January 25, 2015, 19:28 |
Problems with time derivative
Rep Power: 12 |
Hello foamers!
I have two equations (assume p and T are dimensionless volScalarFields) 1) 2) I already know and , The first equation is easy: Code:
fvScalarMatrix pEqn ( fvm::ddt(p) + p ); pEqn.solve(); Now I know for all If I write the second equation using finite differences, I will get But what is the analogue of this equation in OpenFOAM? If I try to use Code:
fvm::ddt(p,T) + T So how to use OpenFOAM correctly here? Please help! |
January 26, 2015, 03:39 |
January 26, 2015, 04:18 |
Mattia de\' Michieli Vitturi
Rep Power: 17 |
are you sure that about this? I've always tought that ddt(p,T) discretizes the derivative in time of pT. Otherwise, if it was p times the temporal derivative of T, why not using p*ddt(t)? Also looking at Table 2.2 of the programming guide it seems that ddt(p,T) should be the discretization of the time derivative of (p*T). Can you clarify it? Thank you Mattia |
January 26, 2015, 04:55 |
#4 | |
Mohammad Shakil Ahmmed
Rep Power: 15 |
Cheers shakil |
January 26, 2015, 05:13 |
Rep Power: 12 |
January 26, 2015, 05:18 |
Well,
Here fvc::ddt method in EulerDdtScheme: Code:
template<class Type> tmp<GeometricField<Type, fvPatchField, volMesh> > EulerDdtScheme<Type>::fvcDdt ( const dimensionedScalar& rho, const GeometricField<Type, fvPatchField, volMesh>& vf ) { dimensionedScalar rDeltaT = 1.0/mesh().time().deltaT(); IOobject ddtIOobject ( "ddt("+rho.name()+','+vf.name()+')', mesh().time().timeName(), mesh() ); if (mesh().moving()) { ... } else { return tmp<GeometricField<Type, fvPatchField, volMesh> > ( new GeometricField<Type, fvPatchField, volMesh> ( ddtIOobject, rDeltaT*rho*(vf - vf.oldTime()) ) ); } } Code:
template<class Type> tmp<fvMatrix<Type> > EulerDdtScheme<Type>::fvmDdt ( const volScalarField& rho, const GeometricField<Type, fvPatchField, volMesh>& vf ) { ... scalar rDeltaT = 1.0/mesh().time().deltaTValue(); fvm.diag() = rDeltaT*rho.internalField()*mesh().Vsc(); if (mesh().moving()) { ... } else { fvm.source() = rDeltaT *rho.oldTime().internalField() *vf.oldTime().internalField()*mesh().Vsc(); } ... } |
Rep Power: 17 |
The correct formula is the first one. Take a look at the programmers guide (page 37 for version 2.3.1) and you will find everything. Eq. 2.21 is exactly what you are looking for.
Mattia |
January 27, 2015, 19:35 |
Rep Power: 12 |
I am not sure that I understand correctly...
I think that in the beginning of the time loop (p and T are dimensionless volScalarFields) we have formula below: But after solving this equation: Code:
fvScalarMatrix pEqn ( fvm::ddt(p) + p ); pEqn.solve(); So ? I mean when we use , rho always behaves like a scalar, right? Please correct me, if I am wrong. |
January 28, 2015, 04:26 |
#9 |
It behaves like scalar field i.e. it can vary in space.
January 28, 2015, 05:10 |
#10 |
Rep Power: 12 |
January 28, 2015, 17:44 |
new problem
#11 |
Rep Power: 12 |
Hi, I have a new big problem with temporal derivative!
Again, A and B are dimensionless volScalarFields I also have Code:
dimensionedScalar c ("c", dimensionSet(0, 0, 1, 0, 0, 0 ,0), 1.0); I solved the first equation: Code:
fvScalarMatrix AEqn ( c*fvm::ddt(A) + A ); AEqn.solve(); Now I know and , After that I tried to solve the second equation: Code:
fvScalarMatrix BEqn ( c*fvm::ddt(A) +c*fvm::ddt(B) + B ); BEqn.solve(); Code:
--> FOAM FATAL ERROR : incompatible fields for operation [A] + [B] How can I tell him that? Thank you very much for any hint ... |
January 29, 2015, 02:45 |
#12 |
fvm:: methods usually operate on the same field, so OpenFOAM is not quite happy about your fvm::ddt(A) + fvm::ddt(B). If you need time derivative of A in equation for B, you can use it as a source term with fvc::ddt(A). So your code should be: Code:
fvm::ddt(B) + B/c + fvc::ddt(A) |
January 29, 2015, 03:53 |
#13 |
Rep Power: 12 |
alexeym, exactly, I need to use fvc::ddt(A) in my equation...
Thanks a lot! |
Elastic or Plastic Deformations in OpenFOAM | NickolasPl | OpenFOAM Pre-Processing | 36 | September 23, 2023 09:22 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
