When does OpenFOAM execute "storeOldTime" ?
Like Tree3Likes
  • 3 Post By deepsterblue
Old   March 4, 2015, 19:24
Default When does OpenFOAM execute "storeOldTime" ?
openfoammaofnepo is on a distinguished road
Hi All,
I met a problem when I read the EulerDdtScheme.C
https://github.com/OpenFOAM/OpenFOAM-2.2.x/blob/master/src/finiteVolume/finiteVolume/ddtSchemes/EulerDdtScheme/EulerDdtScheme.C
I found that when we do the time discretization, we need the rho and vf for both the current time step and the previous time step (lines 253 in the above wenpage):
rDeltaT*(rho*vf - rho.oldTime()*vf.oldTime())
So my question is: when OpenFOAm is running, when are rho.oldTime() and vf.oldTime() stored into these two fields as the old values? If we take the rhoPimpleFOAM as an example.
I checked the source files for GeometricField.C, and found that there are indeed the functions for storeOldTimes:
// Store old-time field
template<class Type, template<class> class PatchField, class GeoMesh>
void Foam::GeometricField<Type, PatchField, GeoMesh>::storeOldTimes() const
    if
        field0Ptr_
     && timeIndex_ != this->time().timeIndex()
            this->name().size() > 2
         && this->name()(this->name().size()-2, 2) == "_0"
        storeOldTime();
    // Correct time index
    timeIndex_ = this->time().timeIndex();
But due to my propably limited knowlwdge of C++, I failed to find the places where the above function is called and where the "storeOldTime()" is defined. Could anybody know about this issue? Thank you in advance!
OFFO
openfoammaofnepo is offline   Reply With Quote
Old   March 5, 2015, 10:50
Sandeep Menon
deepsterblue will become famous soon enough
It happens on-demand, whenever you invoke 'field.oldTime()'
If you look at the 'GeometricField:ldTime()' member function, it checks for the existence of field0Ptr_, and creates one if it doesn't exist. From that point on, it is updated on access only if the time-step has changed (by checking the value of timeIndex_, which is incremented every time-step)
fedvasu, rajibroy and joshwilliams like this.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   March 5, 2015, 10:58
Thank you, deepsterblue. I have not found a place where field.oldTime() is invoked. Could you please give me an example in it? Thank you very much. This is also my question so that I cannot understand when the old fields are stored in running OpenFOAM solvers.
OFFO
Old   March 5, 2015, 11:03
Sandeep Menon
You gave the example yourself - in your original post. When you have:
rho.oldTime() * vf.oldTime()
the storage of old-times is invoked at that point.
Sandeep Menon
Old   March 5, 2015, 11:31
Thank you. Since the following is from the Euler time scheme:
So does it mean that when the time discretization is perdormed, the old fields will be stored? I originally thought that rho.oldTime() only extract the old rho fields fore previously stored fields.
Old   March 5, 2015, 18:42
Sandeep Menon
Yes - makes sense, doesn't it? If you don't discretize in time, then you don't need an old time, and that never needs to be stored. Simple and elegant.
Sandeep Menon
Old   March 5, 2015, 18:47
It seems make sense. In one Solver, we will have several time discretizations, like in UEqn, rhoEqn, pEqn, for rho and the relavant quantities. If I follow your line of reasoning, the oldTime() will be store many times?
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 19:28
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 08:18
ESI-OpenCFD Releases OpenFOAM v2.2.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 13 March 30, 2013 17:52
Summer School on Numerical Modelling and OpenFOAM hjasak OpenFOAM 5 October 12, 2008 14:14
