compressible multiphase solvers
Like Tree2Likes
  • 2 Post By demichie
Old   January 15, 2015, 05:06
Default compressible multiphase solvers
mbani
Maryam1988 is on a distinguished road
Dear Foamers,
I have a solver for compressible liquid and gas phases which uses vof method and solves one momentum equation with mixture properties.
1) Is it possible to solve two separate momentum equation for each phase with their own properties? How?
2) Is it possible to change the thermophysical properties of the solver which consider each phase separately?
Best of all,
Maryam
Maryam1988 is offline   Reply With Quote
Old   January 15, 2015, 08:09
Anil Kunwar
Annier is an unknown quantity at this point
Hi Maryam,
You can study the report/tutorial on A description of the twoPhaseEulerFoam solver (Author: Praveen Prabhu Baila)
at http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2008/ . This tutorial is for incompressible flow and it starts with a good description about defining properties and equations in two different phases.
For compressible flows, you can find other similar reports. For example, the tutorial/report on A description and improvement of the interPhaseChangeFoam solver for Large Eddy Simulation of cavitating flow (Author:NaiXian LU) in the same website.
Yours
Anil Kunwar
Annier is offline   Reply With Quote
Old   January 22, 2015, 16:14
mbani
Dear Anil,
Thanks. but I need a solver which considers both phases as compressible and heat transfer equation.
Thanks again,
Maryam
Old   January 23, 2015, 04:23
Mattia de\' Michieli Vitturi
demichie is on a distinguished road
twoPhaseEulerSolver, in the more recent version of OpenFoam, solves for two compressible phases with two momentum equations (two velocities and one common pressure). Each phase has its own dictionary with the thermophysical properties.
Mattia
Annier and jamestangx like this.
demichie is offline   Reply With Quote
Old   January 25, 2015, 09:43
Anil Kunwar
Hi Maryam,
Also, another tutorial on twoPhaseEulerFoam prepared by Sandra Busch is given in http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2014/
Yours
Anil Kunwar
Old   January 31, 2015, 02:43
Ron
ron_OFuser is on a distinguished road
Check out this link for Chalmer documents
http://www.cfd-online.com/Forums/ope...-chalmers.html
Cheers Chalmers
ron_OFuser is offline   Reply With Quote
compressible, euler-euler, thermophysicalproperties
How rho_ and psi_ are calculated in compressible solvers of OpenFOAM? JBUNSW OpenFOAM Programming & Development 17 February 12, 2021 09:59
Adding porous zones to compressible multiphase solvers Hisham OpenFOAM Programming & Development 8 November 27, 2015 06:14
Low Mach Number Compressible Multiphase Flows DarrenC CFX 10 May 26, 2014 09:52
Cryogenics, compressible multiphase and heat transfer solver mturcios777 OpenFOAM Programming & Development 3 March 22, 2012 11:11
Compressible Multiphase Jens Siemens 0 October 7, 2002 09:10
