February 21, 2015, 11:54 |
openfoam pow() fails when running parallel
Rep Power: 14 |
Hi foamers,
I am experiencing a problem when using pow() function for parallel run I want to calculate the diametre of an identified droplet using the code below Code:
pD = dropletV[i]*6.0/mathematical::pi; dropletD[i] = Foam::pow((pD), 1/2.0); I went back to check every value of dropletD array and they are all reasonable. So I figured a way to test the pow() function by manually putting in a calculated pD value and it worked fine. However, whenever I put in pD the simulation crashes. Can anyone help me with this problem? is there another alternative for pow() function? Last edited by wyldckat; February 21, 2015 at 12:14. Reason: Added [CODE][/CODE] |
February 21, 2015, 20:59 |
Rep Power: 14 |
Actually, putting 1.0/2.0 was a way I used to test the pow function. I want to evaluate dropletD[i] = Foam:ow(pD, 1.0/3.0) to find the diametre of the droplet. It seems to be the only way to find "to the power of 1/3". It crashes every time I try to run it in parallel. Any idea how to solve the problem?
February 22, 2015, 05:22 |
Can you post the error solver produces in parallel run? If you really think it has something to do with pow function, next question will be: where do you get dropletV array? How you iterate over the array? |
February 22, 2015, 06:09 |
Dongyue Li
Rep Power: 18 |
I also tried with this, there is a simple way to reproduce this problem:
Add this into interFoam: Code:
double asdfasfd = Foam::pow(alpha1[0],1.0/2.0); Code:
Courant Number mean: 0.0369924 max: 0.281874 Interface Courant Number mean: 0.00198018 max: 0.264548 deltaT = 0.00473396 Time = 0.0263302 MULES: Solving for alpha1 Phase-1 volume fraction = 0.130194 Min(alpha1) = -1.24957e-55 Max(alpha1) = 1 MULES: Solving for alpha1 Phase-1 volume fraction = 0.130194 Min(alpha1) = -1.18514e-55 Max(alpha1) = 1 sdfsdfsd sdfsdfsd sdfsdfsd sdfsdfsd [3] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [3] #1 Foam::sigFpe::sigHandler(int) at ??:? [3] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [3] #3 in "/lib/x86_64-linux-gnu/libm.so.6" [3] #4 pow in "/lib/x86_64-linux-gnu/libm.so.6" [3] #5 [3] at ??:? [3] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [3] #7 [3] at ??:? [q-virtual-machine:03985] *** Process received signal *** [q-virtual-machine:03985] Signal: Floating point exception (8) [q-virtual-machine:03985] Signal code: (-6) [q-virtual-machine:03985] Failing at address: 0x3e800000f91 [q-virtual-machine:03985] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36c30) [0x7f58302c3c30] [q-virtual-machine:03985] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7f58302c3bb9] [q-virtual-machine:03985] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36c30) [0x7f58302c3c30] [q-virtual-machine:03985] [ 3] /lib/x86_64-linux-gnu/libm.so.6(+0x15a95) [0x7f583087ea95] [q-virtual-machine:03985] [ 4] /lib/x86_64-linux-gnu/libm.so.6(pow+0x1c) [0x7f583088f9ac] [q-virtual-machine:03985] [ 5] interFoam() [0x4278e6] [q-virtual-machine:03985] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f58302aeec5] [q-virtual-machine:03985] [ 7] interFoam() [0x42af5a] [q-virtual-machine:03985] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 3 with PID 3985 on node q-virtual-machine exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- q@q-virtual-machine:~/OpenFOAM/OpenFOAM-2.2.x/tutorials/multiphase/interFoam/laminar/damBreak$ mpirun -np 4 interFoam -parallel /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.x Exec : interFoam -parallel Date : Feb 22 2015 Time : 10:46:33 Host : "q-virtual-machine" PID : 4044 Case : /home/q/OpenFOAM/OpenFOAM-2.2.x/tutorials/multiphase/interFoam/laminar/damBreak nProcs : 4 Slaves : But this works: Code:
double asdfasfd = Foam::pow(4,1.0/2.0); volScalarField asdsdfd = Foam::pow(alpha1,1.0/2.0); BTW, all of these cases can be launched without any problem in serial mode. |
February 22, 2015, 08:09 |
Rep Power: 14 |
Thank you Dongyue,
Your supplementary comment does make my question clearer |
February 22, 2015, 09:49 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
I have to say that I cannot find enough information in the examples you two have provided, in order for me to properly test this and to be 100% certain of what I'm going to write, but my guess/estimate is this:
Best regards, Bruno
February 22, 2015, 12:45 |
Rep Power: 14 |
Hi Bruno,
Thank you for your suggestion. I have experienced another problem when integrating your line of code in my solver. error: request for member ‘value’ in ‘(& alpha1)->Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::<anonymous>.Foam:imensionedField <double, Foam::volMesh>::<anonymous>.Foam::Field<double>::< anonymous>.Foam::List<double>::<anonymous>.Foam::U List<T>:perator[]<double>(cellI)’, which is of non-class type ‘double’ if (alpha1[cellI].value() > 0.8) it says value is of non-class type of ‘double' and the compilation fails. Any suggestion to solve this problem? we just simply added "volScalarField asdfs = Foam:ow(alpha1[0], 1.0/2.0) just above the runtime.write() line of interFoam.C and the solver gave the aforementioned error. The case we used to test the line of code is the standard dambreak tutorial case. |
February 22, 2015, 14:16 |
#9 |
Bruno Santos
Rep Power: 128 |
Hi Carlen,
Sorry, I was drawing ideas directly from what I remembered and ".value()" is actually only applicable for "dimensionedScalar" and similar classes/objects. Nonetheless, I've fortunately managed to reproduce the problem and it's fairly simple... remember the error message stating something about "sigfpe"? Well, it means this: http://en.wikipedia.org/wiki/SIGFPE#SIGFPE If you haven't figured it out yet, then here's the demonstration in source code:
And here I was imagining that it could have something to do with OpenFOAM's parallel coding mechanisms... and it was all due to a matter of understanding mathematics. Oh, as to why "alpha1" would have negative values? Well, in my tests, the values were negative, but they were very small, very near 0.0... therefore, they were computationally/numerically as good as 0.0. As for why it would only crash in parallel? Well, you were "lucky", in the sense that probably the values were only this bad for "alpha1[0]" in processor 2, because this cell was actually somewhere in the middle of the domain, while in serial mode, the "alpha1[0]" is always near the wall or floor (i.e always "1.0"). Best regards, Bruno |
February 23, 2015, 03:02 |
#10 |
Rep Power: 14 |
Thank you very much Bruno!
Your method perfectly solves my problem. I very much appreciate you taking time to answer my question. Best regards Carlen |
Error running simpleFoam in parallel | Yuby | OpenFOAM Running, Solving & CFD | 14 | October 7, 2021 05:38 |
Case running in serial, but Parallel run gives error | atmcfd | OpenFOAM Running, Solving & CFD | 18 | March 26, 2016 13:40 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 08:02 |
Random machine freezes when running several OpenFoam jobs simultaneously | 2bias | OpenFOAM Installation | 5 | July 2, 2010 08:40 |
