dynamicMeshDict diffusivity
Like Tree2Likes
  • 2 Post By dduque
Old   December 3, 2014, 07:27
Default dynamicMeshDict diffusivity
Xiantao Zhang
zhxter is on a distinguished road
hi, Foamers,
I am now trying to establish a 2D numerical wave tank(NWT) using OpenFOAM.
The left boundary of the rectangular NWT is moving to generate waves. Suppose the name of the patch is set "movingWall", and in the dynamicMeshDict, the contents are as follows,
FoamFile
version 2.0;
format ascii;
class dictionary;
object dynamicMeshDict;
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolverLibs ("libfvMotionSolvers.so");
solver displacementLaplacian;
displacementLaplacianCoeffs
diffusivity inverseDistance 1 (movingWall);
My question is : what does the number "1" after the inverseDistance mean?
zhxter is offline   Reply With Quote
Old   October 11, 2019, 05:41
Daniel Duque
dduque is on a distinguished road
It's just the number of patches that are listed next. I just found out myself...
john myce and Michael@UW like this.
dduque is offline   Reply With Quote
Old   February 14, 2020, 12:25
john myce is on a distinguished road
Hi guys,
I am also working on dynamic mesh. Does anyone know the meaning of the coefficient set for the following diffusivity methods:
directional (1 200 0);
exponential 5 inverseDistance (...);
motionDirectional (1 1000 0);
I guess they are related to each coordinate axis but I still don't know the meaning of the number setting up.
Cheers,
john myce is offline   Reply With Quote
Old   February 23, 2020, 13:53
I'm coming with some updates:
for the coefficient to provide for the exponential method, it is the exponent of the function to calculate the diffusivity:
Foam::exponentialDiffusivity::operator()() const
    return exp(-alpha_/basicDiffusivityPtr_->operator()());
from /src/fvMotionSolver/motionDiffusivity/manipulators/exponential/exponentialDiffusivity.C
For the directional & motiondirectional methods, I still don't know if it is just the distance in each coordinate axis or the mean non-orthogonality (first coefficient) and mean skewness (second).
References :http://www.tfd.chalmers.se/~hani/kur...h_openfoam.pdf page 23 &
http://www.tfd.chalmers.se/~hani/kur...AM-rapport.pdf from page 11 to 14
Cheers,
Old   May 20, 2020, 20:04
Default diffusivity directional
Michael@UW is on a distinguished road
Cheers,
Hi John,
Thank you for sharing! I read the reference at http://www.tfd.chalmers.se/~hani/kur...AM-rapport.pdf. It says "the first number determines the mean cell non-orthogonality; while the second number determines the mean cell skewness."
But I doubt the parameters in directional is a vector to control the diffusivity in 3 directions. As I found the code in directionalDiffusivity.C
void Foam::directionalDiffusivity::correct()
    const surfaceVectorField n(mesh().Sf()/mesh().magSf());
    faceDiffusivity_ == (n & cmptMultiply(diffusivityVector_, n));
Can you confirm that?
Thanks!
Michael
Michael@UW is offline   Reply With Quote
Old   May 20, 2020, 20:06
Originally Posted by zhxter View Post
hi, Foamers,
FoamFile
version 2.0;
format ascii;
class dictionary;
Hi Xintao,
I found the number 1 appears in some tutorials but not in some others. Just wondering if it is optional or not.
Thanks,
Michael
Old   May 21, 2020, 10:52
Hi Michael,
I have still a doubt of what we clearly provide as an input for the coefficients.
I tried different values but without any revelation.
Anyway thanks for providing this part of the code.
I have found at this link:
https://www.openfoam.com/documentati...89434350fa0f17
Sf returns cell face area vectors.
magSf returns cell face area magnitudes.
cmptMultiply is scaling two tensors : n which gathers Sf/magSf (cell unit vector) & the one which gathers the user-defined coefficients.
So I definitely think that it does not control the diffusivity in 3 directions but instead (tell me if I am wrong), calculating the diffusivity using the user-defined diffusivity vectors and the unit normal vectors of each face.
Cheers
Old   May 21, 2020, 11:09
Originally Posted by Michael@UW View Post
Hi Xintao,
Thanks,
Michael
Regarding this question, you don't have to provide this coefficient but if you provide it with the wrong number of patches declared, the meshing process will not running.
inversedistance
Kinematic Diffusivity - Problem with additional variable clau90 CFX 3 May 14, 2014 10:54
Diffusivity model in dynamicMeshDict of movingCone xuezhj OpenFOAM Running, Solving & CFD 0 October 2, 2012 23:11
PEM modeling UDS diffusivity in mixture gemini FLUENT 6 August 7, 2012 08:37
What is UDS diffusivity of a self-defined material? aleisia FLUENT 0 March 5, 2011 23:08
Motion diffusivity solver has problems with patches moving toward each other bfa OpenFOAM Running, Solving & CFD 2 July 8, 2009 22:35
