Updating face properties for a moving mesh
Like Tree1Likes
  • 1 Post By Artur
Old   January 6, 2015, 10:21
Default Updating face properties for a moving mesh
Artur's Avatar
Artur
Artur will become famous soon enough
Hi All,
I am trying to extract face centres and normal vectors of a set of faces described by a patch. It works fine for a stationary mesh but when I move the code to a dynamic mesh solver and apply rotation to the faces I am interested in the face normal vector does not update but the face centre does.
In other words, the second quantity of the following is always the same:
Info << mesh.Cf().boundaryField()[patchi][patchFaceI] << " "
     << mesh.Sf().boundaryField()[patchi][patchFaceI] << endl;
Any suggestions how to fix it? I'm digging through the code but haven't found anything yet...
All the best,
A
Artur is offline   Reply With Quote
Old   January 6, 2015, 11:10
Artur's Avatar
Artur
I'm sorry, I was looking at a wrong face. Everything works as it should, it was just me being stupid.
In case someone wonders, here's a piece of code computing the normal of a face (taken from primitiveMeshGeometry.C) I used to find the mistake:
    const labelList& f = mesh.faces()[faceI];
    const List<point>& p = mesh.points();
    label nPoints = f.size();
    vector sumN = vector::zero;
    point fCentre = p[f[0]];
    for (label pi = 1; pi < nPoints; pi++)
        fCentre += p[f[pi]];
    fCentre /= nPoints;
    for (label pi = 0; pi < nPoints; pi++)
        const point& nextPoint = p[f[(pi + 1) % nPoints]];
        vector n = (nextPoint - p[f[pi]])^(fCentre - p[f[pi]]);
        sumN += n;
    Info << 0.5*sumN << endl; // final result for the area vector
gentela likes this.
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
Question on moving mesh, mesh velocity is really small! ripperjack Main CFD Forum 2 April 28, 2014 14:37
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
