Problem with linearized Navier-Stokes equations
Like Tree1Likes
  • 1 Post By alexeym
Old   October 4, 2014, 12:57
Default Problem with linearized Navier-Stokes equations
Andrea
And901 is on a distinguished road
Hi everybody,
i'm new to OpenFOAM and i'm trying to solve the incompressible linearized Navier-Stokes equations.
Called U_zero the equilibrium solution, i tried to modify the icoFoam.C code as follow:
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi_zero, U)
+ fvm::div(phi,U_zero)
- fvm::laplacian(nu, U)
solve(UEqn == -fvc::grad(p));
where phi_zero is defined as
surfaceScalarField phi_zero
IOobject
"phi_zero",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT,
IOobject::AUTO_WRITE
linearInterpolate(U_zero) & mesh.Sf()
I also defined U_zero in createFields.H as:
Info<< "Reading field U_zero\n" << endl;
volVectorField U_zero
IOobject
"U_zero",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
mesh,
Foam::vector(1,0,0)
I compiled the code without errors but when i try to run a case (cavity for example) the following error message appears:
--> FOAM FATAL ERROR:
valueInternalCoeffs cannot be called for a calculatedFvPatchField
on patch movingWall of field U_zero in file "/home/andrea/Desktop/tesi/openfoam/tutorials/incompressible/icoFoam/cavityLinearized/0/U_zero"
You are probably trying to solve for a field with a default boundary condition.
From function calculatedFvPatchField<Type>::valueInternalCoeffs( const tmp<scalarField>&) const
in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 144.
FOAM exiting
I know that i should first calculate U_zero as a stationary solution and then solve the linearized NS equation in a neighbourhood of it . In my case U_zero is just a constant vector, but i'm just trying to run the code without errors to see what happens.
Thanks for your help.
Regards, Andrea
And901 is offline   Reply With Quote
Old   October 4, 2014, 16:32
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
if I got your problem right, you need to set boundary conditions for U_zero. Now you create the field with:
IOobject
"U_zero",
runTime.timeName(),
mesh,
mesh,
Foam::vector(1,0,0)
but you can add
IOobject
"U_zero",
runTime.timeName(),
mesh,
mesh,
Foam::vector(1,0,0),
U.boundaryField().types()
so U_zero will have the same BCs as U. In fact you can change U.boundaryField().types() to any BC you'd like U_zero to have.
alexeym is offline   Reply With Quote
Old   October 5, 2014, 04:58
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good morning,
You must use fvc:: on the U_zero term, as it should not be a part of your matrix, but rather the source term.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   October 5, 2014, 06:19
Andrea
Hi Alexey,
thanks for your reply, i added the new line for BC as you said but a new error appears:
incompatible dimensions for operation
[U[0 1 -2 0 0 0 0] ] + [U[0 0 -1 0 0 0 0] ]
From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&)
in file /opt/openfoam211/src/finiteVolume/lnInclude/fvMatrix.C at line 1316.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
at ??:?
at ??:?
at ??:?
#5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Aborted (core dumped)
It seems that U dimensions are not correct but U file in /0 directory has dimensions:
dimensions [0 1 -1 0 0 0 0];
Old   October 5, 2014, 06:23
Andrea
Hi Niels,
sorry, maybe my question is stupid but why did you say that U_zero should be a source term? In linearized Navier-Stokes equations U_zero is always coupled with U so how can i write it as a source term?
Best Regards,
Andrea.
Old   October 5, 2014, 10:18
Alexey Matveichev
I think it's U_zero, not U, that gives you dimension problem; it seems U_zero is dimless (so dimensions of div(phi, U_zero) is 1/s.
Maybe dimensions of U_zero that you've put in 0 folder are overwritten by Foam::vector(1,0,0), try using dimensionedVector("U_zero", dimVelocity, vector(1, 0, 0)).
About comment by Niels, in your div(phi, U_zero) there's no U, so you have to use div method from fvc namespace. And it will be treated as a source term.
ngj likes this.
Old   October 6, 2014, 06:49
Andrea
Hi Alexey,
thanks a lot for your advices, i solved the problem.
Sorry if i ask you one more question; i would like to read U_zero from a file following these steps:
1) run cavity case with icoFoam;
2) extract U field at each time step typing "foamCalc components U";
3) Set U_zero = U (so i need to read U_zero from a file);
4)Solve linearized Navier-Stokes equations around U_zero;
I have done step 1 and 2 but i don't know how to do step 3.
I would appreciate your help.
Best regards,
Andrea
Old   October 6, 2014, 09:52
Alexey Matveichev
right now the only solution that I can think of is to use another variant of IObject constructor to create U_zero vector field:
http://foam.sourceforge.net/docs/cpp...52f901319147b6
IOobject
    const fileName& path,
    const objectRegistry& registry,
    readOption r = NO_READ,
    writeOption w = NO_WRITE,
    bool registerObject = true
with this constructor you can directly specify path of the object i.e. path to the simulation results you've obtained with icoFoam.
Old   October 7, 2014, 11:11
Andrea
Thanks Alexey,
problem solved.
Best Regards,
Andrea
Old   December 6, 2015, 07:51
kkpal is on a distinguished road
Thanks to this thread, my icoLinearFoam is also compiled.
Now I am trying to construct the operation matrix M, for U_{n+1}=MU_n, and analysis the eigenvalues of M to see if the base flow is stable or not.
kkpal is offline   Reply With Quote
Old   December 6, 2015, 09:32
ali alkebsi
kebsiali is on a distinguished road
Hello
I think you either have a missing file or a miss-spell in the name of the file or inside U_zero
kebsiali is offline   Reply With Quote
Old   December 6, 2015, 09:42
Hi, ali,
Yes, I made a mistake and I've corrected it. I have successfully compiled and run it.
Now I would like to analyse the global stability of the flow by the eigenvectors (growth rate) of the matrix M by constructing U_{n+1}=MU_{n}, in which U is the velocity velocity vector. Any idea how to achieve this?
Non-dimensionalizing Navier Stokes VincentD Main CFD Forum 16 July 10, 2017 05:55
Navier stokes Equations in Unstructured Grid Mh.R Main CFD Forum 4 October 19, 2011 16:37
Navier stokes compresible viscid flow fea, somebody can help? Jose Choy Main CFD Forum 3 October 24, 2003 03:28
Presure range of the Navier Stokes Equations Dr. Tsimento Main CFD Forum 7 May 23, 2001 11:12
need help on solution to Stokes equations Yuksel Onsoy Main CFD Forum 3 November 2, 2000 06:54
