the openfoam source term and fvmatrix problem
Like Tree1Likes
  • 1 Post By wenxu
Old   September 5, 2014, 11:56
Default the openfoam source term and fvmatrix problem
Freedom
wenxu is on a distinguished road
hi,everyone:
In the src/finitevolume/fvm/fvmSup.C,there is the code:
(1)template<class Type>
Foam::tmp<Foam::fvMatrix<Type> >
Foam::fvm::Su
const DimensionedField<Type, volMesh>& su,
const GeometricField<Type, fvPatchField, volMesh>& vf
const fvMesh& mesh = vf.mesh();
tmp<fvMatrix<Type> > tfvm
new fvMatrix<Type>
vf,
dimVol*su.dimensions()
fvMatrix<Type>& fvm = tfvm();
fvm.source() -= mesh.V()*su.field();
return tfvm;
(2)template<class Type>
Foam::fvm::Sp
const DimensionedField<scalar, volMesh>& sp,
new fvMatrix<Type>
vf,
dimVol*sp.dimensions()*vf.dimensions()
fvm.diag() += mesh.V()*sp.field();
return tfvm;
(3)template<class Type>
Foam::fvm::SuSp
const DimensionedField<scalar, volMesh>& susp,
new fvMatrix<Type>
vf,
dimVol*susp.dimensions()*vf.dimensions()
fvm.diag() += mesh.V()*max(susp.field(), scalar(0));
fvm.source() -= mesh.V()*min(susp.field(), scalar(0))
*vf.internalField();
return tfvm;
The code in red colour, for the EXPLICIT the operator is "-=" from the source term of the fvmatrix. for the IMPLICIT the operator is "+=" from the the diagnal term of the fvmatrix. what that mean? i think the source term is rho*phi*V, so where is the "phi"? (i don't know the fvmatrix's diagnal and source stands for? )
And for the IMPLICIT/EXPLICIT, when susp.field() greater than zero, it is the same as the IMPLICIT, i could understand that. but when susp.field less than zero, it should be use EXPLICIT, but you know that it subtract the rho*phi*V from the source of the fvmatrix, I really confused with it....
anyone could so kind to help me, thank you in advance.
fnovo likes this.
wenxu is offline   Reply With Quote
Implicit source term mcdonalds OpenFOAM Programming & Development 11 November 14, 2019 09:33
Problem about fvMatrix in OpenFOAM, over volume or not yhaomin2007 OpenFOAM 1 July 6, 2015 22:11
