How to access identity matrix in OF?
Like Tree3Likes
  • 1 Post By jherb
  • 1 Post By alexeym
  • 1 Post By infinity
Old   January 16, 2015, 02:21
Default How to access identity matrix in OF?
T. Chourushi
Tushar@cfd is on a distinguished road
Dear Foamers,
I wish to use identity matrix "I" for a Tensor field. I am using the following line for writing the identity matrix.
    volTensorField Ei = I ;
The above code line generates the following error, by looking at error it is clear that problem seems to be with the transformation of Tensors (spherical -to- volume field). For my case I need volTensorField to represent the identity matrix. How to resolve this issue?
testFoam.C: In function ‘int main(int, char**)’:
testFoam.C:71:22: error: conversion from ‘const sphericalTensor {aka const Foam::SphericalTensor<double>}’ to non-scalar type ‘Foam::volTensorField {aka Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>}’ requested
Thanks in Advance!
Tushar@cfd is offline   Reply With Quote
Old   January 16, 2015, 05:46
Joachim Herb
jherb is on a distinguished road
Try something like
 volTensorField Ei = tensor::one;
Tushar@cfd likes this.
jherb is offline   Reply With Quote
Old   January 16, 2015, 06:02
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Either use correct constructor (something like this):
volTensorField Ei
    IOobject
         "Ei",
         runTime.timeName(),
         mesh,
         IOobject::NO_READ,
         IOobject::AUTO_WRITE
    mesh,
    <dimensions>,
    <BC type>,
    I
if you plan to modify the field later, or, if you just need a constant in expression, use I.
alexeym is offline   Reply With Quote
Old   January 16, 2015, 06:27
T. Chourushi
Thanks a lot for your quick replies. It worked
Old   March 7, 2015, 00:43
Amir
infinity is on a distinguished road
Hi
I've put
   volTensorField Ei;
in my header file and this
 Ei
         IOobject
              "Ei",
              runTime_.timeName(),
              mesh_,
              IOobject::NO_READ,
         mesh_,
in my LES model constructor to define the identity tensor but unfortunately compiler said
error: expected primary-expression before ‘)’ token
any idea?
infinity is offline   Reply With Quote
Old   March 7, 2015, 01:49
T. Chourushi
Originally Posted by infinity View Post
Hi
I've put
   volTensorField Ei;
 Ei
         IOobject
              "Ei",
              mesh_,
              IOobject::NO_READ,
         mesh_,
any idea?
Dear Amir,
Try these:
 volTensorField Ei
         IOobject
              "Ei",
              mesh_,
              IOobject::NO_READ,
         mesh_,
and
Ei = tensor::one;
This will do the job.
Best Luck!
Old   March 9, 2015, 00:47
Amir
Dear Tushar
I solved the problem by using
tensor Ei(1,0,0,0,1,0,0,0,1);
and it worked ,
wish U the best my friend and thanks a lot for quick answering
acs likes this.
Convection Diffusion 1-D Matrix Problem balrog Main CFD Forum 1 November 3, 2014 14:34
more equation in block matrix system yhaomin2007 OpenFOAM 1 September 6, 2012 09:33
Access to arrays of Pressure matrix in CFX omidiut CFX 5 October 14, 2011 13:05
Force can not converge colopolo CFX 13 October 4, 2011 23:03
OpenFOAM version 1.6 details lakeat OpenFOAM Running, Solving & CFD 42 August 26, 2009 22:47
