February 5, 2015, 18:05 |
Implementation of a very simple solver
Samuele Z
Rep Power: 19 |
Dear All,
I am trying to figure out how to manage a very simpe solver. I need only the continuity equation to be solved. What I want to do is the following: 1. my domain is very simple: an empty cube with 5 walls and 1 inlet; 2. I insert a certain flow rate from the inlet and I want to fill all the domain; 3. the idea is to evaluate the density of each cell; 4. in the cells with density < 1, everything is fine; where the density is bigger, I do the following: Delta_rho = rho - 1. Then I "the" the Delta_rho in the neibouhring cells. Does anyone have an idea about how to solve this? Thanks a lot, Samuele |
February 7, 2015, 07:54 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Samuele,
Here's some reading material:
Bruno
MAC Vs SIMPLE Solver? | Vino | Main CFD Forum | 1 | May 3, 2021 12:07 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 10:52 |
Multigrid with SIMPLE Navier-Stokes Solver | tyson | Main CFD Forum | 1 | June 12, 2011 03:09 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
n-s equation solver using simple algorithm | paresh.halder | FLUENT | 0 | December 3, 2010 17:00 |
