How PotentialFreeSurfaceFoam Calculate "Zeta"
Like Tree4Likes
  • 4 Post By xiaofishnus
Old   January 23, 2015, 03:31
Question How PotentialFreeSurfaceFoam Calculate "Zeta"
xiaofishnus is on a distinguished road
Hi, there
I am learning the PotentialFreeSurfaceFoam. Can anybody provide me the related reference about this FOAM? Can anybody brief me how the FOAM calculate 'zeta'. In the source code I just see the definition of zeta in createFields.H. I did not see any other code which explicitly calculates 'zeta'.
Thanks a lot!
xiaofishnus is offline   Reply With Quote
Old   January 23, 2015, 04:31
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
If you take a look at potentialFreeSurfaceFoam.C, you will see the following:
Description
    Incompressible Navier-Stokes solver with inclusion of a wave height field
    to enable single-phase free-surface approximations
    Wave height field, zeta, used by pressure boundary conditions
    Turbulence modelling is generic, i.e. laminar, RAS or LES may be selected.
If user set IC for zeta, the field will be read, otherwise it will be zero. Then the field can be used by BCs (waveSurfacePressure for example) but it is not recalculated in potentialFreeSurfaceFoam.
alexeym is offline   Reply With Quote
Old   January 25, 2015, 22:06
Wink
Thanks for your reply.
Could you please recommend some references related to potentialFreeSurfaceFoam?
Thanks.
potentialfreesurfacefoam, reference paper, source code, zeta
calculate a nozzle flow using rhoCentralFoam hg2lf OpenFOAM 0 October 25, 2012 22:26
calculate Nu number Diana.N FLUENT 3 February 27, 2012 14:40
calculate values for eps and k from Re or u????? sbar OpenFOAM Pre-Processing 5 August 16, 2010 05:10
How to calculate Torque for francis turbine manish CFX 4 March 15, 2007 03:57
can use coupled solver to calculate combustion cfdfans FLUENT 0 November 25, 2003 05:48
