viscosity model
jafar
bagherij is on a distinguished road
Dear Freeads
i am new in open foam,i want to analysis creeping flow( in steady state case) around cylinder ,i want to use a new viscosity model to calculate apparent viscosity.
how can i add a new viscosity model?
which solver should be used?
bagherij is offline   Reply With Quote
Old   March 30, 2015, 06:16
Sören Sander
Sören Sander is on a distinguished road
Hi bagherij,
this should give you a starting point.
Best regards,
Sören Sander is offline   Reply With Quote
Old   April 3, 2015, 07:46
Talking Thank you
jafar
Dear Sören
thanks,i added new viscosity model ,now i want to calculate shear stress( and compare with yield stress) ,how can i do it?
Best regards
Old   April 7, 2015, 04:03
Sören Sander
The shear stress tensor is calculated by
1. Define a volTensorField named "tau" in your createFields.H
2. Add the following line to your solver
tau = -mu*(fvc::grad(U)+(fvc::grad(U)).T());
where "mu" is the dynamic viscosity of the system. Depending on your viscosity model, you might have to replace this with your local mu.
bagherij likes this.
Old   April 14, 2015, 16:14
jafar
Thanking for reply
i added that line to my solver ,when i run below message coming
Error nu was not declared in this scope
mu should be returned by viscosity model .
Old   April 15, 2015, 11:57
Sören Sander
In the tutorial nu is accessed by
Foam::tmp<Foam::volScalarField>Foam::singlePhaseTransportModel::nu() const
    return viscosityModelPtr_->nu();
Without knowing your code in detail, i guess you might access your nu the same way.
Old   July 4, 2015, 21:08
Default calculate shear rate for creeping flow around cylider
jafar
Dear
I add a new viscosity model named "Zhu" to my problem by ,but when i run the code i got some error (in file error( attachment)).i also want to compare shear rate with yeld stressse but i dont know where should i do it.i attach my problem and new viscosity model.please help.
thanks jafar
crepping flow, cylinders, drag force, new viscosity model, openfoam2.3
Help: apply B.C. in my granular flow model ? Derek Jing FLUENT 1 January 8, 2020 22:38
coefficient of power-Law viscosity Model in OpenFOAM Daniel_Khazaei OpenFOAM Running, Solving & CFD 6 April 5, 2016 05:23
parallel code samiam1000 SU2 3 March 25, 2013 05:55
Baldwin-Lomax model in wall jet flow K.S.Chang Main CFD Forum 0 December 7, 2005 02:51
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
