on the run flow-rate evaluation on a cluster
Like Tree3Likes
  • 3 Post By kmooney
Old   August 25, 2014, 05:10
Default on the run flow-rate evaluation on a cluster
wstapel is on a distinguished road
Dear Foamers,
I've got a problem with coding a parallel calculation of the flow-rate which is to be evaluated on the run (not by integratePatchField).
My overall purpose is the following: I want the flow-rate to influence the inlet boundary conditions of an internal flow.
So far I've actually managed to evaluate the flow-rate, but it only works if I'm performing parallel calculations on my local machine or on one single node of a cluster. However if I try to run the very same calculation on a cluster distributed over several nodes, it always yields a zero flow-rate.
So obviously the problem must have something to do with parallelisation or with mpi ...
Finally here is the code, I added to the original icoFoam solver:
// Declaration and Initialisation of Variables
word outletPatchName = "OUTLET";
// search for label of the outlet patch by the name within the boundary dictionary
label inletPatchi = mesh.boundaryMesh().findPatchID(outletPatchName);
// Calculate volumetric flow-rate
scalar volFluxOutlet = sum(phi.boundaryField()[outletPatchi]);
// Write flow-rate
Info<< "Volumetric Flowrate: " << volFluxOutlet << " m^3/s" << endl;
I'd be glad for any helpful comments.
Waldemar
wstapel is offline   Reply With Quote
Old   August 25, 2014, 23:41
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Hi Waldemar,
Try using
gSum(...)
instead of
sum(...)
I believe that gSum has built-in mpi reduction operators while 'sum' does not.
I hope that helps!
Cheers,
Kyle
jhoepken, chrisb2244 and wstapel like this.
kmooney is offline   Reply With Quote
Old   August 26, 2014, 04:04
Hi Kyle,
it works fine. Thank you very much!
Old   August 26, 2014, 15:55
kmooney's Avatar
Kyle Mooney
Excellent! Good to hear.
clusters, flow-rate, programming
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 02:31
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 18:24
Mass flow rate boundary condition for continuity equation for oscillating flow p07ip705 Main CFD Forum 0 February 28, 2013 02:33
target flow rate: varying results Ryan FLUENT 3 January 9, 2008 14:54
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
