August 25, 2014, 11:14 |
Gravity in rotating screw
riccardo maione
Rep Power: 12 |
Hello everyone,
I am sorry I know this is a beginner question but I am fairly new to Openfoam, so I will gladly appreciate your help. I'd like to simulate the behavior of a screw auger combustor who utilises char as the main fuel, steel is also present in this reactor and it receives the heat from conduction and convection, I know I have to divide the problem because openfoam is not capable of calculating the conduction heat transfer due to contact between particles, but my question is, is openfoam capable of simulating all the other phenomena? (hydrodynamics with char and steel balls and char combustion reaction), if yes which is the most suited solver to do that? thanks for your kind attention, Riccardo Maione |
September 17, 2014, 10:02 |
riccardo maione
Rep Power: 12 |
Hello all!
I'd like to simulate a gas in a rotating screw conveyor and my idea of rotation implementation is to use a rotating non inertial system, so I have resolved the acceleration field in my mesh but now I do not know how to implement it in OpenFOAM, I am a beginner in OpenFoam so please have simpathy thank you all by the way P.S. the acceleration vector changes only with position, it doesn't change with time |
October 5, 2014, 06:26 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Riccardo and welcome to the forum!
I moved your two posts into the same thread, because this way we can have a better picture of what you're trying to do. Nonetheless, it feels like you didn't provide enough information in order to make it easier to give you some suggestions. From the brief search and understanding I can gather:
It's unlikely that an existing solver will do everything you need... then again, it's possible that using rhoReactingFoam in OpenFOAM 2.3, along with MRF as an "fvOption" might do the trick. Best regards, Bruno
October 6, 2014, 03:40 |
#4 | |
riccardo maione
Rep Power: 12 |
First of all thanks for your help and sorry if I didn't provide so much information, what I am trying to do is to simulate a screw conveyor like the one you linked for the combustion of char. I want to implement this in the CFDEM package (www.cfdem.com), so what i did was to code the rotating frame in the solver. what CFDEM does is to simulate a solid phase with a dem approach and the gas phase with a cfd approach and after a fixed time step they exchange information. Yes, I use a transient solver to solve this. My only problem is to implement the compressibility into the solver (I added conservation of species, continuity for compressible gasses and the possibility of a solid reaction). Yes, some particles decay over time, some particle doesn't (there is a mix of steel particles and char particle and this is the reason why I use a CFDEM approach: I need to study the heat exchange between particles by contact). Now, my question is, which changes need to be made to change a solver from an incompressible one into a compressible one in OpenFOAM? I thank you another time for the help, Riccardo Maione |
October 11, 2014, 17:31 |
#5 | |
Bruno Santos
Rep Power: 128 |
Hi Riccardo,
Let's see... the basics for switching a transient incompressible solver to a transient compressible solver can easily be found by comparing these two solvers:
Let's see, what else is there... you might also want to have a look into these two, since they are more related to the reaction part of the simulation you need: Code:
echo $FOAM_SOLVERS/combustion/reactingFoam/ echo $FOAM_SOLVERS/combustion/reactingFoam/rhoReactingFoam/ Best regards, Bruno |
October 15, 2014, 04:46 |
#6 | |
riccardo maione
Rep Power: 12 |
now all is much clearer, and I did the solver change, but what when I look to coalCombustionFoam there is a term linked to gas source term coalParcels.Srho(), shouldn't it be a momentum exchange term between particles, like + coalParcels.SU(U)? |
October 19, 2014, 05:59 |
#7 | |
Bruno Santos
Rep Power: 128 |
Hi Riccardo,
Because from what I can figure out:
Bruno
October 20, 2014, 03:31 |
riccardo maione
Rep Power: 12 |
Like always probably I wasn't that clear, I am sorry for that,
in pEqn.H the program solves: while (pimple.correctNonOrthogonal()) { fvScalarMatrix pEqn ( fvm::ddt(psi, p) + fvc::div(phiHbyA) - fvm::laplacian(rho*rAU, p) == coalParcels.Srho() + fvOptions(psi, p, rho.name()) ); so there is a mass source term, is it because continuity equation was substitued into the pressure equation? Sorry again and best regards, Riccardo |
January 25, 2015, 15:24 |
#9 |
Bruno Santos
Rep Power: 128 |
Greetings Riccardo,
Sorry for the late reply, but only now was I able to look into this again. OK, I think there is something that you might not be familiar with, at least in OpenFOAM:
January 25, 2015, 15:30 |
#10 | |
riccardo maione
Rep Power: 12 |
thanks for your reply, however I didn't realize how the source term of the solid phase was in the PISO equation, now I know it is due to the substitution of the continuity equation is that correct? best regards Riccardo |
January 25, 2015, 15:43 |
#11 | |
Bruno Santos
Rep Power: 128 |
Hi Riccardo,
What I think I'm not understanding, is that I can't figure out what is the "before and after" you're referring to as "substitution". What I can say for certain is that source terms are usually added to any equations, usually on the right side of the respective equation. Best regards, Bruno |
January 25, 2015, 15:47 |
#12 |
riccardo maione
Rep Power: 12 |
To evaluate the pressure equation to resolve the system the navier stokes equation is manipulated to find the new pressure at the local timestep. during the manipulation of the navier stokes equation the velocity gradient is substituted with the continuity equation, in order to decouple pressure and velocity, and so the solid mass source, is that correct?
January 25, 2015, 16:23 |
#13 | |
Bruno Santos
Rep Power: 128 |
Mmm... OK, I think I now understood your question.
There are several solvers we need to look into, in order to understand what's going on:
Nonetheless, it seems to me that you're looking at the opposite way as to how OpenFOAM decouples the equation. It's the pressure gradient that can affect the momentum equation: Code:
if (pimple.momentumPredictor()) { solve(UEqn == -fvc::grad(p)); fvOptions.correct(U); K = 0.5*magSqr(U); }
Sorry for not being able to give a better answer here, but this is a bit off my level of expertise |
January 25, 2015, 16:44 |
#14 |
riccardo maione
Rep Power: 12 |
Thank you really much Bruno,
I had read those pages and as a matter of fact I wrote, compiled, used and tested the solver in the cfd-dem case with heterogeneous reaction, thank you again for you patience, I explained the problem with only a few words, maybe not too many. I am pretty sure of that because I was trying to say the exact same thing as you did in the last piece of code, I am really sorry. However I am pretty sure of what I said, I only wanted a word from the expert best regards, Riccardo |
Adding gravity in rotating domain | ThomasN | CFX | 4 | November 21, 2013 03:49 |
Problem with gravity and rotating domain i.e. Rotor-Stator CFX | Brendan | CFX | 0 | September 2, 2013 04:58 |
rotating gravity | olhe0002 | OpenFOAM Running, Solving & CFD | 1 | June 7, 2010 08:40 |
stress analysis of a rotating beam(wind blade) | Cheyannne | ANSYS | 0 | October 19, 2009 18:06 |
Gravity in single rotating reference frame | QinxueTan | FLUENT | 0 | May 7, 2008 07:59 |
