September 25, 2014, 08:39 |
How to "Info << " in parallel environment?
Lianhua Zhu
Rep Power: 15 |
The standard "Info <<" seems work only for the master process.
But I want to let the process with rank id other than 0 to output. I want't do that because I'm debugging my solver. How can I do that? Best, Lianhua |
September 25, 2014, 09:46 |
Xiaofeng Liu
Rep Power: 17 |
use "Pout << "
Xiaofeng Liu, Ph.D., P.E., Assistant Professor Department of Civil and Environmental Engineering Penn State University 223B Sackett Building University Park, PA 16802 Web: http://water.engr.psu.edu/liu/ |
September 25, 2014, 09:48 |
Lianhua Zhu
Rep Power: 15 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 16:25 |
simpleFoam in parallel issue | plucas | OpenFOAM Running, Solving & CFD | 3 | July 17, 2013 12:30 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 17:49 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 13:00 |
