Augmented reduced mechanism for methane by J.-Y. Chen
Like Tree2Likes
  • 1 Post By Hagen
  • 1 Post By muhsinkhan
Old   September 11, 2014, 13:53
Default Augmented reduced mechanism for methane by J.-Y. Chen
Hagen Müller
Hagen is on a distinguished road
Dear Foamer's,
I am working on methane/air combustion. As the full mechanism that describes the chemistry kinetics is very expensive, I use reduced mechansims. So far I was happy with the 4-steps/7-species mechanism by Jones-Lindstedt or 16 species mechanism by Smooke.
However, especially at higher pressures the Augmented Reduced Mechanism (ARM) of J.-Y. Chen (COMBUSTION AND FLAME 125:906 –919 (2001)) is probably better. The only problem, the implementation in OpenFOAM is, I believe, not straightforward since steady state reactions are involved. A Frortran routine is available here: http://www.sandia.gov/TNF/chemistry.html
My question is, has anybody tried to use this mechanism in OpenFOAM? How could this be done?
Thank you!
Hagen
Tom123 likes this.
Hagen is offline   Reply With Quote
Old   February 1, 2016, 04:14
Tomladian Bucinara
Tom123 is on a distinguished road
Dear Hagen,
Could you please share the files of the reduced mechanism of 4-steps/7-species mechanism by Jones-Lindstedt or 16 species mechanism by Smooke. I need them badly. Thanks.
Tom
Tom123 is offline   Reply With Quote
Old   May 3, 2016, 03:59
Default Jones-lindstedt
Muhsin Khan
muhsinkhan is on a distinguished road
hello Tomladian,
you can search online for "Simplified Kinetic schemes for oxy-fuel combustion" by A frassoldati, which contains jones-lindstedt mechanism in chemkin format in table2. Also the JL method is mentioned in the book "High Temperature Combustion-chapter3 by Hiroshi Tsuji".
sivakumar1729 likes this.
muhsinkhan is offline   Reply With Quote
Utilise reduced kinetics mechanism (ARM19 etc.) clarkie_49 FLUENT 7 September 11, 2019 16:06
reduced reaction mechanism for methane combustion using FLUENT vnm ANSYS 1 August 9, 2016 10:25
CHEMKIN format incompatibilities with reduced n-Heptane mechanism kriete OpenFOAM Programming & Development 0 December 26, 2013 17:29
CHEMKIN format incompatibilities with reduced n-Heptane mechanism kriete OpenFOAM Running, Solving & CFD 0 December 23, 2013 08:00
Reduced mechanism for Ethylene Combustion Chaitanya FLUENT 1 May 9, 2011 07:40
